zeroN64 will not execute
#1 Kefo
Kefo
Posted 04 April 2011 - 12:29 PM
Hey there fellow members and porters, I have tried for the past two days to get zeroN64 running, and without luck. It will show an icon in the dock for a split second the first time I try starting it after rebooting the OS, and then nothing every time following. I've downloaded every CXZ engine, (even though I believe jade is the only one I need), as well as project64 (k) itself in hopes that would work, thegrimreaper (once again not sure if it would help but just to see) and have read every post on this site and searched over the web for someone with a similar issue.
I would be truly grateful to anyone who could give me a little guidance... running osX10.6.7 on a 13" black macbook (2.4GHz intel core 2 duo, w/ 4gb 667 MHz DDR2 SDRAM) and whatever the built in video card is... can't remember exactly. Cheers,
Hans
#2 devilhunter
Posted 04 April 2011 - 04:38 PM
Do any other CXZ ports work for you?
Since you have a bare minimum chip what can be called a GPU, i can't recommend any medium to heavy ports, but you can try this one.
viewtopic.php?f=231&t=6394
Also got X11 installed?
#3 Dragonessa007
Dragonessa007
  • 19 posts
  • Graphics Card:Intel HD 3000
  • I like to play:RPG, Sim, FPS. My favorite systems are Playstation, Nintendo64, Wii, and Gamecube.
Posted 22 March 2012 - 04:13 PM
I am having this exact problem. I am using CXZ engines (Jade, etc.) and my graphics card is an Intel HD 3000, I use a Macbook Pro "13 that has an i5 2.3ghz processor and I have OSX Lion. Is there any way to get the damn app to work?
#4 devilhunter
Posted 22 March 2012 - 08:34 PM
wow this thing is so old.
I've posted this in 2009, and it wasn't even a CXZ Wrapper back then.
Here is the Project64 wrapped in the newest Wineskin
link
I haven't got a N64 Rom around to test it with now (now where did i put those things...), but it should work; just select 'open ROM' from the File menu in the window and navigate to your ROM.
I have posted quite a lot of Emulators back then (all of which don't work now since snow leopard), an i'll be updating them with Wineskin and post them into the Port Database when i'll find the time.
#5 KGameLover1
KGameLover1
    News Editor - Master Troll
  • News Team
  • 839 posts
  • LocationWhere I am is where I be
  • Graphics Card:AMD Radeon HD 6750M 1024 MB, also Intel HD Graphics 3000 512 MB.
  • I like to play:Everything that's fun
Posted 22 March 2012 - 10:25 PM
CXZ doesn't work on Lion.
blinxfrost said:
in game my guy spins out of control only way i can control is arrow keys my hands are to nubby to reach them and shot
View my ports! <--- Orcs Must Die, Payday, Fallout, I Wanna Be The Guy, and more!
How to use a Wineskin wrapper!
#6 JaKXz92
JaKXz92
  • Graphics Card:Intel HD 4000
  • Operating System:Mac OS X 10.8 (Mountain Lion)
Posted 30 October 2012 - 03:23 AM
Hi, I'm trying the provided wrapper on Mountain Lion with the latest XQuartz (i.e. X11) installed, v2.7.4, and I can get Project64k 0.38 working to the point where it gives me an error about the GFX driver I'm using. The problem here is that it doesn't successfully open popup windows, I think, so I can't actually get to the option to change the gfx driver.
When I simply double click on the zeroN64.app, the icon appears in the dock but then nothing else happens.
Thoughts?
thanks in advance
edit: apologies if this question is similar to those above, but i'm just wondering if anything has changed since then!
#7 waves
waves
    Still here
  • 1,328 posts
  • Graphics Card:NVIDA
Posted 30 October 2012 - 10:46 PM
Your problem is you are on 10.8 - this only works on 10.6 and below - and maybe 10.7.
So either go back to Snow Leo - or try a something else - but it will not work on 10.8
How to get multiple file port games / apps runnning: http://portingteam.c...-combine-files/
#8 eridani
eridani
    Members
  • 203 posts
  • LocationSylvarant
  • Graphics Card:ATi Radeon X1600
Posted 01 November 2012 - 01:52 AM
View Postwaves, on 30 October 2012 - 10:46 PM, said:
Your problem is you are on 10.8 - this only works on 10.6 and below - and maybe 10.7... it will not work on 10.8
Why not? its a Wineskin based wrapper.
I mean the one posted by DH above. It should work just after updating the wrapper to v2.5.8, which is a simple task.   o.o
#9 waves
waves
    Still here
  • 1,328 posts
Posted 05 November 2012 - 11:01 AM
Ah that one - never realized there was a winskin one - so yeah it will work - but not unless it is 2.5.8 - for 10.8.2 - I assume without looking at :)
