Project 64 1.7 Port!
7 replies to this topic
#1 Matty0
Matty0
    Advanced Porter
  • 46 posts
Posted 18 April 2010 - 07:39 PM
this is a port of the 1.7.55e build of Project 64.
as im sure many of you know, the origional 1.7 exe file can't run in a wrapper, so i used the hacked (k) exe in stead and it runs great :)
this is a spanish build (english wouldn't work) but i put in an english language pack so its all english.
Screenie
Runs on the CXZ Jade Engine.
Download,
This was quite a challenge, finding the hacked (k) exe wasn't easy!
Matty0
#2 berylshape
berylshape
  • 24 posts
Posted 18 April 2010 - 09:16 PM
Told you everything on MacBB :P
Drop by on our PortingTeam IRC if you don't have access to BrokenStones and need Sixtyforce, i'll help you there :)
#3 Guest_jjh_*
Guest_jjh_*
Posted 20 April 2010 - 09:56 AM
you're the man.  thanks for doing this !
#4 Matty0
Matty0
    Advanced Porter
  • 46 posts
Posted 20 April 2010 - 01:05 PM
:) thanks, this isnt... the most stable of ports, and i recomend the ZeroN64 port if thats what you're looking for, but it is a first milestone in getting the 1.7 build running. if we can get the propper exe to run then pokemon snap for us :D
#5 Guest_z11111_*
Guest_z11111_*
Posted 08 February 2011 - 03:34 AM
thanks a ton! Been looking for this for a while
#6 Guest_elmnt61_*
Guest_elmnt61_*
Posted 25 March 2011 - 11:39 AM
Hm, this isn't working for me. I load it up, and it tells me the audio plugin could not be loaded, or the RSP plugin. And there's nothing in the graphics plugin menu. I tried to add graphics plugins from my windows version of PJ64 1.7, and they don't appear in the drop-down menu.  Any idea how to get these gfx plugins working? Thanks!
#7 thneoo
thneoo
Posted 28 November 2011 - 05:44 PM
thanks you
#8 adrian1369
adrian1369
  • 6 posts
  • Graphics Card:Nvidia 9400M and 9600M GT
Posted 14 February 2012 - 02:19 AM
Could you update the link !
