Wineskin won't start on mojave
9 replies to this topic
#1 Nemexya
Nemexya
  • Graphics Card:Intel Iris Plus Graphics 640 1536 MB
Posted 25 July 2019 - 07:55 AM
Hi everyone,
I discovered wineskin yesterday, I've been using Wine for a while to open Windows games / app.
I tried to make wineskin work on my mac but when i put the app in the wrapper and try to launch it, nothing happens.
I have the icon with the wrapper open on my dock but nothing is showing at all.
If I run a test run, nothing will happen and it'll ask me if I want to look at the log but even then, the log won't show, TextEdit will stay on the dock trying to start but nothing will happen.
I don't know what I need to do to make something work.
I'm on macOS Mojave 10.14.5 and my GPU is Intel Iris Plus Graphics 640 1536 MB.
Thanks in advance.
  • 1253 posts
Posted 25 July 2019 - 08:32 AM
How exactly did you 'put the app in the wrapper'? You need to be a lot more specific.
#3 Nemexya
Nemexya
Posted 25 July 2019 - 08:42 AM
I create a "new blank wrapper", then I open it. I then have 3 options, right?
1. Install Software
2. Set Screen options
3. Advanced
So after "installing" the software, in my case, it's copying a folder, I just need to run the wrapper to start the app or not?
If so, it doesn't start (it works using Wine alone though) otherwise what did I do wrong?
Sorry for the inconvenience.
#4 ovvldc
  • 1253 posts
Posted 25 July 2019 - 08:56 AM
Did you select the right Windows EXEcutable in the wrapper (under 'advanced'), so that it knows what to run?
#5 Nemexya
Nemexya
Posted 25 July 2019 - 08:59 AM
Yes
#6 ovvldc
  • 1253 posts
Posted 25 July 2019 - 09:12 AM
Which version of Wineskin wrapper and engine are you using? What app are you trying to install?
#7 Nemexya
Nemexya
Posted 25 July 2019 - 09:57 AM
My wrapper version is 2.9.0.2 and the engine I'm using is WS9Wine64Bit4.12.1. As for apps, no apps work at all, no matter the app.
#8 ovvldc
  • 1253 posts
Posted 25 July 2019 - 11:01 AM
Did you try grabbing one of Gcenx' WS10Wine engines? I have been using those without issue, though your issue may be unrelated.
#9 Nemexya
Nemexya
Posted 27 July 2019 - 08:44 AM
After deleting everything, downloaded everything again, rebooting my pc, it somehow works now. I am very sorry for the "stupid" post.
I don't know why and how it works now because I didn't do anything special since that was what was I was doing all the time to try to make it work but it didn't before.
Thanks for the help and sorry for the inconvenience.
#10 ovvldc
  • 1253 posts
Posted 27 July 2019 - 08:59 AM
It happens. We've all had phantom bugs.
