Custom Build Error
#1 1Leonard
1Leonard
  • 19 posts
  • Graphics Card:Intel HD Graphics 4000 1024 MB
Posted 10 May 2015 - 08:09 AM
Hi All,
I've been trying to make a new wine engine from a patched source of 1.7.42 but I've been getting the same error for the whole day. It just says that "An error occurred during Wine Make, build halted." It Always happens at the same spot:
-doleaut32 -lwine \
  ../../libs/port/libwine_port.a -L/tmp/Wineskin/lib
Cleaning up changes made for the build, if any...
logout
[Process completed]
The whole log: http://www.mediafire...al_Saved_Output
(I have applied the patch found here)
#2 Slice
Posted 10 May 2015 - 08:36 AM
1.
Install gettext
configure: WARNING: gettext tools not found (or too old), translations won't be built.
2. Install libxml2.2dylib for 32bits
ld: warning: ignoring file /Users/Lennart/anaconda/lib/libxml2.dylib, file was built for x86_64 which is not the architecture being linked (i386): /Users/Lennart/anaconda/lib/libxml2.dylib
ld: warning: ignoring file /Users/Lennart/anaconda/lib/libz.dylib, file was built for x86_64 which is not the architecture being linked (i386): /Users/Lennart/anaconda/lib/libz.dylib
Undefined symbols for architecture i386:
  "_htmlDocContentDumpOutput", referenced from:
	  _node_transform_write in node.o
  "_htmlNodeDumpFormatOutput", referenced from:
  "_htmlSetMetaEncoding", referenced from:
  "_valuePush", referenced from:
	  _XSLPattern_OP_IGEq in selection.o
	  _XSLPattern_OP_IGt in selection.o
#3 1Leonard
1Leonard
  • 19 posts
Posted 10 May 2015 - 08:58 AM
View PostSlice, on 10 May 2015 - 08:36 AM, said:
1.
Install gettext
Thanks! Now I know what causes the interference,
I'm afraid that if I install these packages there will be another interference with a program I have to use for school (anaconda).
Can anyone compile a wine engine with the latest source and the patch found here?
#4 Slice
Posted 11 May 2015 - 06:16 PM
It will be better you'll link into the topic.
