DirectX10 capable Wine Engine
22 replies to this topic
#1 RastaFabi
RastaFabi
  • 59 posts
  • Graphics Card:Intel HD 4000, 1536MB dynamic, shared
    NVIDIA GTX 750Ti, 2048MB, eGPU (Thunderbolt)
Posted 08 October 2014 - 06:37 PM
Hello everybody!
I just came across a very interesting project. Someone has (finally) managed to enable DirectX10 in wine (although now there is some progress with every wine dev version), and did some test cases, including a demo video. However this does not mean that any DirectX10 enabled/only game will work. Although it would be interesting to test. The developer says the code need some cleanup and does use hacks to achieve the functionality, but never the less he did it. Take a look.
Now we just need someone to compile this engine (on mine machine it simply gets stuck - but other engines won't compile either).
I hope someone can build WS9Wine1.7.27_D3D10 soon!
Best,
Rastafabi
EDIT: Here's a relatively small (old) DirectX10 demo game (Lost Planet) to test the engine.
Posted 09 October 2014 - 06:32 AM
Well, I hope they get it sorted soon. Adding functionality should at least be easier when the basics are in place. CSMT is apparently also waiting for some of these changes to finish (see https://www.winehq.o...ber/105376.html).
#3 jerbiecastinlag
jerbiecastinlag
  • Graphics Card:intel HD Graphics 4000 512 MB
Posted 10 October 2014 - 03:35 AM
i hope they get it sorted soon , because i want to play nba 2k15 :D
#4 RastaFabi
RastaFabi
  • 59 posts
Posted 10 October 2014 - 04:20 AM
Well, it is sorted! We just need someone to compile this engine.
#5 jerbiecastinlag
jerbiecastinlag
Posted 10 October 2014 - 08:52 AM
if someone compile this engine , do you think we can play nba 2k15? :D
#6 ovvldc
Posted 10 October 2014 - 10:58 AM
Probably not. As indicated in the first post, D3D10 support is very much a work in progress.
But by all means give it a try and see how far you get :).
#7 doh123
Posted 10 October 2014 - 01:59 PM
the download link looks like normal Wine 1.7.27... but they have a patchset for it on the page. Looks like the patch needs to be applied, then compiled?
#8 doh123
Posted 11 October 2014 - 12:56 AM
I applied all the patches to 1.7.27 and built an engine.. I haven't actually tried using it yet... someone else can though.
https://dl.dropboxus...staller.app.zip
#9 RastaFabi
RastaFabi
  • 59 posts
Posted 11 October 2014 - 05:12 AM
Thank you very much, but I am afraid something went wrong... Not even the tutorials the engine was build for work, non of them. Could you recheck the engine, please?
#10 doh123
Posted 11 October 2014 - 11:51 AM
I don't know what there is to "recheck" ... just compiled code.  When people use hacks to get things to work, its likely it will only work on limited systems... and if they did it all in Linux, it could be totally broken on OS X.
#11 cluthz
  • 2,836 posts
Posted 14 October 2014 - 08:24 PM
Glad to see this out.
Wonder how much work has to be done to get it DX11.
Seems like dx11 is the industry standard now.
#12 ovvldc
Posted 15 October 2014 - 04:36 AM
DX11 is a superset of DX10, so much less work than from DX9 to DX10. But first thing's first ;).
#13 thedoc
thedoc
  • 1,311 posts
  • Graphics Card:nVidia GeForce 9600M GT - 512 MB RAM
  • I like to play:FPS, RPG, Racing
Posted 19 October 2014 - 11:28 PM
I added the DX10 build to my custom Wine builds archive here: https://www.mediafir...tom_wine_builds
Check out my Porting Blog @ Doc's Office
#14 Zephon
Zephon
  • 53 posts
  • Graphics Card:NVidia Geforce GTX 760
Posted 20 October 2014 - 02:15 PM
Hi thedoc,
Testing your Engine out for a couple of games. But it makes the Mac Driver unusable. This doesn't seem to be your fault but do you have any advice on how to fix this? I'm guessing this is a drawback of the stage this whole thing is in right now.
#15 thedoc
thedoc
  • 1,311 posts
Posted 20 October 2014 - 02:28 PM
I've been compiling my engines on a 10.6 machine with the old WS2.5.4v2 engine base to ensure 10.5 compatibility - it might be that this build enviroment renders the macdrv unusable since it preceded the macdrv implementation into Wine. Can you test if that problem also applied to the Custom PlayOnLinux Wine builds?
#16 Zephon
Zephon
  • 53 posts
Posted 21 October 2014 - 09:02 AM
Ah, I didn't noticed that, sorry. Unfortunately it is the same for the PlayOnLinux Builds. Tested it with a blank new wrapper as well as with some of my older ones.
#17 rgamer
rgamer
  • Graphics Card:intel hd graphics 5000 1024mb
Posted 29 October 2014 - 05:20 AM
i would love a custom d10 enigne since i am trying to get sid meier's civilization beyond earth to work on mac but no luck
#18 cluthz
  • 2,836 posts
Posted 29 October 2014 - 07:59 AM
Beyond Earth is DX11 only a DX10 engine won't do you much good.
Mac version is on the stairs tho:
http://www.firaxis.c...on-beyond-earth
Mac and Linux versions are coming soon.
#19 Slice
Posted 11 March 2015 - 04:13 AM
Tested this game with 1.7.38 engine. Crash immediately.
As well as with CX14.0.3 and with 1.7.27_DX10.
#20 ovvldc
Posted 12 March 2015 - 09:22 AM
Well, the disclaimer was that there is the beginnings of DX10 support, not that it was complete or suitable for any purpose other than unit tests..
#21 Slice
Posted 13 March 2015 - 07:56 AM
OK.
DirectX9 games and tests works fine. I see no issue.
Dx10/11 game Heroes VI works with some set of issues which I want to resolve.
The work is on the way.
#22 TheClutch
TheClutch
  • 11 posts
  • LocationLouisiana
  • Graphics Card:AMD Radeon HD 6770M 512 MB
  • I like to play:Garry's mod,Counter-Strike,Call of duty,battlefield,Shadow of mordor,gta,and much more...
Posted 13 March 2015 - 10:38 PM
Same here.Lost planet just crashed.
#23 ovvldc
Posted 22 June 2015 - 02:22 PM
FYI, it seems that there is some relief on the horizon. According to Codeweavers' James Ramey:
However, you might still be able to play these titles on your Mac or Linux computer when they are released later this year using CrossOver. In the coming months, CodeWeavers will have support for DirectX 11; better controller support; and further improvements to overall GPU performance."
(from https://www.codeweav...computer-gaming)
