I got the windows game and I used the cider wrapper and it works kinda well.... a bit lot lag and he walks slow sometimes.
I have a late 2008 macbook aluminum with 2.4 Ghz and nvidia GeForce 9400M 256 MB
but i hate using the keyboard.
so what can I do to use a joystick or something else?
also I see they have a native version of assassins creed 2. does it work well or is it terrible?
using a joystick with assassin's creed port?
Started By shamguy4, Oct 19 2011 01:09 PM
Posted 19 October 2011 - 01:09 PM
Posted 19 October 2011 - 03:10 PM
Native assassins creed 2 doesn't work well with my controller at least.
As for the lagging, it's on your side, because 9400M is actually below lowest specs from ubisoft.
Specs:
100 series are one generation newer than 9400M and 9400M is a integrated card as well.
Not to mention you have a 2.40GHz CPU and not 3.06GHz
Specs:
Minimum: OS: OS X version Leopard 10.5.8, Snow Leopard 10.6.3, or later. Processor: Intel Core® 2 Duo 3.06 GHz Memory: 3GB Graphics: 256 MB Dedicated Shader model 3.0 or higher (see supported list) Hard Drive: 9GB Peripherals: Mouse, keyboard Internet Connection: Broadband Internet connection with 128 kbps upstream or faster SUPPORTED VIDEO CARDS AT TIME OF RELEASE: - ATI® RADEON® HD 4000/5000 series* - NVIDIA GeForce® 100/200 series* *Laptop and integrated versions of these cards may work but are NOT supported. These chipsets are the only ones that will run this game.
[HackPro i5-4.3 GHz, 2x SSD + 5TB HDD • 16GB RAM • NVidia GTX 660 2GB • OSX 10.8.3] . [MacBookAir 13 1.7GHz • Intel HD 3000 • OSX 10.7.5]
How to port Steam games .... My Youtube Porting videos ... My Porting Nexus
Posted 19 October 2011 - 03:33 PM
For assassins creed 1.
Depending on the Cider version, that was used to port it, it should work out of the box.
If it does not try out other versions from the Assassins Creed Post in the Members Project Settings.
I remember, that it did work with at least one version of those wrappers. Maybe it was 0.6.
If you have a wrapper, that does not seem to detect your controller correctly, you can always use controller mate.
And if the game only works with XBox 360 Gamepad the xbox360cemu does the magic.
God save us everyone, Will we burn inside the fires of a thousand suns? - Linkin Park The Catalyst
Listen to their new Single Burn it Down for free!
Posted 19 October 2011 - 05:32 PM
oh well i didn't know about controller mate but i discovered oscillator!
i am playing using my wii controller!
the analog sticks don't work exactly right... i needed to set them to digital buttons: up down...
but otherwise its cool.
