CrossOver engine 15.3.1 (WS9WineCX15.3.1)
11 replies to this topic
#1 NRG
  • 682 posts
Posted 21 September 2016 - 06:29 AM
edit: 5 Oct 2016 [new little update]:
changelog...
#2 darklord42
darklord42
  • 151 posts
Posted 21 September 2016 - 01:46 PM
Does anyone have any idea which version of wine this coincidences with?  I wonder if it can be built 64bit now?
#3 NRG
  • 682 posts
Posted 21 September 2016 - 01:59 PM
1.8.4
#4 darklord42
darklord42
  • 151 posts
Posted 22 September 2016 - 02:33 AM
Ah makes sense, thanks!
#5 Incredible Hulk
Incredible Hulk
  • 185 posts
  • Graphics Card:6750M, OSX 10.12.2
  • I like to play:PES, COD, Grid, FNV, RO
Posted 04 October 2016 - 08:27 PM
View PostNRG, on 21 September 2016 - 06:29 AM, said:
Thanks for this especially as doh123 don't update Codeweavers engines regularly. Change log doesn't tell much but 15.3.0 works fantastic across the board.
#6 NRG
  • 682 posts
Posted 04 October 2016 - 10:30 PM
I'm to upload the new 15.3.1 version
#7 NRG
  • 682 posts
Posted 04 October 2016 - 11:15 PM
changelog...
#8 LordCruaver
LordCruaver
  • Graphics Card:AMD Radeon HD 6750M 512 MB
Posted 30 October 2016 - 06:53 AM
I seem to be getting some odd Audio Crackling when using the 15.3.1 engine.
Engine Usage: Wrapper to operate steam, error noticed in Skyrim audio.
Edit:
Result was because of using Windows 10 base instead of Windows XP. Perhaps it could be part of your next work to make a windows 10 usable. Or perhaps not, depends if you got the time and desire.
#9 NRG
  • 682 posts
Posted 30 October 2016 - 08:05 AM
Edit:
Sorry but it's not depend by me; It depends by Codeweavers releases...
Regarding me, I only compiled  their wine's engine to make it available for wineskin
However actually there isn't any valid reason to use windows10 as default system in the wineskin's configuration pannel, expecially if a game is old  and if it was released  also for previous versions of Windows, it's always better use the same Windows version for a better compatibility...
#10 Josander
Josander
  • 96 posts
  • Graphics Card:AMD Radeon HD 7970 3072 MB
  • I like to play:Bethesda games
Posted 09 November 2016 - 02:09 PM
not sure if its a hot iron, or bothering question, and i echo the same ingenuous question like darklord42 :  I wonder if it can be built 64bit now?
#11 Incredible Hulk
Incredible Hulk
  • 185 posts
Posted 27 November 2016 - 02:14 PM
Crossover 16 will be 64-bit
#12 Incredible Hulk
Incredible Hulk
  • 185 posts
Posted 27 November 2016 - 02:17 PM
Tip to update Crossover engines with latest wine libraries for best Wineskin expirience
- right click your wine app -> Show Package Contents
go to … Contest/ Frameworks
Find at the bottom “wswine.bundle” (that’s the actual wine engine)
right click it -> Show Package Contents
Inside You have bin, lib and share folder
- Go to lib folder and delete all files except wine folder (lib/wine)
- Go to share folder and delete all folders except wine folder (share/wine)
- Download latest Mac Wine tarball:
https://dl.winehq.or...x/download.html
- uncompress downloaded file and go to usr folder
(btw. - if you put version file inside and rename this folder to wswine.bundle you’ll get actual wineskin engine)
- Move all files except wine folders from usr/lib and usr/share from Your uncompressed Mac Wine tarball to appropriate folders in wineskin engine. (It can’t hurt if You copy lib64 folder also)
Run Your app
