Hello Everyone,
Recently i created a Ciderx port for poral 2, i installed the game and copied the crack and tested out the port it was working perfectly the first time,
but once i quit and open the Portal 2 port again it gives me a error saying "Could not load library client" so for that i have to again copy the crack to the portal 2 folder in my Ciderx Port,and than it starts working....
This happen every time i quit my game
what is the problem???does it happen with other games too????
Portal 2 Problem
Started By jaymit, Dec 02 2011 07:46 AM
Posted 02 December 2011 - 07:46 AM
Posted 02 December 2011 - 01:18 PM
jaymit said:
Hello Everyone,
In case of portal 2 this may be the client.dll.
Find it's path and add it to the protectedfiles.txt in the resources folder.
That should fix your problem.
God save us everyone, Will we burn inside the fires of a thousand suns? - Linkin Park The Catalyst
Listen to their new Single Burn it Down for free!
#3 Guest__*
Posted 03 December 2011 - 12:36 AM
Just for your notice, Portal 2 is a Mac Supportive game. If you bought it, you can already install it on steam , if not. Well not sure about that .
Posted 03 December 2011 - 02:07 PM
So if your looking for a good cider wrapper to do this in; I suggest this one: viewtopic.php?f=109&t=9075
as it has a lot of support for steam.
Not sure how it will actually turn out however.
Just saying that it works out on paper.
Cheers! :beer:
Posted 04 December 2011 - 07:34 AM
Drakulix said:
jaymit said:
Hello Everyone,
Thanks a lot ill try it out and tell you! since i have a very low download speed so i cant download the mac version
but the windows one is available in my local hub,and the game works perfectly for those of u having slow download speeds,perfect graphics!! thanks all
#6
Posted 04 December 2011 - 10:13 AM
The solution that DRAKULIX wrote worked only twice but than the error started coming again than i went to portal2/bin there i saw that the client.dll file was renamed by the game itself as "client.dll.SteamStart",the game renamed the client.dll file therefoe making me think it was deleted .
so the solution is to right click on the client.dll (delete the "client.dll.SteamStart" file and copy the client.dll file from crack folder ) file [Located in c_drive/program files/Valve/Portal 2/portal2/bin] and go to "Get info"
then in the General Section :Check the Locked Box
and in the "Sharing & Permisson "Section below Change everyones Privelleges to "Only Read"
So the Game cant change the Client.dll file
Thanks for the help guys!
#7
Posted 09 December 2011 - 08:12 AM
Or you could just... you know.... support the developers and buy it on steam....
