Half-Life 1 problems
#1 Cheddar
Cheddar
  • 19 posts
  • LocationUnited States
Posted 27 January 2011 - 03:23 AM
About 3 months ago i downloaded a Counterstrike 1.6 cider port and it ran fine, i got tired of it and deleted it. Later i tried to download thedoctor45's Half-Life port and it did not run, neither did the expansions. i wanted to see if counterstrike still ran since they are built on the same engine, and i downloaded the same port that used to run on my computer but this time it didn't run, right when i open any of the ports (hl, hl:bs, hl:op, cs1.6) they pop up for a second and instantly close, i was wondering if anyone else has had this problem and if there are any fixes for it, Cheers.
#2 Cheddar
Cheddar
  • 19 posts
Posted 27 January 2011 - 04:05 AM
I figured it out, i needed to make a folder in Macintosh HD>Library>Preferences of the preference folder name it can successfully copy the files and the games run
#3 civosark
civosark
  • Graphics Card:mac whatever... :)
  • I like to play:half life
Posted 18 February 2012 - 12:43 PM
i also try to run
