Problem with installing
19 replies to this topic
#1 mengchhorn
mengchhorn
  • 9 posts
  • LocationCambodia
Posted 30 March 2011 - 04:37 AM
I have download CiderX and i get 3files of it, but i couldn't able to install it as i already try with Split and Concat, 7zX
#2 Drakulix
    Old nearly vanished Member
  • 1,903 posts
Posted 30 March 2011 - 04:50 AM
Use only 7zX. Open the .001 file with 7zX and make sure all files are in the same folder.
#3 GameGuy
GameGuy
  • 2,127 posts
  • LocationCanada...Eh
  • Graphics Card:nVidia 9400m 256mb
    ATI Radeon HD 6950 2GB
    MSI N670GTX PW/OCE 2GB SLI
  • I like to play:RPG, Racing, and of course FPS
Posted 30 March 2011 - 04:53 AM
when extracted it should give you one file...it should be a dmg file that includes inside the installer for ciderx
Macbook Pro: Intel C2D 2.53ghz, 4GB Ram, Nvidia 9400m 256MB
Hackintosh: Intel i5-3570k, 16GB Ram, Asus Z77 Sabertooth, MSI GTX 670 Power Edition SLI
If my post helped you hit the like button :)
#4 mengchhorn
mengchhorn
  • 9 posts
  • LocationCambodia
Posted 30 March 2011 - 04:59 AM
after i open that and i get one file that is CiderX Installer 1.3.dmg.7z with the size of 398.5mb
#5 GameGuy
GameGuy
  • 2,127 posts
Posted 30 March 2011 - 05:04 AM
try removing the .7z or extract again...mine was about 471mb
#6 mengchhorn
mengchhorn
  • 9 posts
  • LocationCambodia
Posted 30 March 2011 - 05:12 AM
hmmm the problem still exist even i have remove .7z before expansion it still got the same size ... as i open it ... it said there is no mountable file systems.
#7 GameGuy
GameGuy
  • 2,127 posts
Posted 30 March 2011 - 05:16 AM
so after removing the 7z and leaving the dmg it doesn't mount...you may have to redownload the parts and try again...when i downloaded i get:
CiderX Installer 1.3.sfv (4KB)
CiderX Installer 1.3.dmg.001 (199.2 MB)
CiderX Installer 1.3.dmg.002 (199.2 MB)
CiderX Installer 1.3.dmg.003 (79.6 MB)
#8 mengchhorn
mengchhorn
  • 9 posts
  • LocationCambodia
Posted 30 March 2011 - 05:20 AM
it exactly as what i got ... i already removing the 7z as you have told me and try it again but it still the same with 398.5mb
#9 playn
playn
    Just Playin'
  • 1,966 posts
  • LocationAustralia
  • Graphics Card:NVIDIA GeForce GT 330M
Posted 30 March 2011 - 05:21 AM
You should just have to use 7zX to extract CiderX Installer 1.3.dmg.001
7zX will automatically join and extract the rest of the files for you, as long as they're all in the same folder. But don't remove the .7z. It needs to be there.
'Do you want to spend the rest of your life selling sugared water or do you want a chance to change the world?'
– Steve Jobs
#10 GameGuy
GameGuy
  • 2,127 posts
Posted 30 March 2011 - 05:24 AM
did you move all 3 files to desktop and drag onto the 7zx icon on you dock because thats what i did and it extracted by itself with no problems...i also tried downloading with jdownloader and it extracted all by itself
#11 mengchhorn
mengchhorn
  • 9 posts
  • LocationCambodia
Posted 30 March 2011 - 05:48 AM
hmmm it still the same ...
#12 Drakulix
  • 1,903 posts
Posted 30 March 2011 - 10:57 AM
So what files do you get, after you opened the CiderX Installer 1.3.7z.001 file with 7zX??
#13 mengchhorn
mengchhorn
  • 9 posts
  • LocationCambodia
Posted 30 March 2011 - 11:20 AM
i get CiderX Installer 1.3.dmg.7z with the size of 398.5mb
#14 Razgriz92
Razgriz92
  • 173 posts
  • LocationIndonesia
  • Graphics Card:nVidia GeForce 9400M
  • I like to play:FPS, RPG, etc. (end of thinking capacity)
Posted 30 March 2011 - 11:38 AM
Try the Unarchiver
http://wakaba.c3.cx/...unarchiver.html
I got bad english, yeah I know.. Sorry about that!
Mess with the best, you'll die like the rest!
Some people, no matter how old they get, never lose their beauty - they merely move it from their faces into their hearts
- Martin Buxbaum
#15 Drakulix
  • 1,903 posts
Posted 30 March 2011 - 11:50 AM
That is wrong.
Maybe you have an older version of 7zX.
Try this: viewtopic.php?f=134&t=7605
#16 mengchhorn
mengchhorn
  • 9 posts
  • LocationCambodia
Posted 31 March 2011 - 01:57 PM
@Drakulix: i already got 7zX with version 1.7.1 ... and i even follow your link and download it again but it still the same ... I still got 398.5mb file with .dmg.7z and if i remove .7z and open it, they say no mountable file ...
@Razgriz: i have download your program but it cant extract that file ...
#17 Drakulix
  • 1,903 posts
Posted 31 March 2011 - 02:42 PM
So for me it works, so the files should be okay.
Maybe your download is broken.
Would you please download MacSFV and open the .sfv file with it to test the checksums of your downloaded files?
#18 mengchhorn
mengchhorn
  • 9 posts
  • LocationCambodia
Posted 04 April 2011 - 09:24 PM
@Drakulix: pretty thx for your post now i know that i got the third files missing and i will be redownload it :)
#19 jeffrey2000hk
jeffrey2000hk
Posted 28 July 2011 - 11:31 AM
I have download all of the files and got an installer file, but when it ends installing nothing happens. Nothing in Applications folder. :(
#20 y00nyu1
y00nyu1
Posted 10 December 2011 - 12:46 AM
@jeffrey2000hk same here
