- New patch applied for Raw3.patch so the mouse warps around the x axis
- Should increase compatibility with games that were not working
- Based on latest GIT branch (post 1.5.5 tag)
- Now supports windowed mode (Tested with virtual desktop, as long as the window has focus it should warp)
- New name for the engine! RawMac2
UPDATED: 17 March 2012 - New Wine 1.5
- Wine 1.5 Development is now available - Added new Links
Initial Public Release:
This is the latest wine from the trunk with:
Raw3.patch (enables mouse cursor for games that use Raw input)
RawWarpPatch (my change to the code because raw patch had limited mouse mouvement, it now warps the cursor around the x axis)
ATi Patch - Fixes all GLSL Shader problems (on SL / Lion at least)
Built --without-xinput2 because there is no proper support of xinput2 in osx and just breaks the cursor
plus this one has a partial implementation of wbem proxy, many games depend on that (i.e. NFS Hot Pursuit)
Wine 1.5.5 - RawMac2
Download from Mediafire
Download from Turbobit
Download SOURCE from Mediafire (1.5.7 tag)
Patch source:
--- a/dlls/user32/message.c
+++ b/dlls/user32/message.c
@@ -2366,9 +2366,11 @@
GUITHREADINFO info;
MOUSEHOOKSTRUCT hook;
BOOL eatMsg;
+ INT max_x;
/* find the window to dispatch this mouse message to */
+ max_x = GetSystemMetrics( SM_CXSCREEN );
info.cbSize = sizeof(info);
GetGUIThreadInfo( GetCurrentThreadId(), &info );
if (info.hwndCapture)
@@ -2379,6 +2381,19 @@
else
msg->hwnd = WINPOS_WindowFromPoint( msg->hwnd, msg->pt, &hittest );
+ // Risen 2 Patch
+ if (msg->pt.x < 10) {
+ USER_Driver->pSetCursorPos( (max_x - 11), msg->pt.y );
+ TRACE("THANOS: Hitting Left Edge:\n");
+ TRACE("Current X: %d\n", msg->pt.x);
+ TRACE("Current Y: %d\n", msg->pt.y);
+ else if (msg->pt.x > (max_x - 10)) {
+ USER_Driver->pSetCursorPos( 11, msg->pt.y );
+ TRACE("THANOS: Hitting Right Edge:\n");
if (!msg->hwnd || !WIN_IsCurrentThread( msg->hwnd ))
WINE VERSION 1.4
WINE VERSION 1.5
WINE VERSION 1.5 - WITH ATI SHADER FIX (THIS IS FULLY COMPATIBLE WITH nVidia / Intel)
Happy porting!
