Change Engine Used to WS9Wine1.5.11 ...
7 replies to this topic
#1 zoroaster
zoroaster
  • 143 posts
Posted 19 August 2012 - 11:01 AM
... the wrapper has no visible fonts in Steam, all menu, button and other text is gone.
... additionally if I use Test Run the wrapper stops after one second and I get an error that the X DISPLAY is not set correctly (tested more than once: to get it work again I always have to reboot the whole system).
After using my old 1.4.1 engine again everything works without this strange behavior.
  • 1274 posts
Posted 21 August 2012 - 11:33 AM
Is this a problem with anything other than Steam? I would think a problem with the X DISPLAY would show up in lots of places..
#3 zoroaster
zoroaster
  • 143 posts
Posted 21 August 2012 - 04:31 PM
In fact these are two different problems: one with missing fonts and one with the Test Run button in Wineskin.
#4 doh123
Posted 21 August 2012 - 05:30 PM
No idea on the font issue... unless its a bug in Wine.  X server issues shouldn't be a Wine issue though... how are you getting it to happen exactly, as Test Run works for me.  The only bugginess Test Run should have is if your using Override -> fullscreen.
#5 zoroaster
zoroaster
  • 143 posts
Posted 22 August 2012 - 07:18 PM
If I am the only one who had this kind of problems with the new Wine version this can be ignored. Maybe it was only some kind of local misconfiguration on my machine.
#6 KGameLover1
KGameLover1
    Need a title
  • 840 posts
  • LocationWhere I am is where I be
  • Graphics Card:AMD Radeon HD 6750M 1024 MB, also Intel HD Graphics 3000 512 MB.
  • I like to play:Everything that's fun
Posted 23 August 2012 - 12:22 AM
I have this problem too, and upon researching, many others do as well with any version above the later 1.4's.
blinxfrost said:
in game my guy spins out of control only way i can control is arrow keys my hands are to nubby to reach them and shot
View my ports! <--- Orcs Must Die, Payday, Fallout, I Wanna Be The Guy, and more!
How to use a Wineskin wrapper!
#7 Luggage
Luggage
  • Graphics Card:ATI Radeon HD 5770 1024 MB
    RTS
    FPS
Posted 24 August 2012 - 05:45 PM
I had this problem also…
Problem is caused apparently by some dll you find only on 1.5.x version of wine.
I think it's called dwrite. if you add it with winecfg and immediately disable it, fonts show again on steam.
It's worked for me, though i don't have a clue on what happened.
Maybe someone here can explain it ;)
#8 ovvldc
  • 1274 posts
Posted 25 August 2012 - 02:32 PM
Perhaps report this to the Wine makers?
