Shank
16 replies to this topic
#1 tetsuotk
tetsuotk
  • 9 posts
Posted 29 October 2010 - 02:45 AM
Hello, I'm trying to port the game Shank using CXZ Ebony.
The game is working almost great. Animations runs smoothly. The only problem I've seen is with the keyboard.
I can select the options in menu using mouse and start a new game. But i get no feedback when using the keyboard so I can't control the character.
I pressed alt+f4 and the game did quit so I guess the cxz engine is getting the keyboard input but the game is not.
Any idea of what should I do? This is my second attempt to port a recent game and I'm way closer to get it working than I did with dead space.
Here is the log file content:
2010-10-28 23:58:37.184 CXX11Server[768] Could not find image named 'CrossOver.icns'.
2010-10-28 23:58:37.450 CXX11Server[768] Setting DYLD_FALLBACK_LIBRARY_PATH=/Users/vnakamura/Desktop/Shank.app/Contents/MacOS/CXZ Ebony.app/Contents/SharedSupport/X11/lib:/Users/vnakamura/lib:/lib:/usr/lib:/usr/X11/lib
2010-10-28 23:58:37.452 CXX11Server[768] No version
Release Date: 18 December 2003
X Protocol Version 11, Revision 0, Release 6.8.2
Build Operating System: Mac OS X Apple Computer, Inc.
Current Operating System: Darwin Viniciuss-MacBook-Pro.local 10.4.0 Darwin Kernel Version 10.4.0: Fri Apr 23 18:28:53 PDT 2010; root:xnu-1504.7.4~1/RELEASE_I386 i386
	Before reporting problems, check http://www.codeweavers.c0m/support/
	to make sure that you have the latest version.
2010-10-28 23:58:37.458 CXX11Server[768] A call to OSACopyScriptingDefinition() by NSScriptSuiteRegistry returned an error. Is this application's OSAScriptingDefinition Info.plist entry valid? If its value is 'dynamic', is there an 'ascr'/'gsdf' Apple event handler registered?
_XSERVTransmkdir: ERROR: euid != 0,directory /tmp/.CrossOver will not be created.
Loading GLX bundle glxCGL.bundle (using Apple's OpenGL)
Display mode: Rootless Quartz -- Xplugin implementation
PseudoramiX screen 0 added: 1440x878 @ (0,22).
PseudoramiX screen 0 placed at X11 coordinate (0,0).
[DRI] screen 0 installation complete
Screen 0 added: 1440x878 @ (0,22)
Screen 0 placed at X11 coordinate (0,0).
2010-10-28 23:58:38.903 CXX11Server[768] -[ShutdownController loadWindow]: failed to load window nib file 'ShutdownProgress'.
dyld: warning, DYLD_ setting caused circular dependency in /Users/vnakamura/Desktop/Shank.app/Contents/MacOS/CXZ Ebony.app/Contents/SharedSupport/X11/lib/libGL.dylib
2010-10-28 23:58:38.939 CXX11Server[768] launch path not accessible
tcl error:
*** TCL TRACE ***
invalid command name "finishInit"
	while executing
"finishInit"
tcl error:
*** TCL TRACE ***
invalid command name "::ObjBottle"
	while executing
"::ObjBottle GetBottleList"
tcl error:
*** TCL TRACE ***
	while executing
"::ObjBottle IsDefault {invalid}"
tcl error:
*** TCL TRACE ***
	while executing
"finishInit {invalid}"
tcl error:
*** TCL TRACE ***
invalid command name "::cwdialog::CBottles::GetWinePrefix"
	while executing
"::cwdialog::CBottles::GetWinePrefix {invalid}"
tcl error:
*** TCL TRACE ***
	while executing
"::ObjBottle IsManaged {invalid}"
tcl error:
*** TCL TRACE ***
invalid command name "cwdialog::CBottles::GetWinePrefix"
	while executing
"cwdialog::CBottles::GetWinePrefix {invalid} managed"
tcl error:
*** TCL TRACE ***
invalid command name "::cwdialog::CBottle::GetBottleByName"
	while executing
"::cwdialog::CBottle::GetBottleByName {invalid}"
	invoked from within
"[::cwdialog::CBottle::GetBottleByName {invalid}] GetNeedsUpgrade"
tcl error:
*** TCL TRACE ***
	while executing
2010-10-28 23:58:39.336 CXX11Server[768] Excluding
tcl error:
*** TCL TRACE ***
	while executing
tcl error:
*** TCL TRACE ***
	while executing
"finishInit {command}"
tcl error:
*** TCL TRACE ***
	while executing
"::cwdialog::CBottles::GetWinePrefix {command}"
tcl error:
*** TCL TRACE ***
	while executing
"::ObjBottle IsManaged {command}"
tcl error:
*** TCL TRACE ***
	while executing
"cwdialog::CBottles::GetWinePrefix {command} managed"
tcl error:
*** TCL TRACE ***
	while executing
"::cwdialog::CBottle::GetBottleByName {command}"
	invoked from within
"[::cwdialog::CBottle::GetBottleByName {command}] GetNeedsUpgrade"
tcl error:
*** TCL TRACE ***
	while executing
"::ObjBottle IsDefault {command}"
2010-10-28 23:58:39.342 CXX11Server[768] Excluding
tcl error:
*** TCL TRACE ***
	while executing
"finishInit {name}"
tcl error:
*** TCL TRACE ***
	while executing
"::cwdialog::CBottles::GetWinePrefix {name}"
tcl error:
*** TCL TRACE ***
	while executing
"::ObjBottle IsManaged {name}"
tcl error:
*** TCL TRACE ***
	while executing
"cwdialog::CBottles::GetWinePrefix {name} managed"
tcl error:
*** TCL TRACE ***
	while executing
"::cwdialog::CBottle::GetBottleByName {name}"
	invoked from within
"[::cwdialog::CBottle::GetBottleByName {name}] GetNeedsUpgrade"
tcl error:
*** TCL TRACE ***
	while executing
"::ObjBottle IsDefault {name}"
2010-10-28 23:58:39.348 CXX11Server[768] Excluding
tcl error:
*** TCL TRACE ***
	while executing
"finishInit {::ObjBottle}"
tcl error:
*** TCL TRACE ***
	while executing
"::cwdialog::CBottles::GetWinePrefix {::ObjBottle}"
tcl error:
*** TCL TRACE ***
	while executing
"::ObjBottle IsManaged {::ObjBottle}"
tcl error:
*** TCL TRACE ***
	while executing
"cwdialog::CBottles::GetWinePrefix {::ObjBottle} managed"
tcl error:
*** TCL TRACE ***
	while executing
"::cwdialog::CBottle::GetBottleByName {::ObjBottle}"
	invoked from within
"[::cwdialog::CBottle::GetBottleByName {::ObjBottle}] GetNeedsUpgrade"
tcl error:
*** TCL TRACE ***
	while executing
"::ObjBottle IsDefault {::ObjBottle}"
2010-10-28 23:58:39.354 CXX11Server[768] Excluding
Thu Oct 28 23:58:44 Viniciuss-MacBook-Pro.local CXX11Server[768] : kCGErrorIllegalArgument: CGSOrderWindowList
Thu Oct 28 23:58:44 Viniciuss-MacBook-Pro.local CXX11Server[768] : kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
PseudoramiX screen 0 added: 1440x900 @ (0,0).
I would appreciate any help.
#2 ivanguerr
ivanguerr
  • 36 posts
Posted 29 October 2010 - 10:06 PM
I have the same problem. The game works as well, pretty graphics with good sound. The keyboard doesn´t works. Where is the config file with the player configuration? I haven´t find it.
#3 tetsuotk
tetsuotk
  • 9 posts
Posted 29 October 2010 - 10:37 PM
I tried with Wineskin too and got the same.
Also, I connected a PS3 Dual Shock 3 via bluetooth and I it works. But the buttons configuration is really messed up. Something like:
L3(Clicking the left analog stick) and Start to attack;
Select to jump;
R2 to open the main menu.
When I tried to set the button configuration in the game command i try to change is set to "-X rotation".
So there's a problem with calibration I guess.
Anyway using the controller I can see that the game runs pretty well. So fixing this keyboard problem the game wil probably be fully playable.
Now I'll go search for a way to convert the keyboard commands to a virtual joystick. If it works I'll let you know.
#4 Guest_Shatter_*
Guest_Shatter_*
Posted 30 October 2010 - 06:26 PM
I tried to port. Turned to run, but the keyboard did not work and is strongly inhibited.
#5 tetsuotk
tetsuotk
  • 9 posts
Posted 31 October 2010 - 12:11 AM
For now I'm using ControllerMate to play. I created a virtual joystick and linked its buttons to the keyboard. Works great as a temporary solution!
#6 ivanguerr
ivanguerr
  • 36 posts
Posted 31 October 2010 - 07:20 AM
How do you create a virtual yoystick?
#7 tetsuotk
tetsuotk
  • 9 posts
Posted 31 October 2010 - 11:02 AM
With ControllerMate: http://portingteam.c...edirect.php?htt ... ollermate/
It's simple to use the programming tool to set the virtual controller behavior. Basically you attach a keyboard key to a button on the virtual joystick. The only part that needs a little math is to set the X and Y axis.
I've exported my config: http://portingteam.c...edirect.php?htt ... cmate.html
In my case I used the following keys: arrows, a, s, d, f, left shift, space, right alt, right shift, <, >, [, ] and esc. Feel free to modify it as you like.
After this you can open the game and set the keys to the game actions.
Do not try to change a keyboard command. The game wil wait for you to press a key and since it's not getting any key press it will freeze. Make sure you are changing the joystick commands.
#8 Steps
Steps
  • 32 posts
  • LocationRussian Federation
  • Graphics Card:NVidia GF330M
Posted 21 November 2010 - 11:48 PM
tetsuotk
I've exported my config: http://portingteam.c...edirect.php?htt ... cmate.html — link dead.
#9 tetsuotk
tetsuotk
  • 9 posts
Posted 22 November 2010 - 10:35 AM
Well, let's try this one:
#10 Steps
Steps
  • 32 posts
Posted 22 November 2010 - 10:57 AM
Thanks, I'll try. :)
#11 Ygor
Ygor
  • 21 posts
  • Graphics Card:Nvidia GM 9400
Posted 23 November 2010 - 10:57 AM
You just download that Virtual controller and it should run? Or do you need t open it? Sorry for the dumb questions, but i imported it into controllermate and still no input- so i must be doing something wrong :D
Thanks nevertheless.
#12 Steps
Steps
  • 32 posts
Posted 23 November 2010 - 11:00 AM
I too was not able to use a virtual joystick.
#13 TheTuKays
TheTuKays
  • 112 posts
  • Graphics Card:ati
Posted 24 November 2010 - 09:19 AM
i've tried to install shank myself using the ebony engine and the cxz builder or whatever its name is. Installation was dead simple and the game worked just great. At least as long as you use a game pad. I've got a logitech rumblepad and the game works with it just like that. I've seen in the options in the game that it's possible to change to keyboard. I've not tried it but just wanted to let you know... maybe it helps more than the virtual gamepad.
On the other hand you could as well just go get a rumblepad, they're pretty cheap.
#14 mnemonicj
mnemonicj
  • 7 posts
Posted 21 December 2010 - 06:03 AM
Hello people! First post here, so bear with me please =D
I'm trying to run a port of the game Shank on my Macbook and the games runs perfectly well, but I don't have access to the keyboard settings. The game runs fine but it doesn't detect an input device. I can't assign anything to the game on the settings either. My Macbook settings are 2.4 GHz duo core 2 processor, 6GB ram, 250 HD, nvidia 9400m video card, etc.
The engine I'm running with the game is WS4WineCXG9.1.0. Like I said, everything works fine except for the keyboard input.
Regards.
#15 Razgriz92
Razgriz92
  • 173 posts
  • LocationIndonesia
  • Graphics Card:nVidia GeForce 9400M
  • I like to play:FPS, RPG, etc. (end of thinking capacity)
Posted 21 December 2010 - 06:20 AM
here: there's already a thread regarding this bug
viewtopic.php?f=224&t=6354
I got bad english, yeah I know.. Sorry about that!
Mess with the best, you'll die like the rest!
Some people, no matter how old they get, never lose their beauty - they merely move it from their faces into their hearts
- Martin Buxbaum
#16 waves
waves
    Tired, and starting to outlive my usefullness.
  • 1,600 posts
  • Graphics Card:NVIDA
Posted 21 December 2010 - 05:05 PM
Topics merged - thanks Razgriz92.
How to get multiple file port games / apps runnning: http://portingteam.c...-combine-files/
#17 Guest_rshack_*
Guest_rshack_*
Posted 04 January 2011 - 06:05 PM
Hello all! Any news on this game? I just signed up here, first post, w00t! :D
I downloaded CXEx and installed the game, didn't really need to do much config, the CXEx program is great! Anyway I noticed everyone is having problems with the keyboard and I can't figure out how to fix it? Hoping someone has com up with a solution other than the workarounds already posted...
I have a xbox 360 controller plugged into my mac using the Tattiebogle drivers from here: http://portingteam.c...edirect.php?htt ... /OsxDriver
I can use the analogs and the 'B' button only though in game, none of the other buttons register in-game, and still am unable to control 'Shank' once the game starts. Controller only really works to change settings etc. :(
