[REQ] Sony Vegas
15 replies to this topic
#1 Pool
Pool
  • 42 posts
Posted 06 December 2009 - 06:02 PM
This.
http://portingteam.c...edirect.php?htt ... Sony_Vegas
I'm grateful for the person who does this (This hasn't been done or has it?).
#2 Pool
Pool
  • 42 posts
Posted 08 December 2009 - 02:24 PM
is this possible?
#3 RenegadeUK
RenegadeUK
Posted 21 January 2010 - 12:18 PM
Great post, i would also love to see Sony Vegas ported for the MAC.
That would be amaaazing!
Cheers  :)
#4 Pool
Pool
  • 42 posts
Posted 21 January 2010 - 04:46 PM
Cheers  :)
Yeah. I wonder if anyone who is able to port has seen this topic
#5 Guitarobot
Guitarobot
  • 56 posts
Posted 22 January 2010 - 01:44 AM
I'm giving it a go right now, I'll share my results!  :wink:
#6 Pool
Pool
  • 42 posts
Posted 22 January 2010 - 11:56 AM
Awesome! TY
#7 Pool
Pool
  • 42 posts
Posted 25 January 2010 - 07:03 PM
So how did this work out, or did it at all?
#8 Bumbaz
Bumbaz
Posted 29 January 2010 - 03:40 PM
Honestly, I don't think it can be done, being such a complicated program. I remember trying to get it work through Crossover without success.
#9 Guitarobot
Guitarobot
  • 56 posts
Posted 30 January 2010 - 08:16 PM
Sorry for the delay, I've been busy.  :)
Well I tried it with CXZ and Wineskin, yet failed. This program takes use of some of Window's more core programs:
The components download fine (I think). Then there is the installing:
And I get this error message:
Maybe Sony Vegas is just too complicated, or at least what it needs to run. Any other ideas?
#10 Pool
Pool
  • 42 posts
Posted 31 January 2010 - 04:44 PM
This works thru wine, right?
#11 dafootballer
dafootballer
  • 1,259 posts
  • Graphics Card:Nvidia GeForce 9400m
Posted 31 January 2010 - 05:11 PM
Yeah, and Guitarobot try changing the Windows version in wine config to XP or higher
Posted ImagePosted ImageJoin the Porting Team Steam Group!
#12 Guest_dirtchamber_*
Guest_dirtchamber_*
Posted 13 February 2010 - 05:39 PM
Actually it works, but it's a little tricky. You have to install the dependencies separately, not trough the Vegas setup. The Vegas installer unpacks all those things in a temporary folder (Temp) on C drive (or Windows folder), but clicking Ok on that error deletes them. So don't click ok and go into that temporary folder (it's a randomly generated name inside the Temp folder, search trough it, you'll find it), where you have the VC runtimes and WMF redist. Install them and install the framework trough winetricks. After this, it will work, but the program is quite buggy. For example, it doesn't draw the waveforms for audio files unless you select the compatible mode for broken video drivers. But doing that results in poor feedback for the sound (the scrolling is not real-time, it's about 1 second delayed). Also, I didn't test the VST plugins, so I have no idea if they work.
I gave up on Vegas, there's Final Cut that does all that Vegas does and better. Doesn't worth the time to port it.
#13 GeekyMacBoy1
GeekyMacBoy1
  • 753 posts
  • LocationHK
Posted 29 March 2010 - 01:12 PM
i hope someone ports this app, cos that would be awesome!
#14 Guest_Atanvaryar_*
Guest_Atanvaryar_*
Posted 11 April 2010 - 08:42 PM
Why do you need that, if you can get the original mac Final Cut? Or even the FC Studio...
#15 herta
herta
Posted 30 August 2010 - 01:33 PM
if this works, it would be very interesting to try some things out...
#16 x66dme66x
x66dme66x
  • LocationMaine
Posted 03 November 2010 - 04:56 PM
if you want i can help you get a Virtual Machine running windows 7 ultimate and you may use apps such as Sony Vegas. because i have it running on my mac. send me an email with the subject "Sony Vegas" to x66dme66x@aol.com
