Video How to build Custom Engines With Wineskin
19 replies to this topic
#1 soloMacOSX
soloMacOSX
  • 22 posts
  • Graphics Card:NVidia9400M
    Intel Iris Pro Graphics 6200 1536 MB
Posted 27 November 2016 - 06:37 AM
Hi, currently i'm using El Capitan but I haven't got how to create custom engines with new wine sources through wineskin.
I've followed tutorials which explain how to compile my own engines, but I haven't got success.
- I've installed de sdks correctly
- I've installed gcc 4.2
But when I will compile a new wine source, I can't. Wineskin gets the error that gcc 4.2 not found. I tried many solutions but I couldn't solve it.
Someone with many experience in the management of wineskin, could make a video and upload it in youtube on how to configure wineskin? and also showing which third party software is needed to install to create custom engines? It would be very useful and will help to grow this community of testers. I've seen that some users of wineskin have created custom engines, and also stagin engines so it will be a great help for new testers.
Currently I'm a wineskin user but sometimes I feel limited because I can't build custom engines to add patches and custom configurations.
I hope for soon answer.
Thanks!!
More tutorials in english about Wineskin on soloMacOSX Youtube
#2 Brainzyy
Brainzyy
  • 166 posts
  • LocationBelgium
  • Graphics Card:AMD Radeon R9 M370X (2GB) / Intel Iris Pro 5200
Posted 27 November 2016 - 09:20 PM
El Capitan has SIP (google it) which needs to be disabled to be able to build wineskin engines.
Use this tutorial (written by me): http://portingkit.co...php?topic=289.0
#3 ovvldc
  • 1,124 posts
  • Graphics Card:Intel HD5000
Posted 28 November 2016 - 09:29 AM
I don't see why this should be needed. Nothing in using a Wine engine requires the changing of system files, and neither should building one. It sounds more like the build process is very messy in some way.
#4 Brainzyy
Brainzyy
  • 166 posts
  • LocationBelgium
Posted 28 November 2016 - 01:08 PM
I had the same errors that this user had. I tried without disabling SIP and just modifying the minimumsdk plist, but it didn't work. It only worked when disabling SIP. Don't ask my why, but it did. I did a lot of research on this.
#5 Zakk
Zakk
  • Graphics Card:Nvidia 650M
Posted 01 December 2016 - 12:18 PM
The build process is very messy. People are probably running afoul of SIP when the build script tries to install gcc-4.2 into /usr.
The solution is to either 1) install it somewhere else, 2) install ALL of it into /usr/local (which is exempt from SIP) or 3) just build with the apple provided compiler
#6 ovvldc
  • 1,124 posts
Posted 01 December 2016 - 12:29 PM
I assume that this is a feature of the build script that doh123 developed. Made sense at the time but is now overtaken by events, etc.
#7 soloMacOSX
soloMacOSX
  • 22 posts
Posted 15 December 2016 - 06:02 PM
Hi ScoPezz thanks for your answer. Indeed your guide was the guide that I had followed before I posted this discussion about how to build wineskin engines. It's the error I get after following al the steps and compiling a new engine. I've tried with different wine sources, but still I'm having the same problem. Here is an image with the error.
¿Is there a solution for this problem? I hope for soon answer.
Thanks for your support.
#8 Brainzyy
Brainzyy
  • 166 posts
  • LocationBelgium
Posted 15 December 2016 - 08:01 PM
It could be that your libs/compiler is broken. Maybe because of Homebrew or Macports.
Because it says your installed gcc version cannot be used.
So I suspect you have a custom installed version, which is messing with the version needed for Wineskin.
#9 doh123
Posted 16 December 2016 - 12:46 AM
The script wants to use Apples old gcc 4.2 (back before Apple dumped gcc), which is built to run from locations that require it... It may be the Xcode thing I mentioned in the other thread, or just SIP.
You could modify the build script where it sets what gcc executable to use to point to some other compiler you have...
#10 soloMacOSX
soloMacOSX
  • 22 posts
Posted 17 December 2016 - 05:04 AM
I have installed gcc on my mac, it's a screenshot with my version of gcc
I have read, that the error "checking whether the c compiler works... no" is due to I have not run gcc on my mac and agreed with it's terms of license. Which command I need to use to run gcc from the terminal?
#11 ovvldc
  • 1,124 posts
Posted 17 December 2016 - 10:35 AM
This looks like LLVM masquerading as GCC. Probably done for compatibility purposes in generic build scripts.
#12 doh123
Posted 17 December 2016 - 01:24 PM
yeah, thats clang... it should still work.I know now you can just do "xcode-select --install" which should install and fix several things... but last time I did a fresh install, and it kept saying this, i had to launch XCode.app and accept all the license agreement junk and everything before the command line stuff started working right.  I have not worked with their changed processes in the last couple of years so I'm not totally sure what to tell you.
#13 soloMacOSX
soloMacOSX
  • 22 posts
Posted 17 December 2016 - 04:13 PM
doh123 I have tried in 4 macs, and still having the same problems. I need help! I tried it in 3 iMacs 2015 late and 1 macbook 2008 late and I'm having the same problems :(
All in OSX EL Capitan
#14 soloMacOSX
soloMacOSX
  • 22 posts
Posted 17 December 2016 - 05:40 PM
I tried again if command lines is installed on my Mac and yes, it's installed. Also I have XCode updated. Still the same problem building engines --> "checking whether the C compiler works... no"
I will send you some screenshots:
All is installed, but I can't compile new engines :(
#15 Brainzyy
Brainzyy
  • 166 posts
  • LocationBelgium
Posted 18 December 2016 - 06:52 PM
Run this command: sudo xcodebuild -license
You can agree to everything using this command.
#16 soloMacOSX
soloMacOSX
  • 22 posts
Posted 19 December 2016 - 05:50 PM
No success. And again I tried on a friend's Mac and still the same problem. No compiling custom engines. It's the fifth Mac I've tried and the problem stills appear.
#17 Brainzyy
Brainzyy
  • 166 posts
  • LocationBelgium
Posted 19 December 2016 - 05:58 PM
Then it seems your build environment is polluded or not installed correctly. Are you sure SIP is disabled and you installed the correct gcc version?
#18 soloMacOSX
soloMacOSX
  • 22 posts
Posted 20 December 2016 - 03:52 AM
Yes, I have disabled SIP. I followed your guide step by step in 5 Macs and I can't build custom engines. Could be a problem with OSX El Capitan?
#19 soloMacOSX
soloMacOSX
  • 22 posts
Posted 21 December 2016 - 08:55 PM
ScoPezz I think I've found the problem, but I don't know how to solve it. I researched on google and found that GCC must be installed on /usr/local/bin and the wineskin script installed GCC on another directory /usr/bin. Here is a thumbnail of my actual install directory. How can I change the GCC install directory to /usr/local/bin ? for this reason I think that terminal is not finding the C compiler. Hope for your soon answer.
#20 ovvldc
  • 1,124 posts
Posted 21 December 2016 - 10:07 PM
Maybe a few symlinks can fix the problem? Possibly with some additions to PATH
