WS9WineCX14.0.3 double buffer ... please help!!!
9 replies to this topic
#1 dankoB
  • 3012 posts
Posted 03 January 2015 - 03:36 PM
Hi everyone, hoping someone here will be able to help me out! I am having major issues while trying to build engines using Wineskin Winery. GCC4.2 keeps failing and it won't even start the process
Can someone please compile this engine for me so I can stop pulling out my hair!!!!
http://www.mediafire...oddscs/wine.zip
It's already been patched and totally ready to be built by WineskinWinery. Please help me someone!
  • 3012 posts
Posted 03 January 2015 - 11:46 PM
Nevermind...command line tools was not already part of the XCode 6.1.1 package and not visible for download in the preferences/downloads window. The extra resources need to be downloaded directly from the apple developers page...my bad.
https://developer.ap...ds/index.action
#3 ovvldc
  • 1267 posts
Posted 04 January 2015 - 09:34 AM
Glad you solved it :).
How is the engine working? Anything solved that you used to have problems with?
#4 dankoB
  • 3012 posts
Posted 04 January 2015 - 05:28 PM
Naw, unfortunately it didn't help. I'm trying to port the FakeFactory HL2 Cinematic Mod 2013 and there seems to be a memory leak but I have a patched CX13 engine that runs it fine although there is an issue with a thin diagonal line that forms on the screen. It's really quite annoying and the performance is less desirable than what I'd prefer. If I knew of a cider wrapper with vcrun2010 built in I try to port it using that.
edit...I was having issues with the CX engine and successfully built a patched 1.7.33...the CX build failed while building programs/winedbg for some reason (I'm guessing something was changed in the CX source) I decided to to switch out the CX14.0.3 wine/programs/winedbg folder for that of 1.7.33 and the build finished successfully....about to give it a go....hope the performance is better!
#5 ovvldc
  • 1267 posts
Posted 05 January 2015 - 01:21 PM
Fingers crossed ;).
#6 dankoB
  • 3012 posts
Posted 06 January 2015 - 07:16 AM
No dice! But it works better on my 17GB, heavily modded Fallout 3!!!
#7 ovvldc
  • 1267 posts
Posted 06 January 2015 - 12:51 PM
Well that's something to show for your efforts.. I'll try the CX14 engine on my moderately modded Skyrim when I get home :).
#8 ovvldc
  • 1267 posts
Posted 12 January 2015 - 10:35 AM
I used the CX14 engine on my Skyrim and it works very well. I just have one gripe: with the Wine 1.7.24 engine with multithreaded rendering, I could cmd-tab out of my Wine application without problem. Now with the CX14 engine, I briefly land on my desktop, and then a minimised app window pops out of the dock and I am in fullscreen mode again. I tried to set WindowsFloatWhenInactive to none in the registry, but that didn't help :(. Would anyone have a suggestion on how to handle that?
#9 darklord42
darklord42
  • 151 posts
Posted 15 February 2015 - 04:32 AM
I managed to compile CX14.0.3 as a wineskin engine.  I used the patches from the macports port to get it to compile.
https://dl.dropboxus...CX14.0.3.tar.7z
#10 Slice
Posted 19 February 2015 - 08:51 AM
This version works, thanks! While official release 1.7.36 not.
I also tried compile 1.7.36 from git.
System OSX10.7.5, XCode 4.4.1
Installed llvm-gcc4.2 by macport. AFAIK it is only working compiler for this project.
Installed dependencies.
./configure --prefix=/opt/local CC=llvm-gcc
make
sudo make install
Then I gathered files into wswine.bundle. No, it is not working...
Tell me, please, what tricks else I should apply?
Where can I get patches to sources?
