Problems with automatic Login
Posted 24 July 2009 - 12:46 PM
Posted 24 July 2009 - 12:55 PM
In memories of our forum friend MaxWeber (21/06/09)
Follow us on facebook:
Posted 07 October 2009 - 05:49 AM
Posted 07 October 2009 - 09:07 PM
I think when you quit your browser window, the cookie session gets cancelled.
Posted 07 October 2009 - 10:16 PM
Join the Porting Team Steam Group!
#6
Posted 08 October 2009 - 02:16 AM
#7
Posted 08 October 2009 - 06:12 AM
i was referring to this function that appears when you press the login button but now that you mention it the remember me function doesn't always work either
#8
Posted 08 October 2009 - 06:25 PM
#9
Posted 09 October 2009 - 02:26 AM
#10
Posted 09 October 2009 - 05:26 AM
penyuan said:
You will get some help 8)
devilhunter said:
#11
Posted 11 October 2009 - 04:03 AM
I've had this problem at a few other forums, the cookies were set to another domain.
if you went to abc.com it wouldn't save your cookies, but if you went to www.abc.com it did.
In this case I would say it is like a different forum I was at though;
They had a domain, let's say www.xyz.com but the cookies were only set at the abcd domain.
Hopefully this helps...
#12
Posted 11 October 2009 - 04:11 PM
#13
Posted 11 October 2009 - 04:24 PM
if you went to abc.com it wouldn't save your cookies, but if you went to http://portingteam.c...php?www.abc.com it did.
They had a domain, let's say http://portingteam.c...php?www.xyz.com but the cookies were only set at the abcd domain.
Thanks for the tip, but i already switched the cookie domain when we first set up the new Domain.
But this problem was also on the old forum and Domain, as slacker pointed out some time ago.
I read through some phpbb docs for the correct cookie settings, and it seems they are as correct as they can be.
They are set up as followed:
Cookie domain: forum.portingteam.com
Cookie name: phpbb3_
Cookie path: /
If the problems with the automatic login wasn't working for some, i can only think of that they visit other forums and these forums have 'phpbb3_' also as their cookie names.
Therefore i changed the Cookie name to 'ptcookie' to maybe avoid this problem.
(the cookie name should be unique for each website to avoid this problem)
Here are some references where this is described:
http://www.olate.co.uk/articles/3
Cookie Name: This is set as default as phpbb2mysql and is just the name that the cookie is given when being stored. It doesn’t matter what this is set as but changing it will cause all the cookies to be needed to be added again. It is advised to give the cookie a name. If you are running multiple forums on the same server, it is advisable to have a different cookie name for each forum.
Cookie Path: This is where the cookie is directed to and is defaulted as / but this will depend on your forum location in your site directory. A common mistake here to put the URL (ie http://portingteam.c...edirect.php?htt ... xample.com) as the path which is incorrect.
This is because you have not set up the cookie domain or path correctly. Read the above information and double check your setup.
The members most likely have the cookie security settings set to disallow cookies. Tell them to change them to allow cookies completely or just from your site. IE6 has improved features for this and your members might have messed with the settings.
But maybe reset your cookie settings once, maybe that helps.
Make sure you have updated the cookie settings in your control panel to reflect the changes to your host and domain name.
So try the automatic login with the new cookie name again, otherwise this problem should be something more complicated...
#14
Posted 12 October 2009 - 03:50 AM
I tried to remove all my cookies that have either "phpbb3_" or "ibrain" or "portingteam" in them and tried to log in again. But the site still doesn't remember me. Is there anything else I could try?
I am running Safari 4 on Mac OS X 10.5.8 Leopard.
Thanks for all your efforts!
#15
Posted 13 October 2009 - 06:19 PM
Sadly, this is all i can do for now, if this still hasn't fixed the automatic login problems, i don't know what else to change.
Since this Problem existed even in the old Forum, this could be a bug in phpBB3.
Interestingly, not all users have this bug...
#16
Posted 02 December 2009 - 10:20 PM
#17 Guest_guard10225_*
Posted 26 January 2010 - 05:09 AM
#18
Posted 06 February 2010 - 12:07 AM
doh123 said:
Same here on firefox.
I AM CURRENTLY MISSING IN ACTION, AND NOT CHECKING THE FORUMS UNTIL FURTHER NOTICE.
/GOODBYE
#19
Posted 06 February 2010 - 12:29 AM
There is a fix i've found sometime ago, but i didn't use it.
http://www.phpbb.com...ic.php?t=228741
These kind of fixes tend to break a lot of things, and we could loose the ability to login entirely if i install this, like some posts from that Topic show.
Therefore i'm not gonna install this fix.
I can change the cookie settings all i want, it works for most users, and doesn't work for some.
But you can't keep an automatic login all the time on, for security reasons this has a time limit.
And always use the Logout button when you go away from here for the day.
#20
Posted 06 February 2010 - 02:51 AM
/GOODBYE
#21
Posted 12 March 2010 - 06:35 AM
#22
Posted 12 March 2010 - 04:56 PM
vvsamiamvv said:
The common thing among users is this forum and the inability to "Remember Me" and be automatically logged in. I am registered to plenty of PHP boards and I still can return to it and it automatically logs me in. Unfortunately, I am not good with codes so I got lost in devilhunter's post. Anyways, I don't mind clicking log in every time. It's an effortless work anyways.
#23
Posted 23 December 2010 - 09:08 PM
I don't mind if it's going to be fixed, however :)
This topic is locked
