Weird Gaphical Artifacts On Dirt 1
7 replies to this topic
#1 pazi11
pazi11
  • 6 posts
  • Graphics Card:Intel HD Graphics 4000
Posted 04 May 2015 - 04:52 PM
I have this weird issue on Dirt 1 where all the vehicles have tiny black spots on them.(Which turns the car black.)
Any help? :( Screenshots:
Note:All other games ive tested work flawlessly,its just this one.
  • 3,013 posts
Posted 05 May 2015 - 10:33 PM
Try disabling some of the advanced video option in the the Games menu. Sometimes that will cause issues like this. You can also try to run some of the direct3d settings in Winetricks > Settings
#3 pazi11
pazi11
  • 6 posts
Posted 08 May 2015 - 03:39 PM
Ill try that thanks.
#4 pazi11
pazi11
  • 6 posts
Posted 08 May 2015 - 03:47 PM
Where is Winetricks?I cant seem to find it...Also im using Cider.
#5 dankoB
  • 3,013 posts
Posted 09 May 2015 - 02:53 PM
Ah...no Winetricks in Cider. Have you tried porting it with Wineskin? The AppDB states that it is garbage but all of the tests are with older versions of wine. Might be worth a shot.
#6 pazi11
pazi11
  • 6 posts
Posted 16 May 2015 - 08:11 PM
I did try but it kept crashing on me on the Dirt splash screen thingy.And I know the issue,my graphics card hates special effects,I will try to turn them off.(I mean the issue with the black pixels on the cars.)
#7 pazi11
pazi11
  • 6 posts
Posted 16 May 2015 - 08:58 PM
Tried to turn off the HDR effect and with no luck,that did nothing.
#8 nobita1994
nobita1994
  • 136 posts
  • Graphics Card:i funny
Posted 16 April 2021 - 09:38 AM
Often times, we get confused when we finally hear the exact term of website development services apart from the internet developer being used interchangeably. But the thought is broken when you look at this, all your personal confusion can disappear. atari breakout
