Super Time Force Ultra (Help)
#1 Kn0x3r
Kn0x3r
  • Graphics Card:NVIDIA GeForce 9600M GT 256 MB
Posted 18 November 2014 - 04:05 AM
Hey guys, im new here in the forum, even though I've been following the website for a while now.
Sorry if this is an annoying question, if it has been asked before, etc., but i've been looking around and couldn't find any solution.
I've been trying to get the v1.01 of this to work with wineskin, but it never does.
Tried some whine tricks like instal different versions of the direct x but none worked.
If anyone as managed to get the game to work and wants to share how they did it, or any kind of helptwould be great.
Thank you guys, keep up with the awesome work!
Mac OS X 10.10.1
NVIDIA GeForce 9400M 256 MB - 2,66 GHz Intel Core 2 Duo
[3239224.656] WineskinX11 starting:
[3239224.656] X.Org X Server 1.13.0
[3239224.656] Build Date: 20120921
[3239224.656] _XSERVTransmkdir: ERROR: euid != 0,directory /tmp/.X11-unix will not be created.
[3239224.662] Initializing built-in extension Generic Event Extension
[3239224.662] Initializing built-in extension SHAPE
[3239224.662] Initializing built-in extension MIT-SHM
[3239224.662] Initializing built-in extension XInputExtension
[3239224.662] Initializing built-in extension XTEST
[3239224.662] Initializing built-in extension BIG-REQUESTS
[3239224.662] Initializing built-in extension SYNC
[3239224.662] Initializing built-in extension XKEYBOARD
[3239224.662] Initializing built-in extension XC-MISC
[3239224.662] Initializing built-in extension XINERAMA
[3239224.662] Initializing built-in extension PseudoramiX
[3239224.662] Initializing built-in extension XFIXES
[3239224.662] Initializing built-in extension RENDER
[3239224.662] Initializing built-in extension RANDR
[3239224.662] Initializing built-in extension DAMAGE
[3239224.662] Initializing built-in extension MIT-SCREEN-SAVER
[3239224.662] Initializing built-in extension DOUBLE-BUFFER
[3239224.662] Initializing built-in extension RECORD
[3239224.662] Initializing built-in extension X-Resource
[3239224.662] Initializing built-in extension XVideo
[3239224.662] Initializing built-in extension XVideo-MotionCompensation
[3239224.662] Initializing built-in extension GLX
[3239224.663] x: 0, y: 0, w: 1440, h: 877
[3239224.713] (II) GLX: Initialized Core OpenGL GL provider for screen 0
[3239225.153] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
Engine Used: WS9Wine1.7.29
Hardware:
    Hardware Overview:
      Model Name: MacBook Pro
      Model Identifier: MacBookPro5,3
      Processor Name: Intel Core 2 Duo
      Processor Speed: 2,66 GHz
      Number of Processors: 1
      Total Number of Cores: 2
      L2 Cache: 3 MB
      Memory: 8 GB
      Bus Speed: 1,07 GHz
      Boot ROM Version: MBP53.00AC.B03
      SMC Version (system): 1.48f2
      Sudden Motion Sensor:
          State: Enabled
Graphics/Displays:
    NVIDIA GeForce 9400M:
      Chipset Model: NVIDIA GeForce 9400M
      Type: GPU
      Bus: PCI
      VRAM (Total): 256 MB
      Vendor: NVIDIA (0x10de)
      Device ID: 0x0863
      Revision ID: 0x00b1
      ROM Revision: 3448
      gMux Version: 1.8.8
      Displays:
        Color LCD:
          Display Type: LCD
          Resolution: 1440 x 900
          Pixel Depth: 32-Bit Color (ARGB8888)
          Main Display: Yes
          Mirror: Off
          Online: Yes
          Built-In: Yes
    NVIDIA GeForce 9600M GT:
      Chipset Model: NVIDIA GeForce 9600M GT
      Type: GPU
      Bus: PCIe
      PCIe Lane Width: x16
      Device ID: 0x0647
      Revision ID: 0x00a1
      ROM Revision: 3448
      gMux Version: 1.8.8
fixme:heap:HeapSetInformation 0x0 1 0x0 0
fixme:wbemprox:client_security_SetBlanket 0x44176548, 0x199670, 10, 0, (null), 3, 3, 0x0, 0x00000000
fixme:wbemprox:client_security_Release 0x44176548
fixme:wbemprox:enum_class_object_Next timeout not supported
fixme:win:EnumDisplayDevicesW ((null),0,0x32cbec,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),0,0x32f40c,0x00000000), stub!
fixme:d3d:wined3d_check_device_format_conversion wined3d 0x1a0a90, adapter_idx 0, device_type WINED3D_DEVICE_TYPE_HAL, src_format WINED3DFMT_B8G8R8X8_UNORM, dst_format WINED3DFMT_B8G8R8X8_UNORM stub!
fixme:win:RegisterDeviceNotificationA (hwnd=0x20044, filter=0x32fc88,flags=0x00000004) returns a fake device notification handle!
fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0x32fb6c 1 C) semi-stub
fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0x32f90c 1 C) semi-stub
fixme:avrt:AvSetMmThreadCharacteristicsW (L"Audio",0xa72f618): stub
fixme:xinput:XInputGetState (0 0x3435088)
wine: Unhandled page fault on read access to 0x00000034 at address 0x4368e6ba (thread 0009), starting debugger...
#2 Flanella
Flanella
  • Graphics Card:NVIDIA GeForce GT 750M
Posted 16 April 2015 - 01:38 PM
Working fine with the WS9Wine1.7.40 engine, just install Steam and launch it from there. Cheers!
