How to deal with variable offsets in bits?
#1 djbell
djbell
  • Graphics Card:Intel Iris Graphics 6100 1536 MB
Posted 21 March 2017 - 05:07 PM
Hey all, I've been breaking games since around 1993, and figure it's time to step up my game a little, with the help of BitSlicer.
With flash games, a lot of variables have a 3-bit prefix, and that prefix isn't always the same. Sometimes it's 0, sometimes it's 6, whatever. Whatever it is, modifying it blows up the browser.
With CheatEngine, I can do a "Binary" search which is slow but handy, and then I can define an offset and length in the search results. In BitSlicer, I have two issues.
First, I have I figure out the prefix, often by guessing or just doing it first in CheatEngine. Any way to avoid guessing 1-8 times?
Second, once I nail down my pointer, can I view it with an offset of 3 bits?
It's awesome that BitSlicer is smart enough to deal with a search with *8+X, and that probably gives me something to experiment with in scripting, but I'm curious if I'm doing all of this in the most efficient way possible.
Thanks!
#2 Mr. Orange
Mr. Orange
  • Graphics Card:NVIDIA GTX 970 OC
Posted 31 March 2017 - 08:17 AM
My approach would be scripting. I would try to find a pointer that hold the prefix that you're looking for. Also, you can use offsets in the address field of a variable.
Example:
[0x11231231 + 0x6]
Where 0x6 is your offset, and 0x11231231 is your base.
