Please help Doom 3
#1 fatbunnie96
fatbunnie96
  • 32 posts
  • LocationAustralia
Posted 31 March 2012 - 02:27 AM
Doom 3 works perfectly, except when i try to load a mod, Sikkmod 1.2, it crashes and gives me the error:
R6205
- pure function call
Is there anyway around this or should i just not bother?
I am running 10.6.8 on a MacBook with NVIDIA GeForce 9400M
This is what i get:
X11.app: DISPLAY does not look like a launchd set variable, unsetting.
X11.app: main(): argc=12
argv[0] = /Applications/Doom 3 .app/Contents/MacOS/WineskinX11
argv[1] = :1778
argv[2] = -depth
argv[3] = 24
argv[4] = +xinerama
argv[5] = -br
argv[6] = -fp
argv[7] = /usr/X11/lib/X11/fonts/75dpi,/usr/X11/lib/X11/fonts/100dpi,/usr/X11/lib/X11/fonts/cyrillic,/usr/X11/lib/X11/fonts/encodings,/usr/X11/lib/X11/fonts/misc,/usr/X11/lib/X11/fonts/OTF,/usr/X11/lib/X11/fonts/Speedo,/usr/X11/lib/X11/fonts/TTF,/usr/X11/lib/X11/fonts/Type1,/usr/X11/lib/X11/fonts/util
argv[8] = -xkbdir
argv[9] = /Applications/Doom 3 .app/Contents/Frameworks/share/X11/xkb
argv[10] = +extension
argv[11] = '/Applications/Doom 3 .app/Contents/Frameworks/bin/quartz-wm'
X11.app: No launchd socket handed off, unsetting DISPLAY
X11.app: do_start_x11_server(): argc=12
argv[1] = :1778
argv[2] = -depth
argv[3] = 24
argv[4] = +xinerama
argv[5] = -br
argv[6] = -fp
argv[8] = -xkbdir
[mi] Extension "'/Applications/Doom 3 .app/Contents/Frameworks/bin/quartz-wm'" is not recognized
[mi] Only the following extensions can be run-time enabled:
[mi] Generic Events
[mi] DAMAGE
[mi] DOUBLE-BUFFER
[mi] GLX
[mi] MIT-SCREEN-SAVER
[mi] MIT-SHM
[mi] RANDR
[mi] RENDER
[mi] X-Resource
[mi] XFIXES
[mi] XINERAMA
[mi] XTEST
[mi] XVideo
[1720136.587] Xquartz starting:
[1720136.587] X.Org X Server 1.11.1
[1720136.587] Build Date: 20110929
[1720136.587] _XSERVTransmkdir: ERROR: euid != 0,directory /tmp/.X11-unix will not be created.
[1720136.699] (II) GLX: Initialized Core OpenGL GL provider for screen 0
[1720136.781] [dix] Could not init font path element /usr/X11/lib/X11/fonts/encodings, removing from list!
[1720136.837] X11.app: DarwinProcessFDAdditionQueue_thread: Sleeping to allow xinitrc to catchup.
[1720136.887] (EE) Error loading keymap /tmp/Wineskin/share/X11/xkb/compiled/server-1778.xkm
[1720136.887] (EE) XKB: Failed to load keymap. Loading default keymap instead.
and
fixme:wbemprox:wbem_locator_ConnectServer 0x16c3d0, L"\\\\.\\root\\CIMV2", (null), (null), (null), 0x00000000, (null), 0x0, 0x2f6fb94)
fixme:keyboard:X11DRV_ActivateKeyboardLayout 0xc090c09, 0000: semi-stub!
err:mmtime:TIME_MMTimeStop Timer still active?!
#2 cluthz
  • 2836 posts
Posted 31 March 2012 - 06:02 PM
"R6205 Pure function call" is a virtual c error.
As far as i know this is due to the game compiling sharders and textures for the game.
It's often seen on PCs too when running games on integrated graphics.
THis happens with f.ex my gothic 3 port if you turn settings too high on low end graphics.
Do the sikkmod improve graphics and effects, then I'm pretty sure that's the case.
