[Blackscreen] Tony Hawks Pro Skater 2 - no Menu
#1 Draquewind
Draquewind
  • Graphics Card:Intel HD Graphics 3000 384MB
Posted 14 July 2016 - 05:49 AM
Hey Porting Team Members,
i´m totally new with wineskin and i would say - a big noob ;)
But I can learn.
I saw wineskin the first time, when i tried to play Dungeon Keeper 2 at my MacBook Pro.
It works and now I want to try to run Tony Hawks Pro Skater 2.
I tried many engines, best results see below.
Perfect Intros, but no menu screen. Sound is ok. I just see the cursor on the menu but the other screen is black.
Can anyone help me? What can I do?
I tried also the 1.7.24D3Boost Enginge, but there i get a bad intro and then an error message!
Thanks in advance for helping!!! :)
Wrapper Version: 2.6.2
Best Result Enginge: WS9WINE1.7.15NoFlicker
Screen Options: i set all marks on the other options
LastRunWineLog:
fixme:ddraw:DirectDrawEnumerateExA flags 0x00000006 not handled
fixme:win:EnumDisplayDevicesW ((null),0,0x33e38c,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),0,0x33e61c,0x00000000), stub!
fixme:ddraw:ddraw7_Initialize Ignoring guid {aeb2cdd4-6e41-43ea-941c-8361cc760781}.
fixme:d3d_surface:wined3d_surface_blt Can't handle WINEDDBLT_ASYNC flag.
fixme:d3d_surface:surface_cpu_blt Filter WINED3D_TEXF_LINEAR not supported in software blit.
fixme:d3d:resource_check_usage Unhandled usage flags 0x8.
fixme:ddraw:ddraw_surface7_Flip Ignoring flags 0x1.
LastRunX11 Log:
[3891146.271] WineskinX11 starting:
[3891146.271] X.Org X Server 1.13.0
[3891146.271] Build Date: 20120921
[3891146.271] _XSERVTransmkdir: ERROR: euid != 0,directory /tmp/.X11-unix will not be created.
[3891146.276] Initializing built-in extension Generic Event Extension
[3891146.276] Initializing built-in extension SHAPE
[3891146.276] Initializing built-in extension MIT-SHM
[3891146.276] Initializing built-in extension XInputExtension
[3891146.276] Initializing built-in extension XTEST
[3891146.276] Initializing built-in extension BIG-REQUESTS
[3891146.276] Initializing built-in extension SYNC
[3891146.277] Initializing built-in extension XKEYBOARD
[3891146.277] Initializing built-in extension XC-MISC
[3891146.277] Initializing built-in extension XINERAMA
[3891146.277] Initializing built-in extension PseudoramiX
[3891146.277] Initializing built-in extension XFIXES
[3891146.277] Initializing built-in extension RENDER
[3891146.277] Initializing built-in extension RANDR
[3891146.277] Initializing built-in extension DAMAGE
[3891146.277] Initializing built-in extension MIT-SCREEN-SAVER
[3891146.277] Initializing built-in extension DOUBLE-BUFFER
[3891146.277] Initializing built-in extension RECORD
[3891146.277] Initializing built-in extension X-Resource
[3891146.277] Initializing built-in extension XVideo
[3891146.277] Initializing built-in extension XVideo-MotionCompensation
[3891146.277] Initializing built-in extension GLX
[3891146.278] x: 0, y: 0, w: 1280, h: 777
[3891146.296] (II) GLX: Initialized Core OpenGL GL provider for screen 0
[3891146.299] [dix] Could not init font path element /opt/X11/share/fonts/75dpi, removing from list!
[3891146.299] [dix] Could not init font path element /opt/X11/share/fonts/100dpi, removing from list!
[3891146.299] [dix] Could not init font path element /opt/X11/share/fonts/cyrillic, removing from list!
[3891146.299] [dix] Could not init font path element /opt/X11/share/fonts/misc, removing from list!
[3891146.299] [dix] Could not init font path element /opt/X11/share/fonts/OTF, removing from list!
[3891146.299] [dix] Could not init font path element /opt/X11/share/fonts/Speedo, removing from list!
[3891146.299] [dix] Could not init font path element /opt/X11/share/fonts/TTF, removing from list!
[3891146.299] [dix] Could not init font path element /opt/X11/share/fonts/Type1, removing from list!
[3891146.299] [dix] Could not init font path element /opt/X11/share/fonts/util, removing from list!
[3891146.432] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
[3891149.314] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
[3891149.317] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
[3891149.399] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
[3891149.585] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
[3891149.679] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
[3891149.892] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
[3891149.963] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
[3891151.112] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
Engine Used: WS9Wine1.7.15NoFlicker
Hardware:
    Hardware Overview:
  Model Name: MacBook Pro
  Model Identifier: MacBookPro8,1
  Processor Name: Intel Core i7
  Processor Speed: 2,7 GHz
  Number of Processors: 1
  Total Number of Cores: 2
  L2 Cache (per Core): 256 KB
  L3 Cache: 4 MB
  Memory: 4 GB
  Boot ROM Version: MBP81.0047.B2C
  SMC Version (system): 1.68f99
  Sudden Motion Sensor:
  State: Enabled
Graphics/Displays:
    Intel HD Graphics 3000:
  Chipset Model: Intel HD Graphics 3000
  Type: GPU
  Bus: Built-In
  VRAM (Dynamic, Max): 384 MB
  Vendor: Intel (0x8086)
  Device ID: 0x0126
  Revision ID: 0x0009
  Displays:
    Color LCD:
  Display Type: LCD
  Resolution: 1280 x 800
  Pixel Depth: 32-Bit Color (ARGB8888)
  Main Display: Yes
  Mirror: Off
  Online: Yes
  Built-In: Yes
Hardware:
    Hardware Overview:
  L3 Cache: 4 MB
  Memory: 4 GB
  State: Enabled
Graphics/Displays:
  Type: GPU
  Bus: Built-In
  Device ID: 0x0126
  Revision ID: 0x0009
  Displays:
    Color LCD:
  Display Type: LCD
  Main Display: Yes
  Mirror: Off
  Online: Yes
  Built-In: Yes
