Float help
#1 timelord
timelord
  • Graphics Card:ATI radeon
Posted 05 February 2012 - 04:19 PM
Hello, what is "Epsilon" for float search ? How to use it ?
Posted 05 February 2012 - 04:47 PM
we need more context to answer the question correctly....I believe epsillon is a greek or roman letter....not sure what you mean by floating search and if you're asking how to search the forums then move your cursor to the top right hand corner that has the search box. Click the white text area and type in what it is you're searching for. Click the greyed area to the right of the white text area to select what part of the site you would like to search in.
Welcome to the forums.
***edit....just realized that this was in the bit slicer project....probably not a relevant answer considering the section.****
#3 timelord
timelord
Posted 05 February 2012 - 08:04 PM
I'm sorry. Beacause my question is in Bit Slicer project section.
#4 KGameLover1
KGameLover1
    Need a title
  • 840 posts
  • LocationWhere I am is where I be
  • Graphics Card:AMD Radeon HD 6750M 1024 MB, also Intel HD Graphics 3000 512 MB.
  • I like to play:Everything that's fun
Posted 05 February 2012 - 08:53 PM
He didn't know you were asking about Bit Slicer. I'd suggest sending Zorg a message. :)
blinxfrost said:
in game my guy spins out of control only way i can control is arrow keys my hands are to nubby to reach them and shot
View my ports! <--- Orcs Must Die, Payday, Fallout, I Wanna Be The Guy, and more!
How to use a Wineskin wrapper!
#5 Zorg
Zorg
  • 147 posts
  • LocationSpace
  • Graphics Card:I don't know.
  • I like to play:Arcade, Side Scrollers
Posted 06 February 2012 - 06:51 PM
Epsilons are used for dealing with rounding errors caused by floating points. For example, an epsilon of 0.1 will find all values in the range [value-0.1, value+0.1]. In a program, it's possible that a floating point calculation such as 1.0 - 0.8 may result in something like 0.19999999999999996, which is not quite the same as 0.2.
