Issues on El Capitan 10.11 Beta (15A262e)
65 replies to this topic
#1 pdeli
pdeli
  • 9 posts
  • Graphics Card:Intel HD Graphics 5000 1536 MB
Posted 23 August 2015 - 05:54 PM
Hello,
Here is what I do:
  • Click on Create New Blank Wrapper
  • enter a name for the wrapper
  • click on OK
And I get the following message:
The application X11 could not be opened.
An error occurred while starting the X11 server: "Failed to activate core devices."
Click Quit to quit X11. Click Report to see more details or send a report to Apple.
And I can either click on Report... or Quit.
(X11 is installed in /Applications/Utilities and runs when double clicked.)
Then I click on Quit and Wineskin says it's busy...: "Wineskin Winery is currently busy", beach ball and I have to force quit Wineskin. In the dock there are the Wineskin icon but a Terminal "exec" icon too with which I cannot interact (but which quits by right clicking and selecting quit).
When relaunching Wineskin, when I click on ok after having entered a name for the wrapper, I have another message appearing (which disappears after a few seconds) that says:
ERROR, tried to run command WSS-wineprefixcreate when the wrapper was already running.  Please make sure the wrapper is not running in order to do this.
Then I have to restart the computer in order to try to launch Wineskin again...
Any ideas?
(Using Engine WS9Wine1.7.50 and Wrapper Version Wineskin-2.6.0)
  • 1,171 posts
Posted 24 August 2015 - 06:16 AM
Can you turn on activity monitor and see if there're any processes with 'wine' in the name already running? If so, force quit them
It seems like you already have a process running that the creation system doesn't expect.
#3 pdeli
pdeli
  • 9 posts
Posted 24 August 2015 - 09:12 PM
Hello ovvldc,
Thanks for your answer.
Following your comment, here is what i did:
1. Restarted the computer
2. Started Activity Monitor
3. Checked if there was any process with "wine" in it, there was none
4. Started Wineskin Winery
5. When searching for "wine" in Activity Monitor "Wineskin Winery" shows up
6. In Wineskin Winery clicked on "Create New Blank Wrapper"
7. Pop-up Create a Wrapper shows up
8. Click on OK (didn't bother to change the default name "MyCoolWrapper")
9. And Activity Monitor shows a bunch of MyCoolWrapper61812526Wine appears (6 of them), a single MyCoolWrapper61812526Wineserver, a Wineskin Winery (Not Responding), a WineskinWineskinDefault3345 and a WineskinX11 appear (all in Activity Monitor)
10. Simultaneously a popup with "The application X11 could not be opened. An error occurred while starting the X11 server: "Failed to activate core devices." with butons Report... Quit appears
11. I quit, and only WineskinX11 disappears from the Activity Monitor
12 And Wineskin remains busy... only force quit will do
Can I do anything else?
Thanks and best regards,
Peter
#4 ovvldc
  • 1,171 posts
Posted 25 August 2015 - 09:27 AM
Have you tried installing XQuartz? You can find the most recent available version at http://xquartz.macos.../wiki/X112.7.8.
If you start that first, there will already be an X11 running, and the problem should go away, even though it is pretty strange to begin with because the wrapper should be setting up its own X11 environment automatically.
#5 pdeli
pdeli
  • 9 posts
Posted 25 August 2015 - 09:14 PM
Hello ovvldc,
XQuartz v.2.7.7 is already what I had and used and I had tried what you mentioned, but it did not work. Nevertheless, I downloaded XQuartz from http://xquartz.macosforge.org/landing/ (your link did not work for me), reinstalled it (it goes automatically to /Applications/Utilities), and:
1. Restarted my computer,
2. Launched Activity Monitor,
3. Checked if there was any process with "wine" in it, there was none,
4. Launched X11 (XQuartz v.2.7.7),
and the rest remained the same as in my post of 24 August 2015 from step 3.
Best regards,
Peter
#6 ovvldc
  • 1,171 posts
Posted 26 August 2015 - 02:01 PM
What do you get out of the report, if you try that?
#7 pdeli
pdeli
  • 9 posts
Posted 26 August 2015 - 03:26 PM
What report are you talking about?
Tell me and I'll try...
#8 ovvldc
  • 1,171 posts
Posted 26 August 2015 - 07:45 PM
The one in step 10 :)
#9 pdeli
pdeli
  • 9 posts
Posted 07 September 2015 - 08:49 PM
Hello ovvldc,
Sorry for taking so much time to answer, but got a bit busy lately.
So, the message I got on the 25 August 2015 at step 10 was the same as in step 10 of 24 August 2015, namely:
"[color=#282828][font=helvetica, arial, sans-serif]The application X11 could not be opened. An error occurred while starting the X11 server: "Failed to activate core devices." with butons Report... Quit appears[/font][/color]"
Today I tried again, and everything is the same. However I am now on El Capitan Version 10.11 Beta (15A278b)...
Hope it helps.
Best regards,
pdeli
#10 ovvldc
  • 1,171 posts
Posted 08 September 2015 - 06:02 AM
So it doesn't matter whether you have Quartz already activated or not? Please remember that you also have to set the wrapper to use the system Xquartz, in the wrapper -> advanced -> options -> force use of system installed Quartz ...
#11 NRG
  • 677 posts
Posted 08 September 2015 - 07:48 AM
boys read here:
http://wineskin.urge...s_parentId=6330
and here: http://wineskin.urge...opics_offset=10
I would try to deactivate El Capitain's rootless feature with this tool: http://1i0ny.de/apps/rootlesstoggler/
Then I could restart Os X and install X11 and Wineskin...
#12 ovvldc
  • 1,171 posts
Posted 08 September 2015 - 04:32 PM
It may make sense for people why have actually dug into this to contact the Quartz developers list (archive is at https://lists.macosf...il/xquartz-dev/) and report it. If the release of El Capitan is fairly imminent (which I assume it is), then we might need an updated XQuartz as well for other apps.
If not, Jeremy Huddleston Sequoia might be able to help diagnose and fix the problem on the Wineskin wrapper side.
#13 pdeli
pdeli
  • 9 posts
Posted 08 September 2015 - 07:09 PM
Exactly, whether I have XQuartz running or not, it's the same thing.
As for your second remark, the issue is that I don't get there. I don't get the chance to create the wrapper...
#14 ovvldc
  • 1,171 posts
Posted 09 September 2015 - 02:21 PM
I'm sorry, I missed it. I guess the idea that NRG is advocating is to throw this switch in the master wrapper, before you make one, and then use that adapted master wrapper to make your own like normal?
#15 kdewolf
kdewolf
  • Graphics Card:AMD Radeon HD 6750M
Posted 11 September 2015 - 10:45 PM
I already tried many different approaches, but I am getting the same error not only when creating wrappers, but also when running existing ones.
Tried (without success):
-Deactivating root (both through terminal and rootless tools)
-Installing xquartz (both from the dmg as well as from homebrew)
-Modifying the plist file from inside the wrapper
This is incredibly annoying to me as I do use wrappers not only for games, but also for work-related software.
Does anyone know if either the X team or Wine team are aware of this?
#16 ovvldc
  • 1,171 posts
Posted 13 September 2015 - 10:39 AM
Feel free to raise the issue on the Quartz developer list.
#17 Archonis
Archonis
  • 13 posts
  • Graphics Card:Geforce 250m
Posted 22 September 2015 - 12:25 AM
I know this topic is a little old but it is still a hot topic. Perhaps someone can guide me in the right direction on what i might be doing wrong as i am getting the same error.
When i try to run a application that i had before i updated to El Capitan it will give me a error failed to activate core device where it ran fine before. I tried to create a new wrapper but wineskin will just hose up.
This is where things get a little interesting. I found a old version of the application that someone did for snow. When i open the package content it had wine 2.2. The wine icon dose not look the same as it does now. It is still red but does not have the glossy look. I can edit this package content all day long. update the program, change out the files and everything runs fine with this version.
I search all over the net for this version to try to use wine tricks and so on because i think some files are missing in this version.
The real question here is why when i download the latest version my program will not run. sometime i will just see a small faint line in the middle of the screen but when i run the old version of the program packaged in an older version on wine it works fine other then small fonts.
Can anyone help guide me on how i can get my application to work on 10.11 X OS as i am not the only one who uses my program on a mac?
The help will be wonderful
#18 Archonis
Archonis
  • 13 posts
Posted 22 September 2015 - 02:19 AM
Ok i did some more searching. The older application used WS7Wine1.3.17 that runs fine on El Cap 10.11 however winery does not like this eng. and it still locks up using the latest version of winery.
Any guidence?
I can use wine bottler to run the app but the file size is way to huge
#19 ovvldc
  • 1,171 posts
Posted 22 September 2015 - 05:50 AM
I think doh123 changed the way that the X server is bundled. Maybe that has something to do with it?
#20 NRG
  • 677 posts
Posted 22 September 2015 - 12:03 PM
have you tried  to install  xquartz 2.7.8 rc1 for el capitain?
http://xquartz.macos...z-2.7.8_rc1.dmg
#21 Archonis
Archonis
  • 13 posts
Posted 22 September 2015 - 09:49 PM
Yes I tried 2.7.8 rc1 without any luck. I think this is the point where winey would not even open to create aa wrapper
#22 Archonis
Archonis
  • 13 posts
Posted 23 September 2015 - 12:50 AM
Just an update, when I reinstall 2.7.7 I can open winery to create a wrapper but I am unable to open the wrapper due to the error. When I installed 2.7.8 winery will not load at all.
#23 Archonis
Archonis
  • 13 posts
Posted 23 September 2015 - 01:09 AM
I was able to get winery open with 2.7.8 however still getting failed to activate core devices when I create a blank wrapper
#24 Archonis
Archonis
  • 13 posts
Posted 23 September 2015 - 02:10 AM
correction when i try to create a wrapper it shuts down, here is the report
rocess:               WineskinX11 [625]
Path:                  /tmp/MyCoolWrapper.app/Contents/MacOS/WineskinX11
Identifier:            MyCoolWrapper531780674Wine.wineskin.prefs
Version:               My Program Version (Wineskin 2.6.0)
Code Type:             X86 (Native)
Parent Process:        ??? [1]
Responsible:           WineskinX11 [625]
User ID:               501
Date/Time:             2015-09-22 22:07:29.451 -0400
OS Version:            Mac OS X 10.11 (15A262e)
Report Version:        11
Anonymous UUID:        B35D767B-8210-94C2-FB43-4DA075C8889C
Sleep/Wake UUID:       E96AF669-0B4B-4F44-B003-F129D7014F03
Time Awake Since Boot: 880 seconds
Time Since Wake:       160 seconds
Crashed Thread:        6
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
X.Org X Server 1.13.0 Build Date: 20120921
abort() called
Thread 0:: Dispatch queue: com.apple.main-thread
0   libobjc.A.dylib                0x95f2dce3 objc_msgSend + 83
1   com.apple.AppKit               0x949be909 -[NSView _layoutSubtreeWithOldSize:] + 752
2   com.apple.AppKit               0x949be909 -[NSView _layoutSubtreeWithOldSize:] + 752
3   com.apple.AppKit               0x949be424 -[NSView layoutSubtreeIfNeeded] + 1219
4   com.apple.AppKit               0x949bde70 _NSViewLayoutSubtreesThatUseAutolayoutIfNeeded + 72
5   com.apple.AppKit               0x949bde00 -[NSWindow(NSConstraintBasedLayout) _layoutViewTree] + 89
6   com.apple.AppKit               0x949ddbd6 -[NSWindow(NSConstraintBasedLayout) layoutIfNeeded] + 249
7   com.apple.AppKit               0x950b974f ___NSWindowGetDisplayCycleObserver_block_invoke6402 + 244
8   com.apple.AppKit               0x94c7ffa2 __37+[NSDisplayCycle currentDisplayCycle]_block_invoke + 617
9   com.apple.QuartzCore           0x9ae1e450 CA::Transaction::run_commit_handlers(CATransactionPhase) + 84
10  com.apple.QuartzCore           0x9ac9ddfe CA::Context::commit_transaction(CA::Transaction*) + 188
11  com.apple.QuartzCore           0x9ac9db7d CA::Transaction::commit() + 597
12  com.apple.QuartzCore           0x9acad499 CA::Transaction::observer_callback(__CFRunLoopObserver*, unsigned long, void*) + 75
13  com.apple.CoreFoundation       0x93ace4de __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 30
14  com.apple.CoreFoundation       0x93ace43e __CFRunLoopDoObservers + 398
15  com.apple.CoreFoundation       0x93abf281 CFRunLoopRunSpecific + 417
16  com.apple.CoreFoundation       0x93abf0cb CFRunLoopRunInMode + 123
17  com.apple.HIToolbox            0x933fa869 RunCurrentEventLoopInMode + 267
18  com.apple.HIToolbox            0x933fa5bf ReceiveNextEventCommon + 503
19  com.apple.HIToolbox            0x933fa3b8 _BlockUntilNextEventMatchingListInModeWithFilter + 99
20  com.apple.AppKit               0x9487d976 _DPSNextEvent + 1037
21  com.apple.AppKit               0x94c8817b -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1057
22  com.apple.AppKit               0x9487d3fe -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 121
23  com.apple.AppKit               0x948725a2 -[NSApplication run] + 1063
24  WineskinX11                    0x00009f82 X11ApplicationMain + 850
25  WineskinX11                    0x00016f75 server_main + 277
26  WineskinX11                    0x00003acb do_start_x11_server + 219
27  WineskinX11                    0x00004385 _Xstart_x11_server + 181
28  WineskinX11                    0x00004141 mach_startup_server + 97
29  libsystem_kernel.dylib         0x91c25deb mach_msg_server + 460
30  WineskinX11                    0x000035da main + 1466
31  WineskinX11                    0x00002b15 start + 53
Thread 1:
0   libsystem_pthread.dylib        0x9e181fbc start_wqthread + 0
Thread 2:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib         0x91c2d8b2 kevent_qos + 10
1   libdispatch.dylib              0x916079c5 _dispatch_mgr_invoke + 234
2   libdispatch.dylib              0x916075ae _dispatch_mgr_thread + 52
Thread 3:
0   libsystem_kernel.dylib         0x91c2ce16 __workq_kernreturn + 10
1   libsystem_pthread.dylib        0x9e18458d _pthread_wqthread + 1289
2   libsystem_pthread.dylib        0x9e181fde start_wqthread + 34
Thread 4:: Dispatch queue: com.wineskin.doh123.X11.NSEventsToX11EventsQueue
0   libsystem_kernel.dylib         0x91c2c4a2 __psynch_cvwait + 10
1   libsystem_pthread.dylib        0x9e184fcb _pthread_cond_wait + 757
2   libsystem_pthread.dylib        0x9e188ce8 pthread_cond_wait$UNIX2003 + 71
3   WineskinX11                    0x00012c12 darwinEvents_lock + 146
4   WineskinX11                    0x0000b645 -[X11Application(Private) sendX11NSEvent:] + 2469
5   WineskinX11                    0x0000864c __-[X11Application sendEvent:]_block_invoke_1 + 44
6   libdispatch.dylib              0x9160693d _dispatch_call_block_and_release + 15
7   libdispatch.dylib              0x91606277 _dispatch_queue_drain + 726
8   libdispatch.dylib              0x91605d63 _dispatch_queue_invoke + 509
9   libdispatch.dylib              0x9161b674 _dispatch_queue_override_invoke_owning + 32
10  libdispatch.dylib              0x916058db _dispatch_root_queue_drain + 1771
11  libdispatch.dylib              0x916051ea _dispatch_worker_thread3 + 97
12  libsystem_pthread.dylib        0x9e18449e _pthread_wqthread + 1050
13  libsystem_pthread.dylib        0x9e181fde start_wqthread + 34
Thread 5:
Thread 6 Crashed:
0   libsystem_kernel.dylib         0x91c2c62a __pthread_kill + 10
1   libsystem_pthread.dylib        0x9e1864a8 pthread_kill + 101
2   libsystem_c.dylib              0x98f948c8 abort + 156
3   WineskinX11                    0x0014dd1b OsAbort + 11
4   WineskinX11                    0x00010fd0 AbortDDX + 32
5   WineskinX11                    0x00154daf AbortServer + 47
6   WineskinX11                    0x00155997 FatalError + 151
7   WineskinX11                    0x000ece22 InitCoreDevices + 162
8   WineskinX11                    0x0002f80b dix_main + 779
9   WineskinX11                    0x000170c2 server_thread + 50
10  libsystem_pthread.dylib        0x9e184a86 _pthread_body + 138
11  libsystem_pthread.dylib        0x9e1849fc _pthread_start + 155
12  libsystem_pthread.dylib        0x9e182002 thread_start + 34
Thread 7:
3   WineskinX11                    0x0002b862 xpbproxy_run + 674
4   WineskinX11                    0x0000a322 xpbproxy_x_thread + 18
5   libsystem_pthread.dylib        0x9e184a86 _pthread_body + 138
6   libsystem_pthread.dylib        0x9e1849fc _pthread_start + 155
7   libsystem_pthread.dylib        0x9e182002 thread_start + 34
Thread 8:: com.apple.NSEventThread
0   libsystem_kernel.dylib         0x91c2607a mach_msg_trap + 10
1   libsystem_kernel.dylib         0x91c25464 mach_msg + 68
2   com.apple.CoreFoundation       0x93ac06b6 __CFRunLoopServiceMachPort + 214
3   com.apple.CoreFoundation       0x93abfac1 __CFRunLoopRun + 1521
4   com.apple.CoreFoundation       0x93abf266 CFRunLoopRunSpecific + 390
5   com.apple.CoreFoundation       0x93abf0cb CFRunLoopRunInMode + 123
6   com.apple.AppKit               0x94943a6e _NSEventThread + 291
7   libsystem_pthread.dylib        0x9e184a86 _pthread_body + 138
8   libsystem_pthread.dylib        0x9e1849fc _pthread_start + 155
9   libsystem_pthread.dylib        0x9e182002 thread_start + 34
Thread 9:
Thread 6 crashed with X86 Thread State (32-bit):
  eax: 0x00000000  ebx: 0x00010fbc  ecx: 0xb031ce0c  edx: 0x00000000
  edi: 0xb031d000  esi: 0x00000006  ebp: 0xb031ce28  esp: 0xb031ce0c
   ss: 0x00000023  efl: 0x00000206  eip: 0x91c2c62a   cs: 0x0000000b
   ds: 0x00000023   es: 0x00000023   fs: 0x00000023   gs: 0x0000000f
  cr2: 0x412ab004
Logical CPU:     0
Error Code:      0x00100170
Trap Number:     132
Binary Images:
    0x1000 -   0x1caff7 +WineskinX11 (???) <B5391F7D-E5C3-DBBD-D344-8464EF44CD23> /tmp/MyCoolWrapper.app/Contents/MacOS/WineskinX11
  0x22f000 -   0x23bff3  libXplugin.1.dylib (45) <6996C3F9-41FB-3049-AACD-A85647013CE2> /usr/lib/libXplugin.1.dylib
  0x246000 -   0x247ff7 +libAppleWM.7.dylib (8) <9172C8B1-E8EC-472D-5D76-1FFC7CE296D6> /tmp/MyCoolWrapper.app/Contents/Frameworks/libAppleWM.7.dylib
  0x24a000 -   0x254ff7 +libXext.6.dylib (11) <74D1177F-A9C0-9812-60B2-E67032F0BB2D> /tmp/MyCoolWrapper.app/Contents/Frameworks/libXext.6.dylib
  0x25a000 -   0x25cff7 +libXfixes.3.dylib (5) <4B16127F-AA2F-7480-E642-3AD644D930FB> /tmp/MyCoolWrapper.app/Contents/Frameworks/libXfixes.3.dylib
  0x25f000 -   0x35ffe7 +libX11.6.dylib (10) <836E2D8E-62DF-F650-AD19-68AEB39BB9F4> /tmp/MyCoolWrapper.app/Contents/Frameworks/libX11.6.dylib
  0x37e000 -   0x38dff7 +libxcb.1.dylib (3) <CD142132-5162-9077-4C58-1771098A05FA> /tmp/MyCoolWrapper.app/Contents/Frameworks/libxcb.1.dylib
  0x39a000 -   0x40bfe7 +libpixman-1.0.dylib (27.2) <A830193A-276F-9096-99E6-BB6D92EDE88F> /tmp/MyCoolWrapper.app/Contents/Frameworks/libpixman-1.0.dylib
  0x41a000 -   0x448fe7 +libXfont.1.dylib (6.1) <2898212B-2022-271E-8790-2D8886557356> /tmp/MyCoolWrapper.app/Contents/Frameworks/libXfont.1.dylib
  0x454000 -   0x4c7fe7 +libfreetype.6.dylib (16) <03D4E397-7C4D-18B4-60B8-5E7A47DE3321> /tmp/MyCoolWrapper.app/Contents/Frameworks/libfreetype.6.dylib
  0x4da000 -   0x4ddff7 +libfontenc.1.dylib (2) <E81568AC-ACA7-79AE-D12B-4216AF49D64C> /tmp/MyCoolWrapper.app/Contents/Frameworks/libfontenc.1.dylib
  0x4e0000 -   0x4f1fe7 +libz.1.2.7.dylib (1.2.7) <E0921AD0-B8F7-05A5-CBC0-685673FFCC07> /tmp/MyCoolWrapper.app/Contents/Frameworks/libz.1.2.7.dylib
  0x4f5000 -   0x4f6ff7 +libXau.6.dylib (7) <99064734-2C2C-389D-BB69-978EDD9D09A0> /tmp/MyCoolWrapper.app/Contents/Frameworks/libXau.6.dylib
  0x4f9000 -   0x4fbff7 +libXdmcp.6.dylib (7) <09592ADE-F8B5-8530-1B90-171E6A925DD0> /tmp/MyCoolWrapper.app/Contents/Frameworks/libXdmcp.6.dylib
  0xffc000 -   0xffcffd +cl_kernels (???) <7D5C2740-EF38-4380-A88A-4EA1B39EEEB3> cl_kernels
0x6000000 -  0x6803ffb  libclh.dylib (4.0.3 - 4.0.3) <1BEDDC0C-F6A4-3B97-BB1E-180718B28A3D> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/libclh.dylib
0x7200000 -  0x7255fff  com.apple.CloudDocs (1.0 - 382) <9E3F773D-C028-335A-B774-ECA42F7C2B19> /System/Library/PrivateFrameworks/CloudDocs.framework/CloudDocs
0x48000000 - 0x488e7ff7  com.apple.GeForceTeslaGLDriver (10.0.37 - 10.0.0) <3BA83539-9D04-3887-8D38-55F138470CD6> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/GeForceTeslaGLDriver
0x8fe71000 - 0x8fea559f  dyld (360.14) <F8F92765-2581-30C2-9A00-958420CDDE83> /usr/lib/dyld
0x90010000 - 0x90011fff  libSystem.B.dylib (1225) <B569FE5C-C2A5-38B1-A991-E8651C4128D6> /usr/lib/libSystem.B.dylib
0x90012000 - 0x90013fff  libDiagnosticMessagesClient.dylib (100) <5F2F9A2C-1A83-3D4E-8F69-1D4FD0515794> /usr/lib/libDiagnosticMessagesClient.dylib
0x90014000 - 0x9008aff3  com.apple.securityfoundation (6.0 - 55126) <8F444A38-0D0F-3CB0-BCE6-61E4B25D4D52> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9008f000 - 0x900a2ff7  libcmph.dylib (6) <7FEE63DB-D02D-3E53-9A0C-2787A49D125C> /usr/lib/libcmph.dylib
0x900a3000 - 0x900a5fff  libquarantine.dylib (80) <19FB1136-AC6E-3F0E-BF5D-E927EABE8BE4> /usr/lib/system/libquarantine.dylib
0x900a6000 - 0x900d7fff  com.apple.CoreServicesInternal (248 - 248) <C192CE55-5BA3-3E86-8C5E-76427F8F883B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x900d8000 - 0x900f6ffb  libresolv.9.dylib (60) <5AF8F512-BACE-3BD7-8D21-E0AAEBF07FF9> /usr/lib/libresolv.9.dylib
0x900f7000 - 0x90110fff  com.apple.Kerberos (3.0 - 1) <D196B4D5-6FD7-3F5D-AA8F-6B2D3DC7F993> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x90111000 - 0x903caff7  com.apple.CoreData (120 - 638) <6E650658-4DB3-30B3-8420-F21A925CA1AE> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x903cb000 - 0x903cbfff  libkeymgr.dylib (28) <305656A1-3735-3AE9-BC3A-B5B2C01F8A50> /usr/lib/system/libkeymgr.dylib
0x903cc000 - 0x90425ff3  com.apple.AE (701 - 701) <24BF087A-9291-378A-BDD2-8B1A3E217304> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x90426000 - 0x9043ffff  libsystem_malloc.dylib (67) <9789B60B-620D-3957-9118-BC9C18CDD89E> /usr/lib/system/libsystem_malloc.dylib
0x90440000 - 0x90444fff  libcache.dylib (75) <ADF7019D-9788-3945-8CDE-B3D06F170833> /usr/lib/system/libcache.dylib
0x90445000 - 0x90473fff  libarchive.2.dylib (32) <28F3BC9E-E796-35A8-80D7-237717CC821C> /usr/lib/libarchive.2.dylib
0x90474000 - 0x904cbff7  com.apple.HIServices (1.22 - 548) <0E87EA40-143E-30A6-8F8B-8354A19A6789> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x904d8000 - 0x90a06fdf  com.apple.vImage (8.0 - 8.0) <08F89CDB-16B9-39F6-92FD-3B420C17280A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x90a07000 - 0x90a63ff7  libTIFF.dylib (1432) <5865794A-7B37-3F4F-A0A6-BBFB1E5ABE65> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x90a64000 - 0x90a6dfff  libsystem_networkextension.dylib (384.1.1) <F614FD62-9C56-35D5-85D0-BB6D81F44B8D> /usr/lib/system/libsystem_networkextension.dylib
0x90a6e000 - 0x90a76fff  com.apple.NetFS (6.0 - 4.0) <C21D842D-9A6B-3803-A3FA-85B5813F8E72> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x90a77000 - 0x90b66ff7  libcrypto.0.9.8.dylib (59) <972B860F-D720-34BB-A52D-2D76B90C7C7E> /usr/lib/libcrypto.0.9.8.dylib
0x90b67000 - 0x90bdcfff  com.apple.SearchKit (1.4.0 - 1.4.0) <5E6F1539-A8EE-3C65-8E50-DA99F1D4FEF2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x90bdd000 - 0x90cceff3  libiconv.2.dylib (44) <4EB465C8-E736-3DBD-9F62-74B73B66A84B> /usr/lib/libiconv.2.dylib
0x90ccf000 - 0x90cf7ffb  libxpc.dylib (755.1.19) <F1515399-119F-3021-A100-498E46E7069D> /usr/lib/system/libxpc.dylib
0x90cf8000 - 0x90cf8fff  com.apple.Carbon (154 - 157) <0007A83A-939F-30D4-9F95-38FBB0D0EE96> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x90cf9000 - 0x90cf9fff  libOpenScriptingUtil.dylib (169) <FF16B3EE-C00D-3AEB-87CB-B56808C96E64> /usr/lib/libOpenScriptingUtil.dylib
0x90cfa000 - 0x90d07ff7  libbz2.1.0.dylib (38) <5AF36C82-D418-3B72-9358-4890779B6DC9> /usr/lib/libbz2.1.0.dylib
0x91463000 - 0x914b2fff  libcurl.4.dylib (90) <DD766B11-DAC0-3E32-9E45-9DB8AA90FBCC> /usr/lib/libcurl.4.dylib
0x914b3000 - 0x914dcff7  libsystem_info.dylib (476) <397AC10A-2044-3727-A57D-D43CCA778959> /usr/lib/system/libsystem_info.dylib
0x91551000 - 0x91557fff  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <82746987-77BD-3BA5-896E-011D0D8A5F77> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x91558000 - 0x9156efe7  libcompression.dylib (23) <08202377-BEBC-370C-9D16-45AD4CE79EF8> /usr/lib/libcompression.dylib
0x9156f000 - 0x915c3fff  com.apple.Symbolication (1.4 - 58044) <BC5ECFA6-1C8A-3EFC-971F-E89358F3D2AF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x915e7000 - 0x915e9fff  libCVMSPluginSupport.dylib (12.0.34.11) <33B8F776-E5AF-3120-BCB1-FDBBAFC71661> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x915ea000 - 0x915f3ff3  com.apple.AppleSRP (5.0 - 1) <7172A3C4-2982-3F1F-B7AA-B244BAF852C7> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x915f7000 - 0x91600fff  com.apple.icloud.FindMyDevice (1.0 - 1) <03DFF297-4A96-398D-AAAF-7639DA1D1599> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x91601000 - 0x9162bfff  libdispatch.dylib (500.1.5) <ACF981EF-D75D-3DBB-B280-CA1C0E2955DF> /usr/lib/system/libdispatch.dylib
0x91c12000 - 0x91c32fff  libsystem_kernel.dylib (3247.1.99) <5A919C02-0C46-3C0D-B2CC-E5C44CCFEA57> /usr/lib/system/libsystem_kernel.dylib
0x91c33000 - 0x91c41ff7  libz.1.dylib (60) <55750BAB-975A-3FDE-A177-6DCD7A5CEA62> /usr/lib/libz.1.dylib
0x91c42000 - 0x91ed7ff3  com.apple.security (7.0 - 57336.1.8) <7533BCB5-6B9D-35E1-A492-DBE2F5EA0D3E> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x92358000 - 0x9236dff3  libCGInterfaces.dylib (317.2) <F97A8396-002F-3617-A39E-5B4609D672F4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x9242b000 - 0x924bcfff  com.apple.CoreSymbolication (3.1 - 58048.1) <5C9B6DAC-6B5E-34F3-86DE-925527D24467> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x924bd000 - 0x924bdfff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <593EB262-84D5-39A4-AC4A-C228F0C0E4DE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x924be000 - 0x924d2ff7  com.apple.CoreBluetooth (1.0 - 1) <D67C0359-3AE0-3ADA-B58C-DF28C814C7CD> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x924d3000 - 0x92549ffb  com.apple.ApplicationServices.ATS (377 - 393.1) <14D18EF0-EFE8-384A-9F04-0883BB7C5D92> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9254d000 - 0x92556fff  libcopyfile.dylib (127) <981BBBEC-07FD-3FF8-86E7-C4548DE5A54F> /usr/lib/system/libcopyfile.dylib
0x92557000 - 0x92588fff  com.apple.DictionaryServices (1.2 - 250) <838D2BC2-5CEA-3C7C-BBCD-BA41F7995AA7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x92589000 - 0x925b7ff7  GLRendererFloat (12.0.34.11) <DF3EB90A-76DB-303F-9D41-AC24DC584ED6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x925b8000 - 0x925dbff3  libc++abi.dylib (125) <20843323-D228-3A86-9F23-8FDC64B40211> /usr/lib/libc++abi.dylib
0x925df000 - 0x92609fff  libxslt.1.dylib (14) <FA8FB489-8448-365C-8B8B-7BF068C5C550> /usr/lib/libxslt.1.dylib
0x9260a000 - 0x92644fff  com.apple.MediaKit (16 - 804) <5407AC1F-FFB2-33C3-8686-2803441FE583> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x926b9000 - 0x92714fff  com.apple.print.framework.PrintCore (11.0 - 472) <4B94CE43-2385-34FF-8169-199F6D46A646> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x92715000 - 0x92726fff  com.apple.ProtocolBuffer (1 - 242) <6CE68C18-2865-3F1D-9186-CE44EF70E798> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x928eb000 - 0x928eefff  com.apple.xpc.ServiceManagement (1.0 - 1) <934D3BE4-446A-37B2-A706-379F917A5D92> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x92c13000 - 0x92fedff7  libLAPACK.dylib (1159) <57C95946-6C2D-33D5-948B-1E2CA58F6BD0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92fee000 - 0x930deffb  com.apple.DiskImagesFramework (10.11 - 414) <A5AACE43-C51E-36D3-8525-14992AD74FA2> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x930df000 - 0x930e3ffb  com.apple.IOSurface (108 - 108) <410D0DBB-CAF3-3FF8-B6DF-1E8EDBBC1766> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x930e4000 - 0x931e3fff  libFontParser.dylib (157) <E11000CA-2EDD-3837-8E91-3488E9A08A86> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x931e4000 - 0x93238ffb  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <95FBE70D-5625-3FFB-810F-4829459BBC53> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x93256000 - 0x932fafff  libCoreStorage.dylib (516) <ECC79A4C-CD21-3C26-9A5E-72FB15099AAE> /usr/lib/libCoreStorage.dylib
0x93303000 - 0x93369ff3  libsystem_network.dylib (582.1.3) <BAF4777D-A082-353B-8EF1-CF63730130D6> /usr/lib/system/libsystem_network.dylib
0x93377000 - 0x9337cfff  com.apple.TCC (1.0 - 1) <A5E5B48A-168D-32F9-9061-7DB1E1363F12> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x9337d000 - 0x933ccfff  com.apple.opencl (2.6.9 - 2.6.9) <01C068DA-9FE9-34D8-AF56-4E4220451783> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x933cd000 - 0x93794ff7  com.apple.HIToolbox (2.1.1 - 803) <5A78F0FC-9DA0-3C78-9EEF-DE249679BF8E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93795000 - 0x9379bfff  libunwind.dylib (35.3) <188FCCF5-9470-3CFB-B289-BFF330848C68> /usr/lib/system/libunwind.dylib
0x9379c000 - 0x9384eff3  com.apple.Bluetooth (4.4.0 - 4.4.0f3) <ACC73D3C-CD89-3498-A03A-0209E05F87ED> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x938b4000 - 0x938dcff7  com.apple.IconServices (68 - 68) <2FEC3CEB-EDB4-34D8-AA05-E1A4491C12B2> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x938dd000 - 0x938eefff  libsystem_trace.dylib (200) <CBE5BE48-2DA9-3C5B-BDEE-B903EF909C32> /usr/lib/system/libsystem_trace.dylib
0x938ef000 - 0x93a48ff7  libBLAS.dylib (1159) <01B7578D-121A-3F03-8BC1-D40E929820BC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x93a49000 - 0x93edbff7  com.apple.CoreFoundation (6.9 - 1253) <35B9583B-147C-339F-9D9A-E4E3A636F084> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93edc000 - 0x940fdfff  com.apple.CoreImage (11.0.0 - 356) <6C6E66A3-A89B-3729-850E-AF8ACFB47683> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x940fe000 - 0x9413fff7  libauto.dylib (186) <3729B54F-12F2-3802-A465-72F441AAD99E> /usr/lib/libauto.dylib
0x94140000 - 0x941faff7  com.apple.backup.framework (1.7 - 1.7) <42C069D2-73CC-3249-816F-B42ADB8D0E84> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x941fb000 - 0x9421ffff  com.apple.MultitouchSupport.framework (304.2 - 304.2) <1EAD6619-0986-3871-A44C-28A795A01987> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x94220000 - 0x9422bff3  libcommonCrypto.dylib (60074) <7FF354A2-CD67-3FDB-9BF8-4844A34E6DBF> /usr/lib/system/libcommonCrypto.dylib
0x94321000 - 0x9432bfff  libsystem_notify.dylib (149) <B3F1D5BC-1DC6-3BAC-8954-81A9909C4D53> /usr/lib/system/libsystem_notify.dylib
0x9432c000 - 0x94342ff3  libLinearAlgebra.dylib (1159) <1E89B7DB-1E02-30C9-AE4A-53F5007DF425> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x94343000 - 0x94362fff  com.apple.GenerationalStorage (2.0 - 239) <860B9266-98AD-3A2F-8B98-BBAD29DAF9AA> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x94363000 - 0x943b8ff7  com.apple.htmlrendering (77 - 1.1.4) <C5618E29-AE4D-3B7B-AE40-32C4723D5EC2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x943b9000 - 0x94482fff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <1D4B19C7-4D48-397A-ADD1-3FA87A85ADA9> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x94483000 - 0x94626ff7  libGLProgrammability.dylib (12.0.34.11) <AD563313-D37B-3D0D-92BF-8DE8C4A3F8E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x94627000 - 0x9462affb  libutil.dylib (43) <E000BCEA-F9BF-38AB-B7B3-B75E95B824BA> /usr/lib/libutil.dylib
0x94721000 - 0x9472eff7  com.apple.speech.synthesis.framework (5.4.11 - 5.4.11) <AC1BDEB8-337C-303B-97CB-536A34940254> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x947ea000 - 0x954c2ffb  com.apple.AppKit (6.9 - 1397) <FFBF415B-FC23-32E5-A2EB-DE5C9ABF2405> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x954c3000 - 0x954d6ff7  libsasl2.2.dylib (209) <438656AF-F6C9-3B2F-99F4-02C7DEA733BC> /usr/lib/libsasl2.2.dylib
0x95ddc000 - 0x95ddeffb  libsystem_secinit.dylib (20) <51ECC67E-23BC-310C-828E-0EDFD87895BB> /usr/lib/system/libsystem_secinit.dylib
0x95e53000 - 0x95e5cfff  com.apple.DiskArbitration (2.7 - 2.7) <AB013752-9050-355D-A615-D629C60C2C43> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x95ece000 - 0x95edbfff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <51F1211F-E879-3BB8-80DA-9B127D8D107D> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x95edc000 - 0x95edcfff  com.apple.Accelerate (1.10 - Accelerate 1.10) <BF4B9FE7-9F5D-3C2D-9AFE-57D6694DFC48> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x95edd000 - 0x95f1cffb  libGLImage.dylib (12.0.34.11) <4846A97F-12F3-3F84-A1F1-676C27E05090> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x95f1d000 - 0x95f25fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <0B16B000-0574-3815-875F-501622412FC9> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x95f26000 - 0x95f28ffb  libCGXType.A.dylib (930) <CFD5BD62-8A99-348D-8B50-3924EA57E043> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x95f29000 - 0x962841eb  libobjc.A.dylib (680) <9B9B39CC-CC3A-3E91-AAE7-961E8A6E1804> /usr/lib/libobjc.A.dylib
0x96285000 - 0x96326fff  com.apple.ink.framework (10.9 - 214) <A2A9CC46-7C05-3654-9B66-40D3304D8460> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x96369000 - 0x9636bffb  libRadiance.dylib (1432) <D05BDA8F-2D0E-3F55-894C-C1FF1446959E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9639c000 - 0x9639efff  com.apple.loginsupport (1.0 - 1) <A751FF72-B543-3216-A810-66921DDA0023> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x9639f000 - 0x96412ffb  com.apple.datadetectorscore (7.0 - 460) <70EBF31F-BCE5-34CF-9122-B8E8F08B5029> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x96413000 - 0x9642cfff  libsystem_asl.dylib (322) <BE4B3C13-A3A1-3D62-81B6-FE942D835176> /usr/lib/system/libsystem_asl.dylib
0x9642d000 - 0x9642efff  libremovefile.dylib (41) <5A58C008-A49E-328A-B40B-19C4AA1C14B4> /usr/lib/system/libremovefile.dylib
0x9642f000 - 0x9643afff  com.apple.NetAuth (6.0 - 6.0) <9708D03A-FFE8-3FF0-8771-F149D02E0451> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x9643b000 - 0x9647efff  libGLU.dylib (12.0.34.11) <B9362C4F-D7F0-3014-82DF-83087B61018B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9647f000 - 0x96877fff  com.apple.CoreGraphics (1.600.0 - 930) <CBA2B474-7C39-3D6C-AF70-CD624D7D0108> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x96878000 - 0x9696cff7  libxml2.2.dylib (29) <816B81CF-4F87-3434-92ED-AA6A4284CDFC> /usr/lib/libxml2.2.dylib
0x96a83000 - 0x96d12ff3  com.apple.CFNetwork (760.0.3 - 760.0.3) <51E12B1D-D55A-3B31-A206-BF1CA93AE718> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x97012000 - 0x97084ffb  com.apple.framework.CoreWLAN (11.0 - 1100.19) <3C4303DC-57FD-37CA-ADD7-3D9F62F1EEB6> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x97085000 - 0x970c4fff  com.apple.NavigationServices (3.8 - 220) <F35450FB-1AA8-31D8-98AE-AD8DB8769250> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x970c5000 - 0x97165ffb  com.apple.QD (3.12 - 302) <EF1C7DAC-994C-3062-BACB-4A0D0F0B3906> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x97522000 - 0x976f5ff7  com.apple.ImageIO.framework (3.3.0 - 1432) <BCEB3B62-95EA-368A-B963-886DFDEF93C2> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x976f6000 - 0x976fefff  com.apple.CoreServices.FSEvents (1222 - 1222) <EF7427C6-FB23-30FF-A504-54AFAB71787D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x97788000 - 0x9778bfff  libScreenReader.dylib (425.1) <54DA189E-A5C3-3606-A0B8-06AE7751BF69> /usr/lib/libScreenReader.dylib
0x9778c000 - 0x977a4ff7  libSparseBLAS.dylib (1159) <3ABF944C-4483-349C-A3C6-36B4CE2549E2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x978c0000 - 0x97af9ff7  libFosl_dynamic.dylib (16.24) <A922DC79-6596-3CF0-91D7-7A2A384985D1> /usr/lib/libFosl_dynamic.dylib
0x97afa000 - 0x97affff3  com.apple.print.framework.Print (10.0 - 266) <E83BA38D-23FE-3D26-97DC-324FF82A1ED2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x97b00000 - 0x97b03fff  libextension.dylib (78) <CE6ACBCF-6F13-31D7-93BA-3FC71508D633> /usr/lib/libextension.dylib
0x97b05000 - 0x97c09fff  libJP2.dylib (1432) <9E0A69E0-F519-3720-AE37-4650FA9EC752> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x97c0a000 - 0x97c0afff  com.apple.CoreServices (728.2 - 728.2) <2FD4108D-2959-3D8F-A376-F7553E0CA8B2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x97c0b000 - 0x97eb6ff3  com.apple.RawCamera.bundle (6.16 - 817) <AB2DDD62-48EE-3338-8932-3ACDAF87EF29> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x97eb7000 - 0x97ec7ff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <0A50905C-A1B8-3B0C-AFF5-CA50EA87664C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x97ec8000 - 0x98169ff7  libmecabra.dylib (696) <A4FF0C1C-3C44-302D-84AA-20268A41DED3> /usr/lib/libmecabra.dylib
0x98173000 - 0x9821afff  com.apple.Metadata (10.7.0 - 969) <7E689098-B94D-3D5E-8CE3-E265FDEF0568> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9821b000 - 0x98235ff7  liblzma.5.dylib (10) <7DDBF3FF-5EDC-31EA-8A2C-70C6BC754953> /usr/lib/liblzma.5.dylib
0x9823f000 - 0x98282ff7  com.apple.Metal (54.26.3 - 54.26.3) <3E710B25-6560-3C35-8A1D-A18941ED1464> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x98283000 - 0x9828bfff  libcldcpuengine.dylib (2.6.4.1) <EDCF4CC5-923B-3CA7-B1A4-57B26D2F1EEA> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x9828c000 - 0x982c9ff7  com.apple.DebugSymbols (132 - 132) <CA92EA23-26E7-3483-B23C-84A163C7A318> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x982ca000 - 0x983efff3  com.apple.CoreText (352.0 - 494) <4FAF50E4-2E8E-3710-B13D-37A72361674C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x983f0000 - 0x984eeff7  com.apple.LaunchServices (728.2 - 728.2) <F69DA3E6-83DA-37B4-B86E-F4F5EA8AF435> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x984ef000 - 0x98538ff7  com.apple.coreservices.SharedFileList (24.2 - 24.2) <7D8D6B0F-19D8-3919-B604-5A476164414D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x9853d000 - 0x9853dfff  libenergytrace.dylib (10) <27AA60B3-B948-378B-8BC4-F26C9BCFE8AA> /usr/lib/libenergytrace.dylib
0x9853e000 - 0x98543ff7  libmacho.dylib (875.1) <CC433AC0-F1BE-30F1-8959-BB1945D2097B> /usr/lib/system/libmacho.dylib
0x98552000 - 0x9855dff7  libGPUSupport.dylib (12.0.34.11) <AE348971-5FFE-37C1-8B0F-E42C8099D978> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x985ea000 - 0x98601ff7  libmarisa.dylib (4) <C6E63A3C-4E81-34F1-BEC4-47120C8ACD2B> /usr/lib/libmarisa.dylib
0x98602000 - 0x9860dff7  libChineseTokenizer.dylib (16) <53CE582D-A859-35CA-B90D-B9ADFCC09208> /usr/lib/libChineseTokenizer.dylib
0x98616000 - 0x98619ff7  com.apple.help (1.3.3 - 46) <CB9DA60C-FF93-3708-A3A6-E9D4EBFC42EF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9861a000 - 0x9861afff  libmetal_timestamp.dylib (600.0.41.2) <93E4F1B9-A792-31E9-B6BF-150D1418A282> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x986a8000 - 0x986b1fff  libGFXShared.dylib (12.0.34.11) <E51279E8-5F92-3D1B-8483-6525C1880355> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x986b2000 - 0x98708ff7  libc++.1.dylib (120.1) <59501F15-E2C0-30D2-9B8C-7E784D47900E> /usr/lib/libc++.1.dylib
0x98709000 - 0x9870bfff  libsystem_configuration.dylib (801.1.1) <225943FE-BC20-31B6-9276-E106F202349D> /usr/lib/system/libsystem_configuration.dylib
0x9870c000 - 0x9876ffff  com.apple.SystemConfiguration (1.14 - 1.14) <591B1F4E-82E0-35F4-AF88-74D916659CC0> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x987a9000 - 0x987cfffb  libPng.dylib (1432) <8A0C3FE3-50D5-3407-A92C-DA9210D6D25C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x987d0000 - 0x98c02ffb  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <8A11CE47-5B1A-3DCB-8CE1-22C9ECA52B92> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x98c03000 - 0x98c4bff7  libFontRegistry.dylib (155) <7549537F-A296-386B-B031-D7B3BA8702B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x98c4c000 - 0x98c61ffb  libsystem_coretls.dylib (82) <F9628B67-1B54-3EA0-A31B-52C8D944D41F> /usr/lib/system/libsystem_coretls.dylib
0x98c62000 - 0x98e12ffb  GLEngine (12.0.34.11) <2745D4EF-1D81-32DA-A6CD-68B74013004F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x98e13000 - 0x98efefeb  libvMisc.dylib (563.2) <95534AF5-441D-306B-A58C-AF1EE410B6D1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x98eff000 - 0x98f35ff7  com.apple.CoreVideo (1.8 - 191.0) <CC9022C6-5BCB-33DC-AB95-D08F2AD9C549> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x98f36000 - 0x98fcbfff  libsystem_c.dylib (1081.1.3) <F32E6A37-6160-3D0B-8B39-BE9CB832D0E0> /usr/lib/system/libsystem_c.dylib
0x98fcc000 - 0x9904aff3  com.apple.framework.IOKit (2.0.2 - 1178.1.2) <0AD9BDC7-CCD3-309F-A04B-98906C0A6DC9> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x9904b000 - 0x99085fff  com.apple.LDAPFramework (2.4.28 - 194.5) <3518C5EF-4378-3D68-8D4D-4DD9B67E3B91> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x9908e000 - 0x991dbfe7  com.apple.coreui (2.1 - 362) <3658C9CB-2CC3-3645-930C-64C461C07585> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x991dc000 - 0x992c7ff7  unorm8_bgra.dylib (2.6.4.1) <D08C2F6D-B90A-3CB9-A5DB-E7CDA0DB7323> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x99cbc000 - 0x99cc2fff  com.apple.ImageCapture (9.0 - 9.0) <73C59076-191B-34E2-B6A1-2916E19500B6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x99ced000 - 0x99cf9fff  com.apple.CrashReporterSupport (10.11 - 714) <38E7556B-7A17-30FA-9FF6-A9BC7E129396> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x99e36000 - 0x99e36fff  liblaunch.dylib (755.1.19) <71C84BDA-1A06-3818-97E8-82DF0216E21E> /usr/lib/system/liblaunch.dylib
0x99e37000 - 0x99f79fef  libvDSP.dylib (563.2) <5EA7436A-D27B-385B-9381-C9016EC2B358> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x99f7a000 - 0x99f7afff  com.apple.Cocoa (6.11 - 22) <CC20D6B2-6113-3DB2-9B03-770CE5173ABF> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x99f7b000 - 0x9a2feffb  com.apple.Foundation (6.9 - 1252) <5F8DD82A-9DB2-354F-AA1D-4F6345B93BC8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9a2ff000 - 0x9a2fffff  com.apple.ApplicationServices (48 - 48) <01C91ABE-83DA-35B6-9AE9-2DCA9301529F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9a300000 - 0x9a301fff  com.apple.TrustEvaluationAgent (2.0 - 25) <7B6357BA-B41D-34A8-84D1-B30071C3FC34> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9a310000 - 0x9a333fff  libJPEG.dylib (1432) <CE9B3A56-BEDD-377B-B649-E65B834BEB0C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9a334000 - 0x9a45aff7  libsqlite3.dylib (216) <957ADA90-5587-3DA1-AE29-8AEF09E99985> /usr/lib/libsqlite3.dylib
0x9a45b000 - 0x9a541ff7  unorm8_rgba.dylib (2.6.4.1) <6F7DA8A5-7DD1-3507-BB74-CF3A812ED59D> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
0x9a542000 - 0x9a565ffb  com.apple.framework.Apple80211 (11.0 - 1101.30) <A5D94E34-6333-3AA9-BC77-4A82AFD78341> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x9a566000 - 0x9a568ff3  com.apple.EFILogin (2.0 - 2) <6E03ADA9-7624-3E59-B1E5-82D786410DD3> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x9a56a000 - 0x9a587ff7  libCRFSuite.dylib (34) <5872C4CE-812E-3ABC-B78A-216A9AFD386B> /usr/lib/libCRFSuite.dylib
0x9a588000 - 0x9a5f3ff7  com.apple.framework.CoreWiFi (11.0 - 1100.19) <A3365A39-3576-3C56-9255-0FECC1CBEF2E> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x9a5f4000 - 0x9a65bfff  libcorecrypto.dylib (334) <7AC06733-9133-3992-849F-E6BEF0D87DAA> /usr/lib/system/libcorecrypto.dylib
0x9a65c000 - 0x9a661ffb  libcompiler_rt.dylib (62) <0AAF03E5-B1C4-3701-BB1E-F9A372E3A645> /usr/lib/system/libcompiler_rt.dylib
0x9a662000 - 0x9a671ff7  libxar.1.dylib (302) <B5FC05C6-3E06-3E92-A8E5-C7733D659F6F> /usr/lib/libxar.1.dylib
0x9a868000 - 0x9a86bfff  libCoreFSCache.dylib (119.5) <C7A81CB4-E1A2-3DA6-A128-7C5F8127F661> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x9a86c000 - 0x9aa8affb  libicucore.A.dylib (551.23) <73272E4D-EDA1-3608-811D-ACA2642E1267> /usr/lib/libicucore.A.dylib
0x9aa8e000 - 0x9aa98ffb  com.apple.audio.SoundManager (4.2 - 4.2) <7465DC35-F85B-39AC-8CDA-07030F55CB0D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9aa99000 - 0x9abb2fff  com.apple.desktopservices (1.10 - 1.10) <38F92BB7-EECD-307D-9858-D082F91B54FB> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9abb3000 - 0x9ac51ff7  com.apple.ColorSync (4.9.0 - 4.9.0) <37403766-B22F-3FB9-9A79-2DA9A8DFD84A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9ac52000 - 0x9ac5ffff  com.apple.OpenDirectory (10.11 - 194) <18F059BA-3E74-3E80-BDEC-FE6BEEE12929> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9ac60000 - 0x9ac82fff  com.apple.ProtectedCloudStorage (1.0 - 1) <AD31F5B1-0497-35A4-9B5A-20A67D04283F> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x9ac83000 - 0x9ac8fff7  libkxld.dylib (3247.1.99) <E31533D1-8B24-3D58-8CF8-4895AB790B44> /usr/lib/system/libkxld.dylib
0x9ac90000 - 0x9ae71fff  com.apple.QuartzCore (1.11 - 410.7) <9D1EED37-B841-30F6-9BF4-9EEE66FC89F5> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9ae72000 - 0x9ae72fff  libunc.dylib (29) <48A7C815-E3D4-35B6-94AF-588C58AA8E32> /usr/lib/system/libunc.dylib
0x9ae73000 - 0x9aeedff7  com.apple.Heimdal (4.0 - 2.0) <5E0A95FE-EBC3-3E90-B3BB-315A8808C7EE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x9aeee000 - 0x9aeeffff  liblangid.dylib (122) <3432A383-168D-3522-8B32-BEABE733FC8F> /usr/lib/liblangid.dylib
0x9aef0000 - 0x9aef4fff  com.apple.CommonPanels (1.2.6 - 96) <CEE235FD-EC7A-3C64-8548-AD18A61FF277> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x9aef5000 - 0x9af11ff7  com.apple.openscripting (1.7 - 169) <A4F14809-DE14-35DD-8F15-B41454417F1B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9af12000 - 0x9af1bffb  com.apple.CommonAuth (4.0 - 2.0) <D270762B-4BFC-386B-A62B-A7229FD41859> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9af1c000 - 0x9afc7ff7  com.apple.LanguageModeling (1.0 - 1) <2B584B92-FE86-3DBB-9355-7EEE5AB9752C> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x9afc8000 - 0x9afceff3  libsystem_platform.dylib (73.1.1) <133CCA9F-22C9-3AD1-9298-8E0E53317388> /usr/lib/system/libsystem_platform.dylib
0x9afcf000 - 0x9b002ffb  com.apple.GSS (4.0 - 2.0) <8BCFF342-7177-3DAC-8423-BE8F4C50C538> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9b037000 - 0x9b03afff  libpam.2.dylib (20) <A5D72430-8F29-3E9A-AE11-087ED0CB7506> /usr/lib/libpam.2.dylib
0x9b042000 - 0x9b046fff  libheimdal-asn1.dylib (452.1.1) <28C1A4BC-E76A-358A-85FD-A45F85ED5861> /usr/lib/libheimdal-asn1.dylib
0x9b047000 - 0x9b1ccffb  com.apple.UIFoundation (1.0 - 433) <6A8FB88F-673A-3AFF-B12F-8650D567488C> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x9b1cd000 - 0x9b346ff3  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <1F137920-B0CB-3994-9F59-1277D895D22D> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9b347000 - 0x9b34aff7  libdyld.dylib (360.14) <019751F5-82F6-38E9-BA92-BB0C251BBCBE> /usr/lib/system/libdyld.dylib
0x9b34b000 - 0x9b351fff  com.apple.IOAccelerator (203.7.1 - 203.7.1) <2D21FBCF-536F-32E5-B1A4-E4D99FF89404> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x9c42b000 - 0x9c42dfff  libsystem_coreservices.dylib (19) <9E3AE197-EC29-3B12-A439-C863DC31B648> /usr/lib/system/libsystem_coreservices.dylib
0x9c741000 - 0x9c741fff  libsystem_blocks.dylib (65) <044CF869-766A-3B8C-853B-D840F7E768D1> /usr/lib/system/libsystem_blocks.dylib
0x9c742000 - 0x9c744fff  com.apple.securityhi (9.0 - 55006) <7F02E969-0849-3CC8-8062-454466ECC2E0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9c779000 - 0x9c77cfff  libsystem_sandbox.dylib (459.1.7) <B12A2E5C-BDC3-3F7C-A82E-81C60F31317F> /usr/lib/system/libsystem_sandbox.dylib
0x9cd9e000 - 0x9cdb1ff7  com.apple.Sharing (438 - 438) <2F9AA11A-F593-31DF-BD0F-42642C281C95> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x9d764000 - 0x9d76cffb  libsystem_dnssd.dylib (624.1.2) <A1CFD40D-9FA4-3492-9194-A471654B857E> /usr/lib/system/libsystem_dnssd.dylib
0x9d819000 - 0x9d842fff  libRIP.A.dylib (930) <FED4CBC0-404C-34EC-8345-4E29484935F0> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9d843000 - 0x9d8a6fff  com.apple.CoreServices.OSServices (728.2 - 728.2) <206AEBF7-11A9-38C8-ADF9-B5F01793BF31> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9db26000 - 0x9db29fff  libCoreVMClient.dylib (119.5) <E9A4449C-D6D4-36C8-89DA-8BE58CAA7DC7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9db2a000 - 0x9db3bfff  libbsm.0.dylib (34) <FA298D27-CA59-3106-A3F7-33F91576FA13> /usr/lib/libbsm.0.dylib
0x9db3c000 - 0x9db4aff3  com.apple.opengl (12.0.34 - 12.0.34) <212C65A9-7898-3BE9-B099-A406F18B5FEC> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9dd72000 - 0x9dd76ffb  libGIF.dylib (1432) <CA7BA0A5-8E38-3026-A2D2-D7132ADB59A7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9dd77000 - 0x9dd77fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <9255821D-D839-3C5D-8375-96C5FBF4BC79> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9dd78000 - 0x9dd88fff  libGL.dylib (12.0.34.11) <58C515D1-95DD-35EF-ADF2-9F9A528FEB3F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9dd89000 - 0x9ddbcfe3  libsystem_m.dylib (3105) <C5F73B27-C7AB-3A23-8C5E-9C456691829F> /usr/lib/system/libsystem_m.dylib
0x9ddbd000 - 0x9ddd8fff  com.apple.CFOpenDirectory (10.11 - 194) <F6C91DC2-7E14-365F-B969-571D2423ACD1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x9ddd9000 - 0x9dde5ff7  libcsfde.dylib (516) <92F1E8E7-8F3D-3DE5-934D-CD88967B565C> /usr/lib/libcsfde.dylib
0x9de85000 - 0x9e180fff  com.apple.CoreServices.CarbonCore (1136 - 1136) <0CA121E5-B715-3EA7-94E9-CE6AFDD288CC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9e181000 - 0x9e189ffb  libsystem_pthread.dylib (137) <54000954-040D-3C99-9970-30E4BCBF2C8F> /usr/lib/system/libsystem_pthread.dylib
0x9e18a000 - 0x9e1cafff  com.apple.AppleJPEG (1.0 - 1) <10DD3C21-1466-3C3D-B110-9EC9087F6974> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x9e2d0000 - 0x9e364ff3  com.apple.PerformanceAnalysis (1.0 - 1) <3069FBCD-CCBE-3E57-A4C0-479F000424C9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x9e3c6000 - 0x9e41cfff  libcups.2.dylib (435) <8674B4B6-DF43-30F0-A828-7EF6DCEFA9F9> /usr/lib/libcups.2.dylib
0x9e41d000 - 0x9e459fff  com.apple.RemoteViewServices (2.0 - 99) <CC16CEF2-19F1-35E6-86E2-CF19DA8B9249> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 13
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 5102
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=194.5M resident=0K(0%) swapped_out_or_unallocated=194.5M(100%)
Writable regions: Total=70.8M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=70.8M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate.framework               128K        2
Activity Tracing                  2048K        2
CG backing stores                  488K        4
CG image                            12K        4
CG shared images                   240K        7
CoreAnimation                       44K        4
CoreUI image data                  608K        7
CoreUI image file                  192K        4
Foundation                          16K        2
Image IO                            64K        2
Kernel Alloc Once                    4K        2
MALLOC                            36.9M       31
MALLOC guard page                   48K       10
Mach message                         8K        3
Memory Tag 242                      12K        2
OpenCL                               8K        2
Process Corpse Info               2048K        2
Stack                             12.1M       12
Stack Guard                       56.0M       11
VM_ALLOCATE                        120K       13
__DATA                            21.7M      227
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                        50.6M       21
__OBJC                            2480K       62
__TEXT                           143.9M      233
__UNICODE                          552K        2
mapped file                      181.0M      136
shared memory                     16.3M        9
TOTAL                            530.5M      791
Model: Macmini4,1, BootROM MM41.0042.B00, 2 processors, Intel Core 2 Duo, 2.4 GHz, 2 GB, SMC 1.65f2
Graphics: NVIDIA GeForce 320M, NVIDIA GeForce 320M, PCI, 256 MB
Memory Module: BANK 0/DIMM0, 1 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142323837334648532D4346382020
Memory Module: BANK 1/DIMM0, 1 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142323837334648532D4346382020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.4.0f3 16298, 3 services, 27 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: TOSHIBA MK3255GSXF, 320.07 GB
Serial ATA Device: HL-DT-STDVDRW  GA32N
USB Device: USB 2.0 Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: BRCM2070 Hub
USB Device: Bluetooth USB Host Controller
USB Device: IR Receiver
Thunderbolt Bus:
#25 Thelothian
Thelothian
  • LocationItaly
  • Graphics Card:GTX780M
  • I like to play:Mass Effect, WoW, Diablo, SWTOR
Posted 24 September 2015 - 01:40 PM
Hello all
another mac user on El Capitan (GM).
I'll try to bring you some useful informations, to help finding a solution/fix about this problem.
My tests:
1. rootless. Nothing's changed. The application opens and quits after 1 sec. No errors, no feedback.
2. Using default wineskin config (automatic screen settings, use Mac driver instead of X11, decorate and the 2 default options). If I use the internal Wineskin app and try to run any of the wine tools, I get a running process named Wine open with a very-tiny window (2 pixels wide) in the upper left of the screen. Like this:
3. Deactivating "Mac driver instead of X11" option. Opening Config Utility (as the previous step) i've got the "core devices" error.
4. Activating option "Force use of system installed XQuartz, instead...", after I've launched Winecfg again, and I've got a simple X11 shell window. Stop.
5. Tried some combinations like rootless windows, virtual desktops, Override Screen Settings, etc... but nothing changes.
Note: the log is full of errors about freetype fonts and/or libpng error.
Another important note. PlayonMac (based on Wine as well) has not this problem... but cannot use it because i've portingteam wineries and i don't want to lose them.
#26 Archonis
Archonis
  • 13 posts
Posted 25 September 2015 - 03:50 AM
Same issue here with the little line. Some old wine 1.0 version works but I can't use those versions due to font issues and some other stuff.
#27 ovvldc
  • 1,171 posts
Posted 25 September 2015 - 01:22 PM
I am not convinced that it depends on the Wine version, it seems more likely it depends on the bundled XQuartz version. IIRC, in the old Wineskins, the X server was bundled with the engines. Later, doh123 moved it to the wrapper to reduce the size of engine files.
If it is the Wine version, it would be good to know which version(s) is/are good, and which is not. Someone with lots of time on their hands (i.e. not me) could go through all the engines (there are a lot) and see where it flips. It would help if people who have posted on this issue state the exact wrapper version and wine version of the wineskin apps that still work and that do not work. Through a process of elimination, we can find out when things broke and, by extension, help the devs isolate what change exactly broke things. (It is obvious that I am a scientist?)
#28 Archonis
Archonis
  • 13 posts
Posted 25 September 2015 - 01:57 PM
It's works using ws7wine1.3.17 but you need winery 2.2 (old version) to use that engine
#29 ovvldc
  • 1,171 posts
Posted 26 September 2015 - 08:26 AM
AFAIK, Winery is only up to v1.7 at the moment, but I assume you mean the wrapper version. That would support my theory.
I checked doh123's mediafire folder (https://www.mediafir.../#2sosag9mawre2) and the latest wrapper 2.2 compatible engine there is 1.3.28, so that doesn't leave us with much to work with...
Could you try to make a backup of your game, then update the wrapper and put in the ws9wine1.3.17 engine? If that works, we know that it is not the wrapper, if it breaks, the breakage is in the ws7 to ws8/9 changes.
#30 Archonis
Archonis
  • 13 posts
Posted 27 September 2015 - 12:34 AM
It breaks when I try to update it with any newer engine. I will try and provide more info this weekend
