Help with Umemaro 3D port (18+)
#1 wonderwall555
wonderwall555
  • 46 posts
Posted 14 February 2012 - 12:58 PM
I've been trying to port Umemaro 3D games onto mac, but to no success. I try installing before the W8-1.4 update and it would just say "Oops, installer not found". Then I tried it again with the new update and now but it then tries to pick a file to use as the .exe, but when I look inside there's nothing in the wineskin. Finally I shoved the unziped file in there and tried to get directly to the .exe but then nothing happens.
I really don't get whats going on...I've added the wrapper error logs to the bottom, I'd add a screen shot but really there's nothing to show and thats the issue...
Mac OS X 10.6.8
Mac Book Pro, NVIDIA GeForce 9400M & dual-core Intel Core i5 and i7
err:module:import_dll Library MSVBVM60.DLL (which is needed by L"C:\\Program Files\\Umemaro_-_Nasty_Dr_Sugimoto\\InranTiryou.exe") not found
err:module:LdrInitializeThunk Main exe initialization for L"C:\\Program Files\\Umemaro_-_Nasty_Dr_Sugimoto\\InranTiryou.exe" failed, status c0000135
#2 Razgriz92
Razgriz92
  • 173 posts
  • LocationIndonesia
  • Graphics Card:nVidia GeForce 9400M
  • I like to play:FPS, RPG, etc. (end of thinking capacity)
Posted 18 February 2012 - 04:15 PM
Try installing the dll needed using winetricks or try install the vb6run also with winetriks
I got bad english, yeah I know.. Sorry about that!
Mess with the best, you'll die like the rest!
Some people, no matter how old they get, never lose their beauty - they merely move it from their faces into their hearts
- Martin Buxbaum
