script question
#1 turtelpower
turtelpower
  • Graphics Card:ATI Radeon HD 4850 512 MB
Posted 04 September 2015 - 07:41 AM
hello all,
first so u no im new to this and like to learn.
im having some question about bit slicer i can search and change the aob's, but now i like to make a script/trainer that search the aob and change them to the new value.
i did some search on google etc but cant find any tutorial for it , i did see the wiki but it is not helping me any further on how to do it.
so do one of u have any tut or link that explains how to make one.
thanks
#2 Zorg
Zorg
  • 147 posts
  • LocationSpace
  • Graphics Card:I don't know.
  • I like to play:Arcade, Side Scrollers
Posted 05 September 2015 - 01:27 AM
Perhaps this will help you in the right direction:
#AOB Scan
#Introduction to scripting: https://github.com/zorgiepoo/Bit-Slicer/wiki/Introduction-to-Scripting
from bitslicer import VirtualMemoryError, DebuggerError
ORIGINAL_BYTES = bytes([0x0A, 0x74, 0x16, 0xA1, 0x24, 0xD0, 0x01, 0x00, 0x89])
class Script(object):
	def __init__(self):
		addresses = vm.scanBytes(ORIGINAL_BYTES)
		# Or...
		# addresses = vm.scanByteString("0A 74 16 A1 24 D0 01 00 89")
		self.address = addresses[0]
		debug.log(hex(self.address))
		vm.writeBytes(self.address, bytes([0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]))
	def finish(self):
		#revert bytes back if needed
		vm.writeBytes(self.address, ORIGINAL_BYTES)
Refer to Scripting Functions for all the functions available, and also the introduction to get started. It may involve a little figuring out on your own, since a straight out tutorial won't be available for every kind of thing.
#3 turtelpower
turtelpower
Posted 05 September 2015 - 10:38 AM
ok thanks will try this when i get home and do some more reading
