Problems with COD6 MW2 MultiPlayer in Steam
#1 Guest_Wouter92_*
Guest_Wouter92_*
Posted 18 November 2010 - 11:20 AM
Hi,
I've experienced some problems with the STEAM port: when I start COD6 MW2 in Steam (after I added it as a non-steam game) I always get a directx error.
Does anybody know how to solve this.
I would be very gratefull :D
Cheers
Wouter92
#2 totolezigoto
totolezigoto
  • 58 posts
Posted 18 November 2010 - 04:30 PM
did you install the latest version of direct X ? what does the error says ? ^^
Avatar by me :P
Thanks and congratulations to the porting team for his great work !!!!
#3 Guest_Wouter92_*
Guest_Wouter92_*
Posted 18 November 2010 - 05:39 PM
I think i installed indeed the latest directx: I clicked CXWinetricks in the Contents folder of the steam app and then I clicked on d3d9 and directx 9, then 'Apply'.
The error says: 'Directx encountered an unrecoverable error. Check the readme for possible solutions.'
EDIT: I'm solving it I think, I'll do the steam trick with zeroGear tomorrow again and I think it'll work. What did I do? I used CrossoverGames instead of the steam application of this forum. In that steam crossoverGames auto installed directx and that error is now fixed :D.
