Ever since my PC broke down and i bought an iMac (for art program purposes, something it does brilliantly), I have been struggling to play my favorite game of all time again; Vampire the Masquerade Bloodlines. I downloaded Wineskin after hearing it was one of the better ways to port games to a mac, got the Vampire "wrapper" from this site, and have ZERO idea on how to use either of them. I am pretty clueless when it comes to the finer points of computers, and am about one frustrating fail-session away from screeching and hitting my computer with a stick Stanley Kubrick style. Can anyone help? Is there a for-dummies guide to this? What steps, in the simplest possible terms, must I follow to play my precious game on this new system?
Thankyou in advance!
Help for a noob
Started By cowlevel, Apr 18 2012 12:45 AM
Posted 18 April 2012 - 12:45 AM
Posted 18 April 2012 - 12:54 AM
Ok first of all, wrappers are just for people who dont know how to port, its ok, your new so. First, in order to play that game, you must have a torrent or CD for that game, if you have the game from a torrent or CD, tell me so I can tell you what to do next.
Retired Mac Porter
(I dont port heavy games anymore, I only port small and simple games since i am now retired.)
Posted 18 April 2012 - 01:02 AM
( you will need the game files from a pc or wineskin installer to play the game)(game files not installation files )
simple right click wrapper and follow these instructions
Show package contents > contents > c_drive
copy your game folder into there & if you have the steam version apply the steam crack included with the wrapper (instructions for that in wrapper)
after you are done
close all windows & launch wrapper
done
hope this helped
Proud Supporter of the Infinity Engine Project
Sub-Moderator of Infinity Engine Section
Posted 19 April 2012 - 03:18 AM
I just got the game & this wrapper messed up my mac
its screwed up all the display settings ; Had to reboot to get it back to normal
I even used widescreen fix .
Chultz plz fix .. make the wrapper wineskin instead of ciderx
