Winery and Winskin
#1 TECH198
TECH198
  • 10 posts
  • Graphics Card:Intel Iris 6100 1536MB
Posted 18 June 2017 - 01:31 PM
Why is there no Mac ports ?  e.g  use Wine to install old Mac apps?
I know it probably wouldn't make much sense, but the only options on the Mac is to use Bootcamp, or Virtual machine/VirtualBox at the  very least.
You can reverse engineer Apple's code as much as u could reverse engineer Microsoft Windows I would have guessed. Or is that there is not that much interest in running older Mac apps ?
#2 NRG
  • 654 posts
Posted 18 June 2017 - 02:03 PM
Wineskin Winery is a project for mac  based on WINE to have a GUI for it on macOS and to create a wrapper for the single Windows ported application/game:
wine is a project to run Windows applications firstly on Linux and then on Mac Os x and other systems...
So if you need an emulator for old  not intel mac applications you need something different
