Skyrim Binkw32.dll Error help!
#1 suzaku
suzaku
  • 14 posts
Posted 21 November 2011 - 03:15 PM
Jess887cp wrote:
"I copied the files in the directory described into the cider wrapper. Unfortunately, it doesn't seem to work. When I double-click it, the icon pops up in the dock for a second, then disappears. Is there a fix?"
Hey guys, I have this exact problem, not sure what the issue may be. though there wasn't an empty folder as in step 11 of moussaillion's quoted step by step. it instead had a folder that said %USERPROFILE% I tried opening the application with this folder both in and out of the folder it was in with the same result as Jess887cp.
When it shows up in the dock for that second, right clicking it tells me that the application is not responding.
I've not yet gotten it to open, it seems to be I either need to install the game, not sure how and I didn't see it explicitly shown how, also not sure if there is anything else I need to do with the cider wrapper after downloading and transferring the files from razor1911's wineskin DL
Looked through most of the thread and saw people with similar issues but none of it helped me. Sorry for the super noobishness
Any help would be greatly appreciated. This is the error message I'm receiving, it talks of a bad module and a binkw32.dll issue, not sure what to do. :(
Last login: Sun Nov 20 12:08:05 on ttys001
cpe-70-125-144-157:~ Suzaku$ /Applications/The\ Elder\ Scrolls\ V\ Skyrim.app/Contents/MacOS/cider ; exit;
err:reg:Nt_openConfigW could not retrieve the module file name (reason: 'bad module')
err:module:MODULE_LoadLibraryExA Loading of native DLL C:\Program Files\The Elder Scrolls V Skyrim\binkw32.dll failed, check this file ! (GetLastError 193)
err:module:PE_fixup_imports Module (file) binkw32.dll (which is needed by C:\Program Files\The Elder Scrolls V Skyrim\TESV.exe) not found
logout
[Process completed]
That's what's listed, Thanks for the help MACRM32 I see it says something about 32 not being found but it's in the the skyrim folder with the user profile one as is the TESV.exe
#2 suzaku
suzaku
  • 14 posts
Posted 21 November 2011 - 04:53 PM
Well I've graduated to just a black screen now, no flickers or game in the lower left, just a black screen and mouse arrow. I dl'ed a crack only file a friend sent and then replaced that binkw with the one I had previously had. That fixed the icon just showing up for a second in the dock but now the issue I'm having is just a black screen. I've used the preferences app to change the settings 3 different times for size and all the different resolutions with the same result. this is the error message I'm receiving now.
Last login: Mon Nov 21 10:46:05 on ttys000
err:wave_audiodevice:audio_device_stereo_channels device 54 failed to get preferred stereo channels (0x77686f3f)
err:wave_audiodevice:audio_device_channel_volume_writable device 54 failed to get volume writable (0x77686f3f)
err:wave_audiodevice:audio_device_format failed to get device 54 format inputChannel: 0 (0x77686f3f)
err:wave_audiodevice:audio_device_stereo_channels device 44 failed to get preferred stereo channels (0x77686f3f)
err:wave_audiodevice:audio_device_channel_volume_writable device 44 failed to get volume writable (0x77686f3f)
err:wave_audiodevice:audio_device_format failed to get device 44 format inputChannel: 0 (0x77686f3f)
err:wave_audiodevice:audio_device_format failed to get device 34 format inputChannel: 1 (0x77686f3f)
err:fixup:PE_fixup_imports No implementation for msvcrt.dll.249(_aligned_malloc) imported from C:\windows\system32\XAudio2_6.dll, setting to 0xdeadbeef
err:fixup:PE_fixup_imports No implementation for msvcrt.dll.247(_aligned_free) imported from C:\windows\system32\XAudio2_6.dll, setting to 0xdeadbeef
err:wave_audiodevice:audio_device_set_nominal_sample_rate device 34 failed to set sample rate (0x21646174)
err:dsound:DSOUND_timer could not acquire mix lock
logout
[Process completed]
#3 snyder9
snyder9
  • 27 posts
  • Graphics Card:EVGA GTX560 Ti FPB 1024MB
  • I like to play:Sports Simulations, Strategy
Posted 21 November 2011 - 05:48 PM
Have you replaced the following files with cracked versions? Not just binkw32.dll
atimgpud.dll?
SkyrimLauncher.exe?
TESV.exe?
#4 suzaku
suzaku
  • 14 posts
Posted 21 November 2011 - 05:56 PM
The Crack I dl'ed only had these files to replace. I had originally gotten the files from the wineskin razor1911 torrent and then copied over the files from there into the cider file I dl'ed
binkw32.dll
installscript.vdf
skyrim.rar
Steamclient.dll
THEGFW.ini
I followed these directions originally
Copy from here.
Quote:
OK, so if anyone still needs step by step:
1) DL this torrent
2) Go to viewtopic.php?f=45&t=9348
3) DL the Cider Wrapper
4) Unzip the torrent. You should get a Skyrim folder with, among other things, the "The Elder Scrolls V Skyrim" app.
5) command- click it.
6) choose Show Package Contents
7) Navigate to drive_c/Program Files/The Elder Scrolls V Skyrim
You should see lots of files and directories including SkyrimLauncher.exe, and the Data and Skyrim directories.
9) Now, do steps 5 & 6 for the Cider wrapper
10) In the Cider wrapper, navigate to Contents/Resources/transgaming/c_drive/Program Files/The Elder Scrolls V Skyrim
11) It should be empty.
12) Now, select all the files in step 8, and drag them across to the empty folder in step 11.
That's it!
Er...just to clarify, copy *all* the stuff in the directory you went to in step 7 into the directory you went to in step 10. Not just the ones I deliberately mentioned.
BTW, it doesn't seem to need mouse acceleration in this configuration. They did a good job on the wrapper!
kiyyik
#5 suzaku
suzaku
  • 14 posts
Posted 21 November 2011 - 09:04 PM
atimgpud.dll?
SkyrimLauncher.exe?
TESV.exe?
Replaced these files with cracked versions and still the same issue now as my second post.
#6 suzaku
suzaku
  • 14 posts
Posted 23 November 2011 - 05:13 PM
suzaku said:
cluthz said:
meh i didn't read the follow ups.
Did you add a configfile inside :
/Contents/Resources/transgaming/c_drive/Program Files/The Elder Scrolls V Skyrim/%USERPROFILE%/My Documents/My Games/Skyrim/SkyrimPrefs.ini
No have not messed with that file at all, how and what would I add to the skyrimprefs.ini?
Thanks very much man.
Where and what do I need to add to the skyrimprefs.ini? This is what it looks like currently and all it gets me is a black screen, no flickeriness, no game in the lower left, just a black screen. :( Been working for 4 days now to try and get this working, any help is greatly appreciated.
[Display]
iTexMipMapSkip=0
bFXAAEnabled=1
fMeshLODLevel2FadeDist=3072.0000
fMeshLODLevel1FadeDist=4096.0000
fSpecularLODStartFade=500.0000
fLightLODStartFade=1000.0000
fTreesMidLODSwitchDist=0.0000
iShadowMapResolution=512
fShadowBiasScale=0.5000
iShadowMaskQuarter=3
iBlurDeferredShadowMask=0
fShadowDistance=2000.0000
iMaxDecalsPerFrame=0
iMaxSkinDecalsPerFrame=0
iAdapter=0
iSize W=1920
iSize H=1080
iMultiSample=0
iMaxAnisotropy=4
iPresentInterval=0
bFull Screen=1
fInteriorShadowDistance=3000.0000
bFloatPointRenderTarget=0
fGamma=1.0000
iShadowFilter=3
fDecalLOD2=1500.0000
fDecalLOD1=1000.0000
fShadowLODStartFade=200.0000
iTexMipMapMinimum=0
bTransparencyMultisampling=0
iWaterMultiSamples=0
iShadowMode=3
bTreesReceiveShadows=0
bDrawLandShadows=0
bDrawShadows=1
fLeafAnimDampenDistEnd=4600.0000
fLeafAnimDampenDistStart=3600.0000
fMeshLODFadePercentDefault=1.2000
fMeshLODFadeBoundDefault=256.0000
fMeshLODLevel2FadeTreeDistance=2048.0000
fMeshLODLevel1FadeTreeDistance=2844.0000
iScreenShotIndex=0
bShadowMaskZPrepass=0
bMainZPrepass=0
[Imagespace]
iRadialBlurLevel=0
bDoDepthOfField=1
[LOD]
fLODFadeOutMultActors=2.5000
fLODFadeOutMultItems=3.5000
fLODFadeOutMultObjects=2.5000
fLODFadeOutMultSkyCell=1.0000
[Grass]
fGrassStartFadeDistance=3000.0000
b30GrassVS=0
fGrassMaxStartFadeDistance=7000.0000
fGrassMinStartFadeDistance=400.0000
[Decals]
bDecals=0
bSkinnedDecals=0
uMaxDecals=0
uMaxSkinDecals=0
uMaxSkinDecalsPerActor=0
[TerrainManager]
fTreeLoadDistance=12500.0000
fBlockMaximumDistance=75000.0000
fBlockLevel1Distance=25000.0000
fBlockLevel0Distance=15000.0000
fSplitDistanceMult=0.4000
bShowLODInEditor=0
[BlurShaderHDR]
bDoHighDynamicRange=1
[BlurShader]
bUseBlurShader=0
[Launcher]
bShowAllResolutions=1
uLastAspectRatio=4
[Water]
iWaterReflectHeight=512
iWaterReflectWidth=512
bUseWaterDisplacements=1
bUseWaterRefractions=1
bUseWaterReflections=1
bUseWaterDepth=1
[MAIN]
fSkyCellRefFadeDistance=150000.0000
bGamepadEnable=1
bCrosshairEnabled=1
fHUDOpacity=1.0000
bSaveOnPause=1
bSaveOnTravel=1
bSaveOnWait=1
bSaveOnRest=1
[GamePlay]
bShowFloatingQuestMarkers=1
bShowQuestMarkers=1
iDifficulty=2
[Interface]
bDialogueSubtitles=0
bGeneralSubtitles=0
bShowCompass=1
[Controls]
fMouseHeadingSensitivity=0.0125
fGamepadHeadingSensitivity=1.9000
bAlwaysRunByDefault=1
bInvertYValues=0
bGamePadRumble=1
[Particles]
iMaxDesired=750
[SaveGame]
fAutosaveEveryXMins=15.0000
[AudioMenu]
fAudioMasterVolume=1.0000
fVal7=1.0000
uID7=0
fVal6=1.0000
uID6=0
fVal5=1.0000
uID5=0
fVal4=1.0000
uID4=0
fVal3=0.5000
uID3=466532
fVal2=0.8000
uID2=554685
fVal1=0.8000
uID1=1007612
fVal0=1.0000
uID0=94881
[Clouds]
fCloudLevel2Distance=262144.0000
fCloudLevel1Distance=32768.0000
fCloudLevel0Distance=16384.0000
fCloudNearFadeDistance=9000.0000
[General]
iStoryManagerLoggingEvent=-1
bEnableStoryManagerLogging=0
[Trees]
bRenderSkinnedTrees=1
uiMaxSkinnedTreesToRender=40
#7 cluthz
  • 2,836 posts
Posted 24 November 2011 - 01:23 AM
did you try any of the default files?
#8 suzaku
suzaku
  • 14 posts
Posted 24 November 2011 - 03:45 PM
yeah none of the default stuff works :(
#9 cluthz
  • 2,836 posts
Posted 24 November 2011 - 05:15 PM
At this point I can't see whats going wrong.
Have you tried the razorDOX update 1? If not try it.
I'd suggest try reinstall, it can be a corrupt installation. This might be, since you've had a non-working bink32w.dll.
Another thing you can try is to PM someone that have successfully installed on a iMac with 5670, and get their config, but since none of the default ones worked, i guess thats not gonna help.
One thing, you are running Snow Leopard or Lion right? We've had people reporting issues with Leopard (10.5.x)
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
