I tried to create a wineskin wrapper for NFS2Unleashed, i used the 2.5.6 version of wineskin with 1.5.2 engine... it start normally, some glitches in the game starting video but the real problem is that the game stop on the loading screen of first race of campaign, you can hear the sound but the screen is always on the loading screen. Someone can help me???
Sorry for my english
Here the links to my wrapper:
Part 1: http://www.mediafire...4f1mum8uwf3s5hc
Part 2: http://www.mediafire...t8u5kh0ftv51fd8
10.8
9400m 256mb 2.26ghz macbook late 2009
fixme:thread:SetThreadIdealProcessor (0x124): stub
fixme:thread:SetThreadIdealProcessor (0x150): stub
fixme:system:SystemParametersInfoW Unimplemented action: 53 (SPI_SETTOGGLEKEYS)
fixme:system:SystemParametersInfoW Unimplemented action: 55 (SPI_SETMOUSEKEYS)
fixme:system:SystemParametersInfoW Unimplemented action: 59 (SPI_SETSTICKYKEYS)
fixme:system:SystemParametersInfoW Unimplemented action: 51 (SPI_SETFILTERKEYS)
fixme:system:SystemParametersInfoW Unimplemented action: 67 (SPI_SETHIGHCONTRAST)
fixme:thread:SetThreadIdealProcessor (0x158): stub
fixme:thread:SetThreadIdealProcessor (0x160): stub
fixme:thread:SetThreadIdealProcessor (0x164): stub
fixme:thread:SetThreadIdealProcessor (0x16c): stub
fixme:thread:SetThreadIdealProcessor (0x174): stub
fixme:thread:SetThreadIdealProcessor (0x17c): stub
fixme:thread:SetThreadIdealProcessor (0x184): stub
fixme:thread:SetThreadIdealProcessor (0x194): stub
fixme:win:EnumDisplayDevicesW ((null),0,0x32f8dc,0x00000000), stub!
fixme:thread:SetThreadIdealProcessor (0x198): stub
fixme:thread:SetThreadIdealProcessor (0x1d4): stub
fixme:win:EnumDisplayDevicesW ((null),0,0x32f73c,0x00000000), stub!
fixme:d3d:swapchain_init The application requested more than one back buffer, this is not properly supported.
Please configure the application to use double buffering (1 back buffer) if possible.
fixme:d3d:debug_d3dformat Unrecognized 0x434f5441 (as fourcc: ATOC) WINED3DFORMAT!
fixme:d3d:wined3d_get_format Can't find format unrecognized (0x434f5441) in the format lookup table
fixme:d3d:resource_check_usage Unhandled usage flags 0x8.
fixme:process:GetLogicalProcessorInformation (0x0,0x30e2e8): stub
fixme:thread:SetThreadIdealProcessor (0x2dc): stub
fixme:thread:SetThreadIdealProcessor (0x2f0): stub
fixme:thread:SetThreadIdealProcessor (0x2d8): stub
fixme:d3d9:Direct3DShaderValidatorCreate9 stub
fixme:win:RegisterDeviceNotificationW (hwnd=0x4002a, filter=0x32fbf4,flags=0x00000000) returns a fake device notification handle!
fixme:wbemprox:wbem_locator_ConnectServer 0x242a02a8, L"\\\\.\\root\\cimv2", (null), (null), (null), 0x00000000, (null), 0x0, 0x32fb6c)
fixme:thread:SetThreadIdealProcessor (0x308): stub
fixme:thread:SetThreadIdealProcessor (0x340): stub
fixme:thread:SetThreadIdealProcessor (0x42c): stub
fixme:keyboard:X11DRV_ActivateKeyboardLayout 0x4100410, 0000: semi-stub!
fixme:thread:SetThreadIdealProcessor (0x428): stub
fixme:thread:SetThreadIdealProcessor (0x470): stub
fixme:thread:SetThreadIdealProcessor (0x4fc): stub
Help with Need for Speed Shift 2 Unleashed
Started By Shaggot96, Aug 20 2012 04:07 PM
Posted 20 August 2012 - 04:07 PM
Vi prometto solo sudore, lacrime e sangue.
Winston Churchill
Winston Churchill
Posted 21 August 2012 - 12:31 PM
I've changed the engine with 1.5.11 and it works. Here the wrapper:
Part 1: http://www.mediafire...dv7c8eubbssb110
Part 2: http://www.mediafire...izrsdbyvikap0p5
Winston Churchill
Winston Churchill
Posted 20 December 2012 - 03:08 AM
I can confirm this wrapper as working but it took some testing to make sure it worked. I used the tpb version of the game and used the k that came along with it. You must select the EASetup.exe in order to get the installer to work and it pops up in Italian but it doesn't affect the game. Also, When extracting the wrapper from the zip file use the unarchiver because other programs do not extract it right.
I have Snow Leopard 10.6.8 with NVIDIA GeForce 320M
Thanks Shaggot!!
EDIT: During the races black squares pop up around the screen and quickly take over making the game unplayable. I did some research and this is prevalent on the pc as well so it is probably a problem with the game. I tried to update but i couldn't get the exe files open. If anyone has a fix for the black squares then let me know.
Thanks Shaggot!!
