Problem with running the game "Dying Light"
19 replies to this topic
#1 Dying Light
Dying Light
  • Graphics Card:NVIDIA GeForce GTX 660M
Posted 26 August 2015 - 06:34 PM
Hi guys!
Have the following problem: I download the game for Windows ("Dying Light") and than as I understood I follow such steps in Wineskin Winery:
1. I create new blank wrapper with the 1.7.50 engine.
2. I open the adjusting .exe file and put in "C" folder.
3. Than I wait when the game finally executes and mark the root to open .exe file (WINDOWS EXE in Wineskin Advanced).
4. After that I set my screen option to the fullscreen (Use mac driver and use 3D direct boost are unmarked) and make a test run.
5. After the test run I've got my screen black for few secs and the following report:
err:process:create_process L"C:\\Program Files\\R.G. Freedom\\Dying Light\\DyingLightGame.exe" not supported on this installation (x86_64 binary)
wine: Bad EXE format for C:\Program Files\R.G. Freedom\Dying Light\DyingLightGame.exe.
fixme:ole:RemUnknown_QueryInterface No interface for iid {00000019-0000-0000-c000-000000000046}
AND
WineskinX11: main(): argc=10
WineskinX11: do_start_x11_server(): argc=10
[1797812.702] WineskinX11 starting:
[1797812.702] X.Org X Server 1.13.0
[1797812.702] Build Date: 20120921
[1797812.702] _XSERVTransmkdir: ERROR: euid != 0,directory /tmp/.X11-unix will not be created.
[1797812.703] Initializing built-in extension Generic Event Extension
[1797812.703] Initializing built-in extension SHAPE
[1797812.703] Initializing built-in extension MIT-SHM
[1797812.703] Initializing built-in extension XInputExtension
[1797812.703] Initializing built-in extension XTEST
[1797812.703] Initializing built-in extension BIG-REQUESTS
[1797812.703] Initializing built-in extension SYNC
[1797812.703] Initializing built-in extension XKEYBOARD
[1797812.703] Initializing built-in extension XC-MISC
[1797812.703] Initializing built-in extension XINERAMA
[1797812.703] Initializing built-in extension PseudoramiX
[1797812.703] Initializing built-in extension XFIXES
[1797812.703] Initializing built-in extension RENDER
[1797812.703] Initializing built-in extension RANDR
[1797812.703] Initializing built-in extension DAMAGE
[1797812.703] Initializing built-in extension MIT-SCREEN-SAVER
[1797812.703] Initializing built-in extension DOUBLE-BUFFER
[1797812.703] Initializing built-in extension RECORD
[1797812.703] Initializing built-in extension X-Resource
[1797812.703] Initializing built-in extension XVideo
[1797812.703] Initializing built-in extension XVideo-MotionCompensation
[1797812.703] Initializing built-in extension GLX
[1797812.704] x: 0, y: 0, w: 2560, h: 1417
[1797812.751] (II) GLX: Initialized Core OpenGL GL provider for screen 0
[1797812.751] [dix] Could not init font path element /opt/X11/share/fonts/75dpi, removing from list!
[1797812.751] [dix] Could not init font path element /opt/X11/share/fonts/100dpi, removing from list!
[1797812.751] [dix] Could not init font path element /opt/X11/share/fonts/cyrillic, removing from list!
[1797812.751] [dix] Could not init font path element /opt/X11/share/fonts/misc, removing from list!
[1797812.751] [dix] Could not init font path element /opt/X11/share/fonts/OTF, removing from list!
[1797812.751] [dix] Could not init font path element /opt/X11/share/fonts/Speedo, removing from list!
[1797812.751] [dix] Could not init font path element /opt/X11/share/fonts/TTF, removing from list!
[1797812.751] [dix] Could not init font path element /opt/X11/share/fonts/Type1, removing from list!
[1797812.751] [dix] Could not init font path element /opt/X11/share/fonts/util, removing from list!
[1797814.832] x: 0, y: 0, w: 2560, h: 1440
Engine Used: WS9Wine1.7.50
Hardware:
Hardware Overview:
  Model Name: iMac
  Model Identifier: iMac13,2
  Processor Name: Intel Core i5
  Processor Speed: 2.9 GHz
  Number of Processors: 1
  Total Number of Cores: 4
  L2 Cache (per Core): 256 KB
  L3 Cache: 6 MB
  Memory: 8 GB
  Boot ROM Version: IM131.010A.B08
  SMC Version (system): 2.11f14
Graphics/Displays:
NVIDIA GeForce GTX 660M:
  Chipset Model: NVIDIA GeForce GTX 660M
  Type: GPU
  Bus: PCIe
  PCIe Lane Width: x16
  VRAM (Total): 512 MB
  Vendor: NVIDIA (0x10de)
  Device ID: 0x0fe0
  Revision ID: 0x00a2
  ROM Revision: 3707
  Displays:
iMac:
  Display Type: LCD
  Resolution: 2560 x 1440
  Pixel Depth: 32-Bit Color (ARGB8888)
  Main Display: Yes
  Mirror: Off
  Online: Yes
  Built-In: Yes
Any ideas what to do? I would be really glad to hear any!
Thanks in advance.
Posted 26 August 2015 - 07:44 PM
You are using the 64-bit version, and Wine only works with the 32-bit version...
#3 Dying Light
Dying Light
Posted 26 August 2015 - 08:15 PM
Thanks for your respond. Is there any way to solve this problem?
#4 ovvldc
Posted 26 August 2015 - 09:00 PM
Probably, but I don't personally know much about the game. I just read the error message.
#5 Dying Light
Dying Light
Posted 26 August 2015 - 09:54 PM
Well, you are right. The game requires Win 7, Vista or 8, all 64 bit. If you need any further info I'll tell you. I'm glad for your assistance:)
#6 Dying Light
Dying Light
Posted 26 August 2015 - 09:55 PM
I mean, can I get 64 bit Wine somehow?
#7 dankoB
Posted 27 August 2015 - 05:53 AM
Not at the moment but if you look at this thread we have some dedicated forum users (Slice and darklord42) that are working at getting 64bit Wine running for Mac.
http://portingteam.c...ine-64bit-news/
Sixty-four bit implementation is available through Linux distributions but unfortunately Wine team hasn't focused too much on the Mac implementation of it...
Unfortunately there's also the DirectX 11 hurdle to get across...Dying Light relies solely on DX11 with no support for DX9...so even with 64bit Wine implemented for Mac we need to have DX11 implementation in order to run games such as Dying Light, Crysis 3, Sleeping Dogs, Wolfenstein: A New Order...etc...etc...ect...
So it's still a bit of waiting game...but at least there's a light at the end of the tunnel.
#8 Taro Boy
Taro Boy
  • Graphics Card:NVIDIA GeForce GT 755M 1024 MB
Posted 08 January 2016 - 09:41 PM
I got the same problem too :/. Would be appreciated if anyone has found a solution to this yet.
LastRunWine.log
err:process:create_process L"C:\\Program Files\\R.G. Mechanics\\Dying Light\\DyingLightGame.exe" not supported on this installation (x86_64 binary)
wine: Bad EXE format for C:\Program Files\R.G. Mechanics\Dying Light\DyingLightGame.exe.
LasRunX11.log
[590021.788] WineskinX11 starting:
[590021.788] X.Org X Server 1.13.0
[590021.788] Build Date: 20120921
[590021.788] _XSERVTransmkdir: ERROR: euid != 0,directory /tmp/.X11-unix will not be created.
[590021.841] Initializing built-in extension Generic Event Extension
[590021.841] Initializing built-in extension SHAPE
[590021.841] Initializing built-in extension MIT-SHM
[590021.841] Initializing built-in extension XInputExtension
[590021.841] Initializing built-in extension XTEST
[590021.841] Initializing built-in extension BIG-REQUESTS
[590021.841] Initializing built-in extension SYNC
[590021.841] Initializing built-in extension XKEYBOARD
[590021.841] Initializing built-in extension XC-MISC
[590021.841] Initializing built-in extension XINERAMA
[590021.841] Initializing built-in extension PseudoramiX
[590021.841] Initializing built-in extension XFIXES
[590021.841] Initializing built-in extension RENDER
[590021.841] Initializing built-in extension RANDR
[590021.841] Initializing built-in extension DAMAGE
[590021.841] Initializing built-in extension MIT-SCREEN-SAVER
[590021.841] Initializing built-in extension DOUBLE-BUFFER
[590021.841] Initializing built-in extension RECORD
[590021.841] Initializing built-in extension X-Resource
[590021.841] Initializing built-in extension XVideo
[590021.841] Initializing built-in extension XVideo-MotionCompensation
[590021.841] Initializing built-in extension GLX
[590021.841] x: 0, y: 0, w: 2560, h: 1417
[590022.265] (II) GLX: Initialized Core OpenGL GL provider for screen 0
[590024.778] noPseudoramiXExtension=0, pseudoramiXNumScreens=1
Engine Used: WS9Wine1.7.38
Hardware:
    Hardware Overview:
      Model Name: iMac
      Model Identifier: iMac14,2
      Processor Speed: 3.2 GHz
      L3 Cache: 6 MB
      Memory: 8 GB
      Boot ROM Version: IM142.0118.B11
      SMC Version (system): 2.15f7
Graphics/Displays:
    NVIDIA GeForce GT 755M:
      Chipset Model: NVIDIA GeForce GT 755M
      Type: GPU
      Bus: PCIe
      VRAM (Total): 1024 MB
      Device ID: 0x0fea
      Revision ID: 0x00a2
      ROM Revision: 3782
      Displays:
        iMac:
          Display Type: LCD
          Main Display: Yes
          Mirror: Off
          Online: Yes
          Built-In: Yes
#9 NRG
  • 682 posts
Posted 09 January 2016 - 12:33 PM
It's obvious that you haven't read the thread ...
the game requires directx11 and Windows 64bit.
Wine/Wineskin (for mac) support at the moment only 32bit software and directx9.0
#10 ovvldc
Posted 09 January 2016 - 07:33 PM
Check back next year (fingers crossed).
#11 Taro Boy
Taro Boy
Posted 11 January 2016 - 11:10 AM
Of course I didn't read the thread! I simply jumped to conclusions to see if there are any solutions out there to this problem :/.
#12 ovvldc
Posted 12 January 2016 - 09:10 AM
Patience, my young padawan.
#13 Taro Boy
Taro Boy
Posted 12 January 2016 - 11:52 PM
Haha, sorry man :P. Yeah, I just really want to play this game so bad! Lol. Until next time ;).
#14 Slice
Posted 13 January 2016 - 07:40 AM
Sure?
Did you read the forum?
Did you follow news?
#15 NRG
  • 682 posts
Posted 13 January 2016 - 10:42 AM
View PostSlice, on 13 January 2016 - 07:40 AM, said:
Sure?
If you have a 64bit engine that it make possible to play the game requested in this thread you are welcome...
#16 Slice
Posted 15 January 2016 - 09:35 AM
The link is in my thread. Test if you want.
#17 dankoB
Posted 15 January 2016 - 02:11 PM
Which engine do you have configured that might possibly work on a 64 bit, DX11game? I don't remember seeing that posted at all.
#18 NRG
  • 682 posts
Posted 19 January 2016 - 08:34 PM
you are not the only one
#19 Slice
Posted 23 January 2016 - 12:48 PM
The problem is not in 64bit as you said.
The problem is in dx11 that is not fully supported by wine 32 or 64 bit.
#20 dankoB
Posted 23 January 2016 - 03:59 PM
Unfortunately if DX11 was fully implemented, the 64bit system requirement would still pose an issue.
