Command Conquer Tiberian Sun-Mouse lags graphics
#1 Dubboy
Dubboy
  • Graphics Card:ATY radeon X1600
Posted 20 June 2012 - 01:56 PM
Hi I need help.
I am using port Command Conquer Tiberian Sun the game starts up normally wineskinu to the limited range of resolution.
The game is not moving smoothly even if the mouse-but unless they start to move (lags)
Does anyone have a proven recipe to solve this?
Thanks
Dubboy
#2 thedoc
thedoc
  • 1,311 posts
  • Graphics Card:nVidia GeForce 9600M GT - 512 MB RAM
  • I like to play:FPS, RPG, Racing
Posted 20 June 2012 - 07:30 PM
which engine and Wineskin version are you using - give a bit more info please.
It must be pretty old since the 1.4 build of Wine has an implementation for the DIB engine included which should prevent these DirectDraw related performance bugs from happening.
If you're on an nVidia Mac you might also try adding:
[Software\\Wine\\Direct3D] 1277303423
"DirectDrawRenderer"="opengl"
to the user.reg file in Wineskin.app/Contents/resources/
good luck
Check out my Porting Blog @ Doc's Office
#3 wMin17
wMin17
  • 400 posts
Posted 20 June 2012 - 08:01 PM
Or it could be your graphics card.  It might be too weak to run the game.
#4 BLACKNIGHT
BLACKNIGHT
  • 194 posts
  • LocationBrisbane, Australia
  • Graphics Card:nVidia 860m 2gb
    nVidia 780 ti Gigabyte Windforce 3x edition
    nVidia Titan X Maxwell 3x SLI
  • I like to play:Racing
    FPS
    RPG/SKYRIM/OBLIVION/fallout NV
Posted 21 June 2012 - 04:25 AM
i will try porting it XD
When life gets You down, Grab it by the Balls
Ports Done- 9
PM me for Port Requests
#5 Dubboy
Dubboy
Posted 22 June 2012 - 04:07 PM
So I wonder which mac meets the following requirements?:-) Weak hardware that specifically tested it is not.Grafics card Intel GMA X1600 Ata and 256 megabytes.
Similar pores of the game in which the editor claims to have no problem going the same defect.
Tested on iMac 2011 and 2011 MBP also without result, the mouse still does delay animation and cutting video games.
Wine version is 1.4.Když I port the State of War (Czech SCiFi strategy) I had the same problem, fortunately I managed to disable the hardware in silicon kurzor.V CC I never found such a possibility
