Anno 2070 Install help
41 replies to this topic
#1 rystaman
rystaman
  • 29 posts
  • LocationBirmingham, England
Posted 16 March 2013 - 11:31 PM
Hi guys. I am new to this site and i am currently trying to install Anno 2070 on my macbook pro. I have followed the steps of this guide and it hasn't worked (btw i did buy it and i am using parallels 7) I then followed a bit of this guide. I tried to use the wrapper but i had no clue. Can anybody help me ?
I will post below my OSX version and my GPU and CPU :)
Thanks
My Mac OS X Version: OS X 10.7.5
My Mac Model, GPU & CPU: Mid 2009, NVIDIA GeForce 9400M 256 MB, 2.8 HGHz Intel Core 2 Duo
Sig made by me
#2 Reboot
Reboot
    I am Darkstar
  • Database Moderators
  • 2381 posts
  • Graphics Card:Nvidia EVGA GTX 980 SC 4GB
Posted 17 March 2013 - 03:53 AM
Don't installation instructions help you, correct?
http://portingteam.c...-get-good-help/ (How to get log from Wineskin.)
~ ~ ~ Hackintosh Spec ~ ~ ~
Intel Core i5-3570K 4.20GHz -- Patriot Viper Xtreme 8GB DDR3 1600MHz -- Nvidia EVGA GTX 980 4GB VRAM GDDR5 SC
#3 rystaman
rystaman
  • 29 posts
Posted 17 March 2013 - 09:38 AM
Here is what i have put in the wrapper
Here is where the .exe is located (wineskin page)
Here is what i am getting from the test run and when i normally try to load it up
I know where the .exe is in windows (revloader.exe) but i don't know what to do on this screen
Here are the logs
Sig made by me
#4 thanoulas
thanoulas
  • 568 posts
  • LocationLondon
  • Graphics Card:nVidia GT750M 2GB
Posted 17 March 2013 - 11:01 AM
1. I'm not saying you're using a pirated version (I don't really know) but the pirated version doesn't work in the wrapper.
2. You shouldn't point the wrapper to the revLoader.exe file. You should point it to Anno5.exe
If I helped in any way, you can always click the Like button! | All my Ports | Download Barrel: The Wine Port Manager for Mac OS X
#5 rystaman
rystaman
  • 29 posts
Posted 17 March 2013 - 01:56 PM
I brought it off steam (the deluxe edition) I have a key for it as well. I just don't know how to set it up with steam or not steam. I really have no idea where to start now.
Sig made by me
#6 Reboot
Reboot
    I am Darkstar
  • 2381 posts
Posted 17 March 2013 - 05:30 PM
Game files are not in /Program Files/Anno 2070/ drive_c folder. Wineskin will not run game.
However, Crack RevLoader don't works on wrapper. (as thanoulas said) You need steam to run game. (It's available install via Winetrick or direct download)
#7 rystaman
rystaman
  • 29 posts
Posted 17 March 2013 - 05:38 PM
I have it installed on windows and mac. I just don't know what to do.
So what do i do next?
1. Put game files in Program Files/Anno 2070/drive_c
2. Run game off Steam on Mac ??
I am seriously a n00b at porting and need step by step guides. I hope i become better as i start to port more.
Sig made by me
#8 Reboot
Reboot
    I am Darkstar
  • 2381 posts
Posted 17 March 2013 - 05:42 PM
Steam won't find /drive_c/Program Files/Anno 2070/ to run.
Original location is /drive_c/Program Files/Steam/steamapps/common/Anno 2070/ You can move files to folder. Steam will check/verify installed game automatically before you play it.
Edited by REBOOT, 17 March 2013 - 05:44 PM.
#9 rystaman
rystaman
  • 29 posts
Posted 17 March 2013 - 05:59 PM
So do i have to run it on parallels or on my mac os x
Also that is where the files are
Sig made by me
#10 rystaman
rystaman
  • 29 posts
Posted 17 March 2013 - 06:58 PM
So
But i don't know what to do here
Sig made by me
#11 thanoulas
thanoulas
  • 568 posts
  • LocationLondon
Posted 18 March 2013 - 11:32 AM
That's wrong then. You need to install steam in the wrapper first. Go to Wineskin > Advanced > Tools > Winetricks
Choose steam from the list and install.
Once this is done, launch steam (from the wrapper again), log in, go to your library and install Anno 2070
once that is done again, close steam and point the "Windows EXE" in wineskin to the path reboot wrote (you need to point to the Anno2070.exe file, not the folder)
#12 rystaman
rystaman
  • 29 posts
Posted 18 March 2013 - 04:31 PM
Is that the same as run ?
Sig made by me
#13 rystaman
rystaman
  • 29 posts
Posted 18 March 2013 - 05:56 PM
Here is what i have done
Now what do i do here ??
Sorry i have changed /Anno2070 to /Anno2070/Anno5.exe
Sig made by me
#14 rystaman
rystaman
  • 29 posts
Posted 18 March 2013 - 08:06 PM
So what do i do next ?
Sig made by me
#15 rystaman
rystaman
  • 29 posts
Posted 19 March 2013 - 06:24 PM
Anybody ? I dropped £22 on this game and have no idea how to port it!
Sig made by me
#16 SilentJacket
SilentJacket
  • 188 posts
  • Graphics Card:NVIDIA Geforce 650M 1.024 GB
Posted 19 March 2013 - 07:32 PM
winetricks refers to the old version of steam, unless you find a way to trick the game, you're kinda hosed
#17 rystaman
rystaman
  • 29 posts
Posted 19 March 2013 - 08:28 PM
Sig made by me
#18 dankoB
  • 3012 posts
Posted 19 March 2013 - 09:09 PM
You don't actually need /drive_c/ at the beginning of the command, Remove that and you may be able to get it to run although you may have to install Steam and download it directly to the wrapper. It has to do with the registry keys that get saved to the system.reg file in the resources folder. Check the tutorial section for instructions to install steam.
This link may also help to troubleshoot some issues
http://appdb.winehq....rsion&iId=24799
There is no reason to run the game from parallels, that would normally be used to simply install the software. It's also a fairly outdated method seeing as how the Wineskin installer works just as good with no need to deal with windows.
Good luck!
#19 rystaman
rystaman
  • 29 posts
Posted 20 March 2013 - 07:15 AM
Okay thanks :D But you know at this screen
Where do i direct it to ?
Sig made by me
#20 rystaman
rystaman
  • 29 posts
Posted 20 March 2013 - 07:36 AM
Good luck!
So do i clicked run and it installed.
Then where is the setup.exe and how do i then actually get it to play ?
Sig made by me
#21 thanoulas
thanoulas
  • 568 posts
  • LocationLondon
Posted 20 March 2013 - 02:08 PM
Ok, let's take it from the top because I'm lost as to what progress you've made.
You said that you have bought the game off Steam, is that right? If so, you NEED to install Steam first. If the winetricks installation doesn't work, try clicking on "Update Winetricks" first, then running the steam winetrick.
Let's first get you to the point where you have installed steam, and we'll take it from there.
#22 rystaman
rystaman
  • 29 posts
Posted 20 March 2013 - 06:59 PM
Okay, I'm going to start again in a new wrapper.
Sig made by me
#23 rystaman
rystaman
  • 29 posts
Posted 20 March 2013 - 07:05 PM
1. I have placed contents of steam folder into drive_c folder
2.  Clicked on wineskin in the wrapper and clicked winetricks and ran the steam app thing it came up with this
Also when i clicked update winetricks it didn't let me update
Sig made by me
#24 thanoulas
thanoulas
  • 568 posts
  • LocationLondon
Posted 20 March 2013 - 10:32 PM
Sorry about that. The wrapper is outdated. Start with a fresh wrapper, and don't move ANY files inside it.
Download the Wineskin Winery, if you don't already have it. (http://wineskin.urge...?page=Downloads)
Then, in the game's wrapper, go to advanced > Tools > Update wrapper. After it's done, the "wrapper version" should change to 2.5.9 or later.
Then, go to winetricks, update winetricks, then install steam from there. As I said, DO NOT MOVE ANY FILES INSIDE THE WRAPPER.
Anyway, here's a wrapper with the first stage of the steam installation done. Just run it, log in to steam and download Anno 2070. When you're done with this step I'll let you know of the rest.
http://goo.gl/75bbg
#25 rystaman
rystaman
  • 29 posts
Posted 21 March 2013 - 07:19 AM
When i double click it it just goes onto my dock, it just stays there for about 2 seconds and then goes away.
Sig made by me
#26 thanoulas
thanoulas
  • 568 posts
  • LocationLondon
Posted 21 March 2013 - 03:30 PM
what tool did you use to extract the file?
#27 rystaman
rystaman
  • 29 posts
Posted 21 March 2013 - 06:40 PM
The unarchiver
It's on Mac App Store
Sig made by me
#28 thanoulas
thanoulas
  • 568 posts
  • LocationLondon
Posted 21 March 2013 - 08:08 PM
I guessed so. You need to extract it with 7zx, the unarchiver is poop with 7z files and breaks them.
#29 rystaman
rystaman
  • 29 posts
Posted 21 March 2013 - 09:38 PM
Ahh. Alright :)
Sig made by me
#30 rystaman
rystaman
  • 29 posts
Posted 21 March 2013 - 10:18 PM
So i used 7zx and it just stays on the dock and does nothing and then disappears. Should i put my game files into the wrapper ? Into the steam folder ?
Sig made by me
