How To Search for Words?
#1 JawWilks
JawWilks
  • Graphics Card:Amd 256mb
Posted 05 April 2015 - 12:47 AM
I'm using a piece of software that has text in an area that I want to hide/remove. How would I go about doing this using Bit Slicer? Thanks.
#2 Zorg
Zorg
  • 147 posts
  • LocationSpace
  • Graphics Card:I don't know.
  • I like to play:Arcade, Side Scrollers
Posted 05 April 2015 - 02:14 AM
I'd try searching with the Strings data types.
#3 JawWilks
JawWilks
Posted 05 April 2015 - 09:23 PM
I searched using the Strings data type and found the text. Now how do I stop the text from showing up in the program that I'm using? I'm completely new to this, sorry.
#4 Zorg
Zorg
  • 147 posts
  • LocationSpace
Posted 05 April 2015 - 10:28 PM
Then you can try to double click on the value and modify it to be empty. Note that the application may not update drawing the text all the time, so this may not work as you plan. You may have to trigger the application to update the text for example.
