Skyrim Green Screen Problem
Posted 02 May 2012 - 02:47 AM
Posted 02 May 2012 - 02:54 AM
Macbook Pro: Intel C2D 2.53ghz, 4GB Ram, Nvidia 9400m 256MB
Hackintosh: Intel i5-3570k, 16GB Ram, Asus Z77 Sabertooth, MSI GTX 670 Power Edition SLI
If my post helped you hit the like button ![]()
Posted 02 May 2012 - 04:11 AM
- Aela The Huntress This mod is found here: http://skyrim.nexusm...?id=14436&tab=3
- ApachiiSkyHair This mod is found here: http://skyrim.nexusm...d=10168#content
- Caleiente_Female_Body_Mod this mod is found here: http://skyrim.nexusm...ile.php?id=2666
- Camping This mod is found here: http://skyrim.nexusm...?id=11074&tab=3
- Dovakkin Race this mod is found here: http://skyrim.nexusm...le.php?id=16171
- The Eyes of Beauty This mod is found here: http://skyrim.nexusm...le.php?id=13722
- Handyman This mod is found here: http://skyrim.nexusm...p?id=9884&tab=3
- Lanterns_Of_Skyrim_Bridges this mod is found here: http://skyrim.nexusm...?id=11336&tab=3
- Lanterns of Skyrim roads this mod is found here: http://skyrim.nexusm...3&tab=3#content
- Lanterns of Skyrim Around Cities This mod is found here: http://skyrim.nexusm...?id=12451&tab=3
- Lets get Naked this mod is found here: http://skyrim.nexusm...le.php?id=11770
- Nude Females this mod is found here: http://skyrim.nexusm...php?id=70&tab=3
- Official CBBE FacePack this mod is found here in the downloads: http://skyrim.nexusm...ile.php?id=2666
- True Dragonblood Shout Cooldown This mod is found here: http://skyrim.nexusm...p?id=6692&tab=3
- Useable Lanterns this mod is found here: http://skyrim.nexusm...p?id=8835&tab=3
- Werewolf Second Howl this mod is found here: http://skyrim.nexusm...le.php?id=12017
- No werewolf Time limit this mod can be found here: http://skyrim.nexusm...6&tab=3#content
voidLetsGetNaked.esp
ApachiiHair.esm
TheEyesOfBeauty.esp
AelaTheHuntress.esp
AelaTheHuntress.bsa
DovahRace.esp
Craftable Greybeard Robes.esp
ArchRobe.esp
WerewolfSecondHowlToggle.esp
ShoutCD.esp
Lanterns Of Skyrim - Around Cities.esp
Lanterns Of Skyrim - Around Cities.bsa
Lanterns Of Skyrim - Bridges x2 - OnOff.bsa
Lanterns Of Skyrim - Bridges x2 - OnOff.esp
Lanterns on the Roads (50% less lanterns).esp
Usable lantern.esp
lt_camping.bsa
lt_camping.esp
HandyMan.esp
Infinite Werewolf.esp
Please let me know if this helps
Posted 02 May 2012 - 04:14 AM
Posted 02 May 2012 - 04:37 AM
#6
Posted 02 May 2012 - 04:38 AM
#7
Posted 02 May 2012 - 04:43 AM
#8
Posted 02 May 2012 - 04:45 AM
#9
Posted 02 May 2012 - 04:46 AM
#10
Posted 02 May 2012 - 04:48 AM
#11
Posted 02 May 2012 - 04:52 AM
#12
Posted 02 May 2012 - 04:57 AM
#13
Posted 02 May 2012 - 05:00 AM
#14
Posted 02 May 2012 - 05:03 AM
#15
Posted 02 May 2012 - 05:05 AM
#16
Posted 02 May 2012 - 05:08 AM
#17
Posted 02 May 2012 - 05:09 AM
#18
Posted 02 May 2012 - 05:12 AM
#19
#20
Posted 02 May 2012 - 05:36 AM
#21
Posted 02 May 2012 - 12:57 PM
#22
Posted 02 May 2012 - 08:48 PM
You could try to disable to depth of field to see if fix it or not. It might be the problem, it was for me and the following trick helped me :
In your Documents -> My Games -> Skyrim, find the skyrim.ini and open with notepad.
Then find the line
bDoDepthOfField=1
and change this value to 0
bDoDepthOfField=0
Save and exit.
This disable the depth of field effect, it doesn't have a big impact on the game and sometimes even improve performance when off.
Launch skyrim again and check if you could see underwater or not.
If it doesn't help you can easily just turn it on again by editing the ini and changing the value to 1 again.
Hope this work for you
#23
Posted 02 May 2012 - 08:50 PM
#24
Posted 02 May 2012 - 09:42 PM
#25
Posted 03 June 2012 - 08:13 PM
About "bDoDepthOfField" in "SkyrimPrefs.ini" in your "My Games" folder
"bDoDepthOfField=0" setting also makes underwater visible.
But you will lose your ENB settings of DoF.
And also it makes your underwater no color, and no blur.
So, I recommend you "bDoDepthOfField=1" when using my mod.
If you choose "bDoDepthOfField=0" setting, please deactivate my mod.
It doesn't need any more.
I did not think twice and have disabled the Depth, also did not use the MOD GreenWaterFix.
Note: I play on PC, not MAC, I registered to discuss the matter, I hope that solves your problem and perhaps more players.
#26
Posted 03 June 2012 - 08:30 PM
Then find the line
bDoDepthOfField=1
bDoDepthOfField=0
Save and exit.
#27
Posted 19 June 2012 - 09:20 AM
I have also crashed twice while under water with this "green screen" and those were the only times I've crashed. Could this have any correlation to the PS3 water bug as well?
Any help would be much appreciated.
#28
Posted 20 June 2012 - 07:18 AM
#29
Posted 09 December 2012 - 02:25 AM
go to /documents/my games/skyrim/skyrimPrefs
open the SkyrimPrefs file in a text editor.
find the line: bDoDepthOfField=1
and change it to:bDoDepthOfField=0
save and exit the file.
re-launch skyrim and ye shall see underwater!
Enjoy.
