Base address + offset help
#1 ajuni7
ajuni7
  • Graphics Card:Intel Iris Graphics 6100 1536 MB
Posted 27 June 2015 - 03:30 PM
I am trying to use bit slicer for a game called Stronghold 3. I am a fairly high level programmer. When I try to find -what address tries to write- into my found Float variable (Wood count) I am bit stuck as to what is next.
I've seen several cheat engine tutorials where you see something like '[esi+64]' I know what to do from here. However I just see something like [esi] without an offset and am stuck. I've tried an offset of 0 but that doesn't get me anywhere. Its certainly not static and changes after each restart.
Hope you can help
#2 Zorg
Zorg
  • 147 posts
  • LocationSpace
  • Graphics Card:I don't know.
  • I like to play:Arcade, Side Scrollers
Posted 27 June 2015 - 09:41 PM
I presume the value inside esi is the address of your float variable. You will want to find a pointer/reference to this address. You can try to search for a pointer to that value (may only work if there is a reference pointing directly to it). Or you can try to show the code in the debugger/disassembler and analyze the code, to see where it wrote the value into esi.
