HID controller and zeroN64 v1.0
Started By
Guest_kaizerarel_*
, Nov 08 2009 03:34 PM
11 replies to this topic
#1 Guest_kaizerarel_*
Posted 08 November 2009 - 03:34 PM
Hello,
Could somebody tell me, how to configure my usb joypad with zeroN64 v1.0?
(it' s a standard HID controller based, and it' works perfect with zeroPSX Hybrid for exaple)
Thanx.
Thanx.
Posted 08 November 2009 - 05:07 PM
I assume you use some type of Controller mapping software like Controllermate or USB Overdrive?
Then you just have to do it like in zeroPSX Hybrid.
Go into the Settings/Options of the Emulator and look for the Keyboard layout.
Then change the Keys to the Buttons your Joystick uses, or simply make another Configuration in Controllermate / USB Overdrive and use the Key that the Emulator is set up for.
I know it's a small PITA, but you only have to do this once :)
#3 Guest_kaizerarel_*
Posted 11 November 2009 - 12:56 AM
No, I don't use USB Overdrive.
I use directly my original playstation joypad with an USB adaptator that works without driver (standard HID)
The problem is when I go in to the ZeroN64 Configure control plugin setting window, and I try to set the imput,.
The application recognize only the keyboard imput and not the joypad buttons.
Ill' try to install USB overdrive and use the oprtion that set the key that the Emulator is set up for.
Thanx for your suggestion! :D
Posted 11 November 2009 - 09:11 AM
zeroPSX has like all CX(S) Ports no HID support, so i think it's pure coincidence that your Controller buttons works with the buttons i set up for the Emulator.
I also made a tutorial for Controllermate with a XBOX 360 controller.
Check it out here:
http://forum.porting....php?f=90&t=446
Check it out here:
Posted 16 December 2009 - 11:30 AM
How can you get the XBOX 360 controller to work without ControllerMate? Mine keeps getting false input.
#6
Posted 17 December 2009 - 08:28 PM
Getting it to work with ControllerMate was a real pain, but it worked. Getting it to work with another Keymapper like USB Overdrive is possible, but every analogue Stick isn't working correctly then.
#7
Posted 17 December 2009 - 09:40 PM
Why do the wine wrappers not play nice with these controllers when other mac applications do?
(I have the Tattiebogle driver installed. I would expect that to give good input).
#8
Posted 20 December 2009 - 10:36 PM
Wine has no support for other HID input except Mouse & Keyboard, mainly because they have other problems to put some work into i think.
Since Wine comes from Linux, implementing a Joystick HID driver that would work on both linux and mac would be very hard.
They barely support printing from Wine, it works in some applications and not in others.
#9 Guest_kekestylez_*
Posted 20 December 2009 - 11:33 PM
so xbox 360 / ps3 controllers through tattiebogle driver do not work?
#10
Posted 02 January 2010 - 04:13 AM
Hey devilhunter I was wondering if you could post your controllermate file for ZeroN64 so we wouldn't have to go through the trouble of mapping keys.
Thanks.
Thanks.
#11
Posted 03 January 2010 - 04:59 PM
The xbox 360 controller works fine. You just have to switch to N-rage's input plugin under settings.
#12
Posted 04 January 2010 - 08:11 PM
Thanks.
Thanks.
Sorry, didn't make one for that yet :oops:
I recently got my XBOX 360 controller running again after upgrading to snow (Controllermate didn't work with snow correctly, and only the recent update changed that), so i'll make more of these available for download when i'll mess around with the Emulators...
