CD-ROM Change in same Drive?!
#1 s4t4n
s4t4n
  • Graphics Card:Intel Iris Graphics 550 1536 MB
Posted 09 March 2021 - 02:27 PM
Hi!
I have a problem!
I installed a game that consists of 4 CD's. I mount the images. The game was also easy to install.
In the winecfg I have integrated all 4 mounted CD-ROMs.
D: / -> CD1
E: / -> CD2
F: / -> CD3
G: / -> CD4
In the game, however, it is required that the 2nd CD should be inserted into the CD-ROM drive D: / in which the first CD is located.
Is it possible to change the CD-ROM while using it?
Maybe one of you has an idea how I can solve the problem?
  • 1,286 posts
Posted 31 March 2021 - 04:54 PM
Can you add the drives to the path variable in some way? That would make it easier. Otherwise, you may need to use Deamontools or such.
