Best settings for 15" Retina MBP mid-2012?
#1 themacmeister
themacmeister
  • 30 posts
  • LocationOz
  • Graphics Card:2GB NVIDIA GeForce GTX 670
  • I like to play:2D, abstract schmups, casual games, 2D/3D platformers
Posted 14 July 2016 - 05:37 AM
I have been having issues with my new MBP Retina. All my copied over games are dead, even with updating engines/wrapper/replacing drive_c alias... These games ran on same OS on 2013 iMac (Iris Pro graphics).
I am using gfxCardStatus to lock NVIDIA graphic on, and selecting Low Resolution/32Bit mode in info for the wrapper.
Am I going to have to recreate ALL my WineSkin games?
Mac OS X 10.10.5
MacBookPro 15" mid-2012 Retina, 16GB RAM, 1TB SSD, Intel HD 4000/GeForce650m
no errors, just wanting some guidance ;-)
#2 NRG
  • 680 posts
Posted 14 July 2016 - 08:00 AM
to update your old wrappers you need this procedure:
http://portingteam.c...tall-mac-os-r56
#3 themacmeister
themacmeister
  • 30 posts
  • LocationOz
Posted 16 July 2016 - 04:00 AM
Thanks NRG, but I am only using 10.10.5, and all these wrappers work on 10.10.5 on my iMac and Hackintosh running 10.10.5 ?!?!
#4 dankoB
  • 3012 posts
Posted 16 July 2016 - 02:53 PM
What Wine version are you using?
It's could likely be due to the game's settings. If you locate each of the games configuration files (usually in the same place as the save files) and delete them so the game can configure itself to the new hardware specs it might solve the problem.
#5 themacmeister
themacmeister
  • 30 posts
  • LocationOz
Posted 28 July 2016 - 04:07 AM
I have just managed to run a simple app (Irfan View), so may need to manually recreate wrappers... not too bad, but a lot of configuration and copying files... worth it in the end. :-)
