How to make a wrapper using wineskin for a certain game?
15 replies to this topic
#1 AlexJamesTB
AlexJamesTB
  • 38 posts
  • Graphics Card:AMD Radeon HD 6770M 1024 MB
Posted 12 March 2012 - 01:22 AM
I am trying to play Kingdoms of Amalur using wineskin but whene i use a blank wrapper i only get this:
http://imageshack.us...20312at121.png/
Mac OS X Lion
#2 GameGuy
GameGuy
  • 2,100 posts
  • LocationCanada...Eh
  • Graphics Card:nVidia 9400m 256mb
    ATI Radeon HD 6950 2GB
    MSI N670GTX PW/OCE 2GB SLI
  • I like to play:RPG, Racing, and of course FPS
Posted 12 March 2012 - 01:32 AM
inside the wrapper is a wineskin application in the advanced tab run the debug option and post logs here because that picture doesn't help.
Macbook Pro: Intel C2D 2.53ghz, 4GB Ram, Nvidia 9400m 256MB
Hackintosh: Intel i5-3570k, 16GB Ram, Asus Z77 Sabertooth, MSI GTX 670 Power Edition SLI
If my post helped you hit the like button :)
#3 AlexJamesTB
AlexJamesTB
  • 38 posts
Posted 12 March 2012 - 01:36 AM
You mean click "Test Run (Debug Mode)"
fixme:process:GetLogicalProcessorInformation (0x0,0x33fd3c): stub
fixme:process:GetLogicalProcessorInformation (0x3ffca020,0x33fd3c): stub
err:ole:CoInitializeEx Attempt to change threading model of this apartment from multi-threaded to apartment threaded
fixme:avrt:AvSetMmThreadCharacteristicsW (L"Audio",0x195f66c): stub
fixme:win:RegisterRawInputDevices (pRawInputDevices=0x33f92c, uiNumDevices=1, cbSize=12) stub!
fixme:win:RegisterRawInputDevices (pRawInputDevices=0x33f938, uiNumDevices=1, cbSize=12) stub!
fixme:d3d:init_driver_info Unable to find a driver/device info for vendor_id=0x1002 device_id=0x6740 for driver_model=2
fixme:win:EnumDisplayDevicesW ((null),0,0x33f56c,0x00000000), stub!
fixme:d3d:debug_d3dformat Unrecognized 0x5a574152 (as fourcc: RAWZ) WINED3DFORMAT!
fixme:d3d:wined3d_get_format Can't find format unrecognized (0x5a574152) in the format lookup table
fixme:d3d:debug_d3dformat Unrecognized 0x36314644 (as fourcc: DF16) WINED3DFORMAT!
fixme:d3d:wined3d_get_format Can't find format unrecognized (0x36314644) in the format lookup table
fixme:d3d:debug_d3dformat Unrecognized 0x34324644 (as fourcc: DF24) WINED3DFORMAT!
fixme:d3d:wined3d_get_format Can't find format unrecognized (0x34324644) in the format lookup table
fixme:d3d:debug_d3dformat Unrecognized 0x5a534552 (as fourcc: RESZ) WINED3DFORMAT!
fixme:d3d:wined3d_get_format Can't find format unrecognized (0x5a534552) in the format lookup table
fixme:d3d:debug_d3dformat Unrecognized 0x31495441 (as fourcc: ATI1) WINED3DFORMAT!
fixme:d3d:wined3d_get_format Can't find format unrecognized (0x31495441) in the format lookup table
fixme:d3dx:D3DXCreateEffectEx (0x167e88, 0xbdefe8, 720, 0x0, 0x0, 0x0, 0x108, 0x0, 0x243f54c, 0x243f544): semi-stub
fixme:d3dx:skip_dword_unknown Skipping 1 unknown DWORDs:
fixme:d3dx:skip_dword_unknown     0x00000003
fixme:d3dx:ID3DXBaseEffectImpl_GetDesc iface 0x21e1c8, desc 0x243f520 partial stub
fixme:d3dx:ID3DXBaseEffectImpl_GetPassDesc Pixel shader and vertex shader are not supported, yet.
fixme:d3d_shader:shader_select_frontend Unrecognised version token 0x3fe62200
fixme:d3d_shader:shader_set_function Unable to find frontend for shader.
#4 KGameLover1
KGameLover1
    News Editor - Master Troll
  • News Team
  • 839 posts
  • LocationWhere I am is where I be
  • Graphics Card:AMD Radeon HD 6750M 1024 MB, also Intel HD Graphics 3000 512 MB.
  • I like to play:Everything that's fun
Posted 12 March 2012 - 01:38 AM
Ask and you shall receive: http://portingteam.c...alur-reckoning/
blinxfrost said:
in game my guy spins out of control only way i can control is arrow keys my hands are to nubby to reach them and shot
View my ports! <--- Orcs Must Die, Payday, Fallout, I Wanna Be The Guy, and more!
How to use a Wineskin wrapper!
#5 AlexJamesTB
AlexJamesTB
  • 38 posts
Posted 12 March 2012 - 02:02 AM
I tried using that and it opened but I can only see the in game cursor and I think the sounds. The rest is just black
#6 KGameLover1
KGameLover1
  • News Team
  • 839 posts
Posted 12 March 2012 - 02:05 AM
Might not be working yet. Thanoulas and cluthz are working on it...probably
#7 AlexJamesTB
AlexJamesTB
  • 38 posts
Posted 12 March 2012 - 02:15 AM
NEVER MIND GOT IT WORKING
#8 cluthz
  • 2,642 posts
  • Graphics Card:Nvidia GTX660
  • Operating System:Mac OS X 10.8 (Mountain Lion)
Yeah, that port is defenately a WIP.
To fix the black screen issue, be sure to have only ONE screen connected.
Then go to Documents/My Games/Reckogning
inside there you'll find a "personal.ini" file
Open that file with textedit.
Set screen adapter to 1
set your screen res
set vsync = 0
Then you'll be able to see something.
Mouse movement is not working for me, it's just the same issue i have with my port which i haven't released due to it's not working properly.
[HackPro i5-4.3 GHz, 2x SSD + 5TB HDD • 16GB RAM • NVidia GTX 660 2GB • OSX 10.8.3] . [MacBookAir 13 1.7GHz • Intel HD 3000 • OSX 10.7.5]
How to port Steam games .... My Youtube Porting videos ... My Porting Nexus
#9 cluthz
  • 2,642 posts
Is the mouse working 100%, i mean can you run in a circle and turn around as you like?
#10 AlexJamesTB
AlexJamesTB
  • 38 posts
Posted 12 March 2012 - 02:30 AM
Okay, problems. I cannot turn around 180-360 degrees it stops at around 100 degrees when turning right and 200 degrees when turning left. Also you cannot see your character at all even when making his face in the first scenes (Character Customisation). When I first started playing I could not see my character but I could run. Also there are many texture issues with things jumping around.
http://i41.tinypic.com/246vvrd.png
http://tinypic.com/r/1zxqwx2/5
this is the view from third person. I will try and make a video showing it
#11 cluthz
  • 2,642 posts
Posted 12 March 2012 - 02:33 AM
Report it back on the port. I was really hoping it would work, but it don't.
I've made one where I can turn 180° each way, but that is also very limiting
#12 AlexJamesTB
AlexJamesTB
  • 38 posts
Posted 12 March 2012 - 02:37 AM
Can you please tell me the proper phrasing for this issue? Is it screen tearing?
#13 cluthz
  • 2,642 posts
Posted 12 March 2012 - 02:40 AM
you cannot see your own char?
tearing is when top and bottom of screen is a bit out of sync.
The main issue here is mouse tho, I'm pretty sure textures can be fixed, but mouse can't. Remember to report mouse issue too.
If he got mouse to work on his machine I'm really interested in how.
#14 AlexJamesTB
AlexJamesTB
  • 38 posts
Posted 12 March 2012 - 02:48 AM
Personally, I don't find the mouse to be a problem that makes it unplayable, i can live with that, but the textures are all going mad
#15 cluthz
  • 2,642 posts
Posted 12 March 2012 - 02:50 AM
If you can live with the mouse I can clean and up my port tomorrow, It has at least on my system better mouse.
#16 AlexJamesTB
AlexJamesTB
  • 38 posts
Posted 12 March 2012 - 03:11 AM
http://youtu.be/oOLCOlHiPwU
This is what it looks like
I am uploading a better version. But every time I play the gameplay changes. For instance, this time I could turn around 360 degrees.
http://youtu.be/hwIG3V8iJ5k
Oh and BTW, I am not playing this off of steam but off installation from disk
